Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Mar 6, 2018 at 6:52 PM
    #8021
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
  2. Mar 6, 2018 at 7:24 PM
    #8022
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    :thumbsup:
  3. Mar 7, 2018 at 4:48 AM
    #8023
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Bocsy44[QUOTED] and llamasmurf like this.
  4. Mar 7, 2018 at 5:49 AM
    #8024
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
  5. Mar 7, 2018 at 6:24 AM
    #8025
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Yeah its not too bad. Wondering though, if your not planning on tubbing is it really worth it. Right now I am rubbing on the firewall. It would look a lot cleaner than my current mounts. However, once I cap them, they should look better hopefully lol.
    Bocsy44 and llamasmurf[QUOTED] like this.
  6. Mar 7, 2018 at 1:31 PM
    #8026
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    Just wanted to let you guys know that the site I mentioned earlier called Overland Outfitters based out of B.C is now offering a TW Discount!!
    Tacomaworld10 for 10% off!
    https://overlandoutfitters.ca/
  7. Mar 7, 2018 at 1:33 PM
    #8027
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    if only they were selling Pelfrey skids...
    On another note, how everyone paints sliders, what are the steps to take so it doesn't rust the first winter?
    Bocsy44[QUOTED] likes this.
  8. Mar 7, 2018 at 1:38 PM
    #8028
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    clean with mineral spirits or acetone, apply self etching primer, paint. primer recommends doing a light wet sand to scuff metal to help etch
    Norilsk[QUOTED] likes this.
  9. Mar 7, 2018 at 1:39 PM
    #8029
    Ares
    Ares Well-Known Member
    Darek
    Hamilton , ON
    2015 LTD DCLB
  10. Mar 7, 2018 at 7:09 PM
    #8030
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    I've been watching what's going on here....
    Holy crap!
  11. Mar 8, 2018 at 5:09 AM
    #8031
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    If anyone needs I have amsoil 75w-90 that I am not going to need as much since I can only use it in the t-case now...A case will take me a long time to burn through....
    llamasmurf[QUOTED] likes this.
  12. Mar 8, 2018 at 5:31 AM
    #8032
    llamasmurf
    Wes
    Northern Ontario
    Ill take it! Just lemme know the :spending:
    Muh rear diff will love that kind :cookiemonster:
    tacoma16[QUOTED][OP] likes this.
  13. Mar 8, 2018 at 5:34 AM
    #8033
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    kk I have to figure out how much I paid for it all, and then how many containers I have left. lol. Ill keep you posted.
  14. Mar 8, 2018 at 2:44 PM
    #8034
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I need help. Going to wire up my ARB compressor and had some Q's. I'm installing it behind the rear seat and wanted to wire it up having the switch right next to the compressor so as I need to run it, I'll turn it on/off there. Can I wire it up just using the isolation switch connection without tying it into the ignition? There's a seperate wire for lighting the switch, which I don't care for, and one for the ignition.
    tacoma16[OP] likes this.
  15. Mar 8, 2018 at 2:49 PM
    #8035
    llamasmurf
    Wes
    Northern Ontario
    Tying it to the ignition makes it so it can not be used while the truck is off (so as to not accidentally turn it on when not in use and burn out the compressor and kill the battery)
    2nd option is to connect the 'ignition' wire to a wire that is always live. I would not do that, I installed it as the instructions said.
    Tridet167[QUOTED] likes this.
  16. Mar 8, 2018 at 2:58 PM
    #8036
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Yeah you can run it that way. Just pick up the wires ya need. As Wes said just make sure you don’t leave it on while the trucks off.
  17. Mar 8, 2018 at 3:36 PM
    #8037
    Tridet167
    Tony
    Toronto, Canada
    I would always know to run it with the truck on so no big deal there. So I still need to use the ignition wire as a supply, correct?
  18. Mar 8, 2018 at 4:33 PM
    #8038
    llamasmurf
    Wes
    Northern Ontario
    never mind i read this wrong.
    I :cookiemonster:
    I should not answer electrical questions. I stop now.
  19. Mar 8, 2018 at 4:49 PM
    #8039
    Tridet167
    Tony
    Toronto, Canada
    Hey no worries man. I now have to figure out which route to take and where to get the power. I love electrical stuff just not on cars. I think cars are such a pain in the ass with all the routing of wires behind and under stuff.
    I'm almost tempted to just leave it under the hood because it's so much easier.
  20. Mar 8, 2018 at 5:30 PM
    #8040
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    dude...i'm an electrician and I hate it lmao.
    auto electrical is a cunt.
    and the methods are so different from AC wiring and code.
    Take for instance switching grounds in DC. Would be like switching a neutral for a light which is against code for so many reasons.
    DC you also need to consider distance much sooner. 15amps over 10 ft can change what size wire you run. vs CEC being 3% voltage drop every 100ft for feeds and 5% for anything else.
