Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jul 4, 2018 at 5:50 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Portions of South trail are already closed off now.
    If people abuse it more will close.
    All depends on the locals as well.
    TMR are no longer holding King of the shield in Perry sound anymore because the cottage association there got it closed.
    Hopefully nothing more gets closed though.
    pete37[QUOTED] and Therby like this.
  2. Jul 4, 2018 at 6:52 AM
    pete37
    pete37 Well-Known Member
    peter
    Toronto Canada
    2008 trd offroad aclb 2016 trd sport stolen 2019 TRDORSB
    Hope not its like 15 min from my cottage.love going wheeling when ever I feel like :mudding:
    Joe23[QUOTED] likes this.
  3. Jul 4, 2018 at 6:55 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Yeah they got crazy numbers on my truck....5 degrees of caster. Saweet
    Joe23[QUOTED] and Tridet167 like this.
  4. Jul 4, 2018 at 8:12 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^There's no benefit to running more caster than the factory ~3 degrees, just less tire clearance. I'm at 5 degrees with my non-adjustable All-Pro UCAs, because my front end isn't lifted very high. I rub on the fenderwell plastic with 32" tires on 0 offset wheels (but no rubbing with factory 30mm offset wheels).
    Tridet167 likes this.
  5. Jul 4, 2018 at 8:24 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    5 degrees of castor pushes my wheel forward getting it off of the firewall. Since my bumper is clearances this give me more room with 315’s. If your running stock stuff it doesn’t matter as you’ll run the front aposed to the rear.
    With my wheels at -38 offset and 3.5 backspacing I needed all the help to fit the 35’s. Based on what I have researched and personally seen the more castor the better (Don’t know if it’s negative or positive castor but pushing the wheel into the front fender
    Joe23 and llamasmurf like this.
  6. Jul 4, 2018 at 10:36 AM
    pete37
    peter
    Toronto Canada
    do you know were its closed off??
  7. Jul 4, 2018 at 1:49 PM
    Joe23
    That's how Minden is for me
  8. Jul 4, 2018 at 1:50 PM
    Joe23
    You can't miss it lol there's gates up. Southern tip
    pete37[QUOTED] likes this.
  9. Jul 4, 2018 at 1:51 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I have too much wear on the inside of the tire so I'm guessing the Toe needs adjustment?
  10. Jul 4, 2018 at 2:06 PM
    KenLyns
    Belly of the Beast
    ^That or too much negative camber. You can check camber with your phone attached to a straight edge pressed against your wheel rim.
    This is true for a stock setup that uses the LCA cams to adjust for caster, since more caster pushes the lower ball joint forward. Once the the LCA cams are maxed out, though, getting more caster from LR UCAs moves the upper ball joint toward the firewall.
    Joe23 and Tridet167 like this.
  11. Jul 4, 2018 at 4:23 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I went by the hydro line the other day, on Hwy #518, and they have cleared and widened the ROW there...… Maybe they are gonna "twin" the line..??
  12. Jul 4, 2018 at 4:32 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Moving the upper ball joint towards the firewall would move the wheel forward no? Not to sure on all of this. I just know what my paper says and that I’m the 35’s thread it says as much castor as possible lol
    Joe23 likes this.
  13. Jul 4, 2018 at 7:45 PM
    Joe23
    I dunno how you got so lucky because they only got me 3.6
  14. Jul 4, 2018 at 8:14 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Sucks to suck....
    Light racing has more adjustability than the uniball. You do have more travel though.
    llamasmurf and Joe23[QUOTED] like this.
  15. Jul 4, 2018 at 8:29 PM
    Joe23
    Can't win them all I guess
    Although there is an adjustable total chaos UCA but they do not like our climate
    tacoma16[QUOTED][OP] likes this.
  16. Jul 5, 2018 at 5:17 AM
    pete37
    peter
    Toronto Canada
    never been there looks like deep water don't need the carpets washed lol
  17. Jul 5, 2018 at 5:51 AM
    Joe23
    There's just as bad of water crossings if not worse in ardbeg.
    Just need to know which line to take through the water it's fine
  18. Jul 5, 2018 at 5:58 AM
    pete37
    peter
    Toronto Canada
    cool gotta check it out then thanks
  19. Jul 5, 2018 at 8:18 AM
    Joe23
    It's actually rated lower than ardbeg is lol
    But depending on the time of year can be worse. Last year was bad because it was so wet. This year it's been fine, lower than before.
    Other than the final water crossing at the end that if you don't know which way to go you'll swamp truck it's fine. It just seems like a never ending water crossing that goes around a bend.
    Therby likes this.
  20. Jul 5, 2018 at 8:40 AM
    pete37
    peter
    Toronto Canada
    cool well have to try it maybe you will come out and show the lines we need to take :thumbsup:
