Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jun 13, 2018 at 5:21 PM
    #9921
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    If you're talking about the Cambridge plant (don't quote me ive been drinking, and dont want to text them to confirm) lexus that's being run through right now, source: 3 people from my regiment work there full time lol. They get bonuses if they spot defects or problems in production (not small bonuses but like 800-3k in monies)
    Therby[QUOTED] likes this.
  2. Jun 13, 2018 at 5:37 PM
    #9922
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I agree, the front I wouldn't mind Fox. It would make it all pretty under there with my TotalChaos UCA's. I need to research this since I think I'm going to need to beef things up.
    soon. The weight of the armour and bumper is giving the front end a work out right now.
    llamasmurf and Joe23[QUOTED] like this.
  3. Jun 13, 2018 at 5:38 PM
    #9923
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    They're not rebuildable unless you're referring to the BP 51.
    Which I would image are around the same as the fox, Kings and icons
  4. Jun 13, 2018 at 5:39 PM
    #9924
    Joe23
    Well factory fox won't do any better they only come with 600lbs springs. I'll be upgrading to 700lbs when I do my bumper
  5. Jun 13, 2018 at 5:48 PM
    #9925
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    I think you mentioned that before but I wasn't about to look through 40 pages of OM&G pages ahah
    Joe23[QUOTED] likes this.
  6. Jun 13, 2018 at 5:50 PM
    #9926
    Joe23
    Rebuilds are only for remote reservoir shocks.
  7. Jun 13, 2018 at 5:54 PM
    #9927
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    ya I haven't personally heard of any limits, but id be interested to know what they are with the OME, or when they fail at
  8. Jun 13, 2018 at 6:31 PM
    #9928
    Joe23
    it would depend on wear and abuse.
    Once you start having shock fade its time to go.
    For what its worth Fox have three different service intervals
    off road only every 1600km
    50/50 every 32 000km (this is referring to desert racing though not slow wheeling type)
    and all on road 80 000km.
    I don't plan on doing it the 50/50 because they should be fine given I dont do fast off road and they won't get stressed.
    If I start noticing shock fade before the 80 000km I'll service them but I don't think I will.
    If you stressed a normal shock the way anything remote reservoir is designed to be used it would be destroyed in minutes.
    remote reservoir can handle it because it has a shit load more oil and nitrogen and is stored externally so it cools better, and obviously the valving inside is different with some using dual bypass or triple bypass valving. But if you don't have the valving and tuning set up properly for your conditions you can burn out a RR just as fast.
    Manfred[QUOTED] likes this.
  9. Jun 13, 2018 at 6:49 PM
    #9929
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    So the shocks I picked up are beyond repair. Getting my money back.
    On the bright side I got this banged out.
    IMG_20180613_214010.jpg IMG_20180613_214144.jpg IMG_20180613_214116.jpg IMG_20180613_214106.jpg IMG_20180613_214020.jpg IMG_20180613_214023.jpg IMG_20180613_214047.jpg Otis safe door circa 1960 with Yale lock. Solid 4x4 weathered oak legs lag bolted. ~275lbs
  10. Jun 13, 2018 at 6:51 PM
    #9930
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Oh yeah...compustar remote start/alarm with t11 remote also got installed today.
    tacoma16[OP] and llamasmurf like this.
  11. Jun 13, 2018 at 6:56 PM
    #9931
    Joe23
    what was wrong with the shocks?
    You'd be surprised how much you could actually repair lol. It just becomes the point of is it worth it.
  12. Jun 13, 2018 at 6:59 PM
    #9932
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Where do you get all that hipster stuff? That good looking cart and now this, I like it.
  13. Jun 13, 2018 at 7:02 PM
    #9933
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I hooked up with this guy that does demo of historic houses in Windsor. I pay him a premium for first pick before they smash shit.
    CNDSndstrm and Norilsk[QUOTED] like this.
  14. Jun 13, 2018 at 7:03 PM
    #9934
    Thyces
    Ontario
    2009 DCLB TRD Sport
  15. Jun 13, 2018 at 7:04 PM
    #9935
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Bent shaft and wallowed out lower mount. I spoke to ski and he said it's not worth the trouble.
    tacoma16[OP] and Joe23[QUOTED] like this.
  16. Jun 13, 2018 at 7:09 PM
    #9936
    Joe23
    ah ya in that case not worth it lol.
    It is technically repairable but the cost would be so much not worth it.
    Thyces[QUOTED] likes this.
  17. Jun 14, 2018 at 6:25 AM
    #9937
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Well this was an interesting watch, learned lots in regards to our trucks ignition and stuff that I had no idea about, as I am a noob to all this.
    Sits for 2+ years and started like it was running already that day lol
    :bananadance:
    desertrunner24 and Therby like this.
  18. Jun 14, 2018 at 6:25 AM
    #9938
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    Who wore the 285s better?
    Tridet167 and llamasmurf like this.
  19. Jun 14, 2018 at 6:27 AM
    #9939
    llamasmurf
    Wes
    Northern Ontario
    They look more aggresive on your rig, might be cuz of the front bumper just showing them off more.
    I honestly do not mind the look of the front of the ZR2, not sure why everyone hates on it so much. :notsure:
  20. Jun 14, 2018 at 1:38 PM
    #9940
    Tridet167
    Tony
    Toronto, Canada
    What springs are you getting? Would I be able to swap out any spring?
    That is very cool.
    I'm going with @Ttaco15
