Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jan 5, 2018 at 8:36 AM
    #6641
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    So what do you guys think? I'll be purchasing the ball joint and bushings so I'll basically have a new set of spc control arms. But I don't want shit to fail unexpectedly. Is it worth it to switch over to uniball? And what are the most reliable/reasonably priced?
  2. Jan 5, 2018 at 8:40 AM
    #6642
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Total chaos. Strongest on the market. Same I have
    Tridet167 likes this.
  3. Jan 5, 2018 at 8:48 AM
    #6643
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I'm actually looking at them right now. Heim joint or not?
  4. Jan 5, 2018 at 8:54 AM
    #6644
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Aaaaaaaahhh... crap! Well, at l;east you can buy new ball joints, and I think that they have improved them too.
    But, safety first. I never had problems with my SPC's, but then any problems that would have occurred are now someone else's.
  5. Jan 5, 2018 at 9:00 AM
    #6645
    taczilla
    Marc
    2016 RAM Rebel
    I tried that, and it does come with a locker. She's bellied up in packed snow.
    Farmer neighbour is coming over after lunch and feeding the cattle. He has to thaw out his big-ass tractor. I also checked my warranty booklet, and the Roadside Assistance program provides a tow service for free, even if I'm stuck! But they are overwhelmed in this cold weather.
    llamasmurf likes this.
  6. Jan 5, 2018 at 9:01 AM
    #6646
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    bet that would not happened with taco... ;)
    It's a heavy whale you got now
    Manfred, 69TACO16 and Tridet167 like this.
  7. Jan 5, 2018 at 9:11 AM
    #6647
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I have Total Chaos and I like them. Just need to keep them greased and cleaned.
  8. Jan 5, 2018 at 9:16 AM
    #6648
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I'm thinking of going with the icons with the delta joint. If I can pick up a used set for a decent price I can retro fit the delta joint into them. For now I'll run the spc's.
    Tridet167[QUOTED] likes this.
  9. Jan 5, 2018 at 9:19 AM
    #6649
    taczilla
    Marc
    2016 RAM Rebel
    Yup... and how ironic, look what Purolator just dropped off at my door.
    He drove right by my truck, too.
    Tridet167, over60, 69TACO16 and 5 others like this.
  10. Jan 5, 2018 at 9:20 AM
    #6650
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Heavier steering feel, because the massive 1" or 1.25" uniball has more friction than a typical grease-filled ball joint.
    Mine (FK 1.25" bore) have no freeplay after about 85000 km. Every few months I give them a squirt of telfon bike chain lube.
    Get Total Chaos because they use stainless uniballs with stainless spacers (as opposed to chromoly ones on All-Pro arms). Heim inboard joints are not necessary. ("Base" versions with urethane bushings are good enough.)
  11. Jan 5, 2018 at 9:22 AM
    #6651
    Thyces
    Ontario
    2009 DCLB TRD Sport
    What are your opinions on the delta joint offered by icon?
  12. Jan 5, 2018 at 9:38 AM
    #6652
    KenLyns
    Belly of the Beast
    There's no boot on the Icon delta joint, so contaminants will get in the same way as with a uniball, though I suppose you can flush it out by greasing.
    Replacement delta joint seems to be twice as expensive as a replacement uniball bearing, if prices on Icon's web site are typical: http://iconvehicledynamics.com/shop...p-toyota-tacoma-delta-joint-retrofit-kit.html
    It is likely the delta joint will fit in UCAs from other mfrs that were designed for 1.00" uniballs (TC, Dirt King). Maybe used TC UCAs are more available than used Icon UCAs because TC had a 5-year head start in the market, just speculating. UCAs designed for 1.25" uniballs (All-Pro, Camburg) won't be compatible.
    llamasmurf and Thyces[QUOTED] like this.
  13. Jan 5, 2018 at 10:01 AM
    #6653
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I've been reading and it seems that it is a sealed unit. Bottom has a "wiper".
  14. Jan 5, 2018 at 10:01 AM
    #6654
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Can I get some input on the jba arms?
  15. Jan 5, 2018 at 10:07 AM
    #6655
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
  16. Jan 5, 2018 at 10:20 AM
    #6656
    KenLyns
    Belly of the Beast
    @Taco-Can
  17. Jan 5, 2018 at 10:20 AM
    #6657
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I thought someone here had them....
  18. Jan 5, 2018 at 11:00 AM
    #6658
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    I wonder if @tacoma16 knows of any spots on the property with a hill and enough speed, you could potentially get all 4 tires off the air?
    Tridet167 and llamasmurf like this.
  19. Jan 5, 2018 at 11:01 AM
    #6659
    Norilsk
    Eugene
    need a new truck again? lol
    taczilla and 69TACO16 like this.
  20. Jan 5, 2018 at 11:08 AM
    #6660
    KenLyns
    Belly of the Beast
    Keep in mind the ZR2 has improved shocks but no hydraulic bumpstops...
