Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jun 24, 2025 at 6:56 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I don't know how I'd know that. Speedy Glass did it. But I don't know how well anything takes rock chips
  2. Jun 24, 2025 at 7:10 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Lower left corner should have the glass mfr's name/logo. OEM is Pilkington at least in 2018.
    blackgen2tacoma likes this.
  3. Jun 24, 2025 at 7:11 PM
    blackgen2tacoma
    blackgen2tacoma Well-Known Member
    Andrew
    2013 black Tacoma limited
    Thanks for your help guys. I talked to my neighbours buddy who does windshields and he recs pgw with oem moldings. Going with him as the guy my shop uses now installs windshields with a welding mask and is a total butcher.
    tacoma16[OP], llamasmurf and 3JOH22A like this.
  4. Jun 24, 2025 at 8:30 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I just checked. It's PGW
    3JOH22A[QUOTED] likes this.
  5. Jun 25, 2025 at 3:13 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
  6. Jun 26, 2025 at 4:17 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    anyone have a sway bar lying around, not the factory tacoma one but just one that looks like a big elongated "u" thanks ahead of time
  7. Jun 26, 2025 at 5:33 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Without dimensions, Best i got;
  8. Jun 26, 2025 at 7:25 AM
    Windigo
    Farook
    '14 Acess Cab
    :) exactly like that but ...
    Roughly 31" wide with around 12- 15 inch arms.
    I took some measurements there rough but I'm just making things up as there is no option unless I want to pay over a grand for the anti rock sway bar. And I need 2 :eek: so most likely $2060. Can't afford that for sway bars. Have to look for a used option
  9. Jun 26, 2025 at 8:06 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  10. Jun 26, 2025 at 8:22 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Hard to find OEM straight sway bars for packaging reasons. Exceptions are vehicles like Jeep Wranglers and early-'90s GM half-tons. If you have access to a Jeep JK, take some measurements of the front sway bar to see if it'll fit.
    Alternatively make your own with 4130 chromoly thick-wall tube, and rectangular tube as levers. The Currie Anti-rock is expensive because it's splined. If you're welding the levers to the tube, it's a lot cheaper.
  11. Jun 26, 2025 at 1:30 PM
    Windigo
    Farook
    '14 Acess Cab
    Anyone want this 1/2 end gen front bumper with worki.g fog lights? Free come and get it please.
    tacoma16[OP] likes this.
  12. Jun 26, 2025 at 5:35 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    TunedUpTaco likes this.
  13. Jun 27, 2025 at 7:31 AM
    llamasmurf
    Wes
    Northern Ontario
    Now I am at the point of maybe wanting the bed box on, or off depending on how I want to use the truck.
    I need something like this, but for the 62" bed box.
    https://www.homedepot.ca/product/dewalt-toughsystem-2-0-adaptor/1001807976
    So the bed box would mount to a small platform with the latches on it? The bed has the click in part bolted to it?
    Help me boys, it now needs to be modular :rofl:
    tacoma16[OP] and Windigo like this.
  14. Jun 27, 2025 at 8:01 AM
    Windigo
    Farook
    '14 Acess Cab
    I'm simple and cheap so Id just make an angle iron frame that the box sits inside of with two bolts on either side that pinch the box in. Or instead of pinch bolts threaded nutserts in the box and holes in the angle iron and a quick bolt in and out. Good luck with it. Sounds like a nice project
    llamasmurf[QUOTED] likes this.
  15. Jun 27, 2025 at 8:12 AM
    llamasmurf
    Wes
    Northern Ontario
    The box is paper thin aluminum, so it must be mounted flush on the weight supporting surface. As it is mounted flush on the bed, the bed holds the weight, not the box. It just keeps things dry. You cant 'Pinch' it to hold it in place, it will crumple like a pop can. The angle iron would have it 1/4" up on the sides and it would cumple in the middle. 1/4" plate for the bottom seems heavy.
    This was the idea of the platform, dont really want to use wood for it, bit its looking that way.
    Windigo[QUOTED] likes this.
  16. Jun 27, 2025 at 8:14 AM
    Windigo
    Farook
    '14 Acess Cab
    I have ordered one as it's getting close to driving. Just need to get the sway down. Hopefully I can custom mount some sway bars, brakes kind of still feel spongy maybe air, couple of other little things but hopefully driving soon. I don't plan to have a front drive shaft for this year, so maybe no four-wheeling. Let's see.
  17. Jun 27, 2025 at 8:15 AM
    Windigo
    Farook
    '14 Acess Cab
    If that's the case, just take a look at the Milwaukee packout platforms. When my truck flipped over those cases were in the back packed full and never came unlatched or moved. I'm not sure about the DeWalt stuff. How secure it is. Somebody else would have to chime in on that.
  18. Jun 27, 2025 at 8:17 AM
    llamasmurf
    Wes
    Northern Ontario
    I just need that idea but larger?
    Is there some sort of commercial equivialant in the back of plumbers trucks or something?
    Bunch of these wanks are contractors, I knows it.
    :duh:
    Hmm, wood platform, ratchet straps, to the side rails.
    HMMMMMMMMMMMMMM
    Then I can have it removable via tractor with pallet forks.
    @Windigo Thnx mate.
  19. Jun 27, 2025 at 1:37 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    does the bed box go from the tie down angle to tie down angle on the bed? My bed box is just a simple bolt through the tie down angle. Keeps it locked in. If you want to go through the floor I just used a 1/4” plate to increase the surface area when mounting my half box.
    Edit
    I’ll try and grab a photo if that doesn’t make sense
  20. Jun 27, 2025 at 1:52 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Multiple (say 8) latches like those used for swing out tire carriers?
    Mount the handle portion to the box walls and the small hook portion to the bed.
