Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jun 11, 2025 at 5:54 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Thanks man!
    I ordered front and rear diffs with 4.88 gears and LSD in the rear. Thanks though man!
    3JOH22A and jordi992[QUOTED] like this.
  2. Jun 11, 2025 at 6:50 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Think I have one too.
    TegoTaco likes this.
  3. Jun 11, 2025 at 7:32 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    llamasmurf, tgelata and tacoma16[OP] like this.
  4. Jun 11, 2025 at 11:11 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    :bananadance:
    Mahindra 4550 4WD w/ rear diff lock :cookiemonster:
    2866lbs front lift capacity
    3K lbs lift was my need. Overloading a tractor is what they are meant for. It will do everything I need.
    ODSC1, TunedUpTaco, Shveet and 5 others like this.
  5. Jun 11, 2025 at 11:40 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    There is usually a hydraulic limiter that you can bypass to increase flow and thus lifting. Have to walk a thin line to ensure you don’t blow the seals out of the cylinders or damage lift points. A lot of manufacturers really limit their machines to ensure user error doesn’t occur for new operators.
    congrats on the new tractor. Nice machine that’s handy to have.
    llamasmurf[QUOTED] likes this.
  6. Jun 11, 2025 at 11:46 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Nice! The snow-clearing tractor I saw in Ardbeg this Feb was a Mahindra, though it had an enclosed cab.
  7. Jun 11, 2025 at 1:44 PM
    llamasmurf
    Wes
    Northern Ontario
    Ya I could not afford the lifting capacity with enclosed cab.
    Will be chilly working snow fo sho.
    3JOH22A[QUOTED] and Windigo like this.
  8. Jun 11, 2025 at 2:51 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    @TegoTaco
    this is from @honkonbobo third gen if I recall. Not sure if the center open diffs are the same but you are more then welcomed to it.
    image.jpgother option is getting an entire third member from a wrecker. I have gotten two frontndiffs from standard auto wreckers without much trouble.
    Also I’m not sure who bought @Windigo rear end but they may have some spare parts or be able to help ya out.
    Unless it’s full send and getting a rear gear and some goodies going. If so carry on!
  9. Jun 11, 2025 at 3:37 PM
    blackgen2tacoma
    blackgen2tacoma Well-Known Member
    Andrew
    2013 black Tacoma limited
    @tacoma16 I was sharing the carnage lol. We are doing a rear gear and lsd. Thanks for the help. Quick question if I put a third gen axle tube in my truck is the gearing the same for the front differential or I have to replace the front differential also??? Thanks
  10. Jun 11, 2025 at 3:41 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    What is the gear ratio of the 3rd gen rear end? Our second gens have the 3.73 so you would have to match that. Believe only the manual 3rd gens came with 4.10’s so if it’s out of an automatic you should have matched front and rear ratios.
    @3JOH22A sound about right?
  11. Jun 11, 2025 at 3:58 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Turd gen AT is 3.90
  12. Jun 11, 2025 at 3:59 PM
    TegoTaco
    Ontario, Canada
  13. Jun 11, 2025 at 4:01 PM
    TegoTaco
    Ontario, Canada
    Thanks a lot man! I did go full send on this repair lol. 4.88 gears with LSD. :) Praying I don’t ever hear that bang again. :D
  14. Jun 11, 2025 at 4:14 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    No worries, sounds super random. Even with all the abuse I put mine through the rear end has stayed together so far for me.
    Windigo likes this.
  15. Jun 11, 2025 at 4:15 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Maybe I misread this. What do you mean axle tube? The entire axle? If so apparently the gears are different and you would have to match the front.
  16. Jun 11, 2025 at 4:18 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    I'm guessing you'd want the larger 8.75" rear diff in the MT and Off Road AT models. I'm not sure if the pinion flange bolt circle and pilot diameter are bigger than 2nd gen. The driveshaft diameter is bigger at the carrier bearing, and the transfer case output flange is bigger too.
  17. Jun 12, 2025 at 12:28 PM
    TunedUpTaco
    TunedUpTaco Well-Known Member
    Rob
    Dundas, Ontario
    2017 Tacoma TRD OffRoad - DCSB - Auto - Stock(ish)
    Any electricians here?
    I bought a welder. It's both 120 and 220 V capable.
    I have a 220 outlet in the garage, but it uses a Nema 14-50 plug (pic-left) The Welder has a Nema 6-50 plug (pic-right)
    There are adaptors on scAmazon for this, but is that safe to use? Rather not blow up/burn down the place....
    tacoma16[OP] and TegoTaco like this.
  18. Jun 12, 2025 at 12:37 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Could you live with burning your house down because of an adapter?
    drag your ass to a welding supply store and talk to a guy. We do hood rat shit. maybe 1 person here is welder certified and i doubt its @Norilsk
    Windigo likes this.
  19. Jun 12, 2025 at 12:55 PM
    TunedUpTaco
    Rob
    Dundas, Ontario
    :D I'm actually heading out there tomorrow - so I'll ask there for sure, since, surprising as it is, I'd rather not burn down the place
    :nuclear:
    Shveet[QUOTED] likes this.
  20. Jun 12, 2025 at 1:36 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Could you change the plug? I ran an adapter to use my 220 welder plug to adapt to a 30amp dryer plug. Worked fine.
