Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jun 27, 2018 at 6:50 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    you're back
    how was the ban? lol
    and ya I noticed which is why I'm upgrading to air bumps :D
    llamasmurf and KenLyns[QUOTED] like this.
  2. Jun 27, 2018 at 7:12 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Back from the perp walk lol...Welcome back!
    KenLyns[QUOTED] and Joe23 like this.
  3. Jun 27, 2018 at 7:32 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Haha. Had to go 275. Worst case is they don’t fit and my dad can use them. But found a couple guys that have a rim with 0 or -6 offset and they say they don’t rub.
    tacoma16[QUOTED][OP] likes this.
  4. Jun 27, 2018 at 7:34 PM
    Canadianguy91
    Sean
    2016 Limited
    All the main stuff. They say anything but abnormal wear. I email bilstein to ask them if there is more of a difference other then me getting a new one quicker from 4wp
  5. Jun 27, 2018 at 7:36 PM
    Canadianguy91
    Sean
    2016 Limited
    Depending on the wait time, I may be forced into those 17’s
    tacoma16[OP] likes this.
  6. Jun 27, 2018 at 7:38 PM
    Joe23
    BOORRRRRRRINGGGGGGGGGGGGGGGG
    just do 285 and cut:boink:
  7. Jun 27, 2018 at 7:39 PM
    Joe23
    :yes::yes::yes::yes::yes:
    :woot:
    Therby and Canadianguy91[QUOTED] like this.
  8. Jun 27, 2018 at 7:39 PM
    Canadianguy91
    Sean
    2016 Limited
    Get the grinder!
    Joe23[QUOTED] likes this.
  9. Jun 27, 2018 at 7:41 PM
    Joe23
    they'll rub flexed.
    those that say they dont rub just dont flex it at all or they don't notice the rub.
    It wont be a terrible rub like a 285, but rub is rub and any rub is not good for a tire.
    you'll definitely need to get rid of mud flaps, and possibly fix rub with heat gun, but could be body mount too depending on alignment
  10. Jun 27, 2018 at 7:41 PM
    Joe23
    I've got two, and a bunch of zip cut blades.
    peters got a welder
    sure we have plenty of big fuckin hammers
    LETS DO THIS SHIT
    :sawzall::welder:
  11. Jun 27, 2018 at 9:07 PM
    Canadianguy91
    Sean
    2016 Limited
    See they were saying if I went say -12 then i would have a higher chance rubbing on plastic then on the body mount. Only other option is go back to the 265 but then I’m 1/2” taller.
  12. Jun 27, 2018 at 9:08 PM
    Canadianguy91
    Sean
    2016 Limited
    I meant for yours! Hey if we need to I can bring a quick cut
  13. Jun 28, 2018 at 5:16 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Are these the Timbrens you had @Joe23 ?
    I find they are taller than stock bumps and I am hitting on them quite often. They are mutli-stage so they are supposed to?
    They work great off road when I flex it :militarypress: no complaints there at all.
  14. Jun 28, 2018 at 5:56 AM
    Joe23
    Factory spec is + offset as soon as you start going less than that you're moving the wheel further out.
    -6 or -12 both are being pushed out more and become more likely to rub body mount.
    Mine are 0 offset and rubbed a lot, they're only 10mm wider than yours and your wheel will be 6mm further out than mine. So you're tire is actually sticking out further than mine. 5mm of my 10mm is each side but your outter side has been moved 6mm out.
    You might get lucky after all @Theicemedic is actually running a 285 75 16 without a CMC, and he's on the billies lift as well. But hes also on a + offset wheel. But he had to cut A LOT of plastic. He barely has any fender liner remaining lol
    You might get lucky you might not. There's so much inconsistency with these trucks and so many variables when it comes to which tire brand, size, wheel spec, alignment...
    The only reason you might not rub is the tire you're going with runs small
    Mine already fit lol
    Yes for now .I have icon air bumps going in soon
    llamasmurf[QUOTED] likes this.
  15. Jun 28, 2018 at 6:13 AM
    llamasmurf
    Wes
    Northern Ontario
    Ok, just wanted to know if we had the same shiz. :cookiemonster:
  16. Jun 28, 2018 at 6:17 AM
    Joe23
    Its probably the only matching part of lift we have and it will soon be gone lol
    Therby and llamasmurf[QUOTED] like this.
  17. Jun 28, 2018 at 9:48 AM
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    Been thinking about this for awhile.
    Someone convince me yes or no for cap life
    Got a good deal lined up for a A.R.E aluminum contractor cap.
    Its white which kinda sucks. Ill turn it black. No windows, side has a tool box and other side access to bed.
    Pic for attention, this cap is ridiculous on this guys truck. Minds just normal sized
  18. Jun 28, 2018 at 10:40 AM
    llamasmurf
    Wes
    Northern Ontario
    o_O
    What is the weight difference between what you made and the aluminum cap?
    :benchpress:
  19. Jun 28, 2018 at 10:59 AM
    Therby
    Kitchener
    Jeep JL
    Mine is 70-80ish i think. Aluminum is 110ish. Not that much. So much more things to do with the cap, but spending more money, but more capable at what i want.
    Its on all the time which is my biggest thing.
    I planned on doing this, just not this year. Price is too good and its exactly what i want. Plus they dont pop up forsale everyday. Especially the 5ft bed
  20. Jun 28, 2018 at 1:04 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    I hate cap looks in general, all old people have them :turtleride:what I noticed, open bed is like “young and free” :oldglory: to me.
    Mind that off-roading with cap at the rear will be problematic, just remember Peter and his setup.
    Atlas86 and Joe23 like this.
