Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Oct 20, 2018 at 5:16 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Haven't hit the highway yet but so far in the city it's good.
    Joe23[QUOTED] likes this.
  2. Oct 20, 2018 at 5:58 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^You just replaced the rear section? Be sure to give 'er on the highway to test it out... for science. :burnrubber:
    Was this the press tool you got? https://www.princessauto.com/en/detail/ball-joint-u-joint-service-kit/A-p8354714e
    Gas tank skid will require you to get replacement tank straps with studs. A bit of extra work to replace. It gets heavy, too, due to the large area. Recommend aluminum skid because the tank is level with the frame in most areas, so it doesn't see impacts most of the time.
    Tridet167[QUOTED] and llamasmurf like this.
  3. Oct 20, 2018 at 6:00 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    happy its all back together. What tool did you get for the u joints? I just got a complete shaft from a 2006 tacoma. Im sure its going to need new joints and bearings.
    and yes I got a pelfreybilt gas tank skid. However it only covers the bottom. Not sure if it would protect against the shaft hitting the tank. I went steel because of price and because I am a retard and aluminum most likely won't hold up.
  4. Oct 20, 2018 at 6:14 PM
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    Yeah this, gas tank skids are easy. Measure LxW go get a Aluminum sheet that size in 3/16.
    Then i just took my gas tank straps off, welded on new supports and brackets to drill holes into so i could bolt on the sheet of aluminum. Its above the frame rail so it was have to be a very weird situation to hit it hard, more for a little scrap here and there.
  5. Oct 20, 2018 at 11:48 PM
    Tridet167
    Tony
    Toronto, Canada
    Powerfist 3 piece set at Princess Auto for $100. They have another one for $79, which I wanted, but it was sold out.
    tacoma16[QUOTED][OP] and Norilsk like this.
  6. Oct 21, 2018 at 11:17 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    They flag the individual. Once flagged you will be stopped and searched every time you cross the border. Don't lie at the border. They can charge you up to 60% of the value of the item if you lie. They have more power and authority then any police. Be respectful and truthful. Most of the time they will let shit slide... If you don't lie.
    Joe23, llamasmurf and Atlas86[QUOTED] like this.
  7. Oct 21, 2018 at 1:03 PM
    Atlas86
    Atlas86 Well-Known Member
    Ontario
    2012 Tacoma TRD Sport DCLB
    Yeah, it's not worth it to try and save a few dollars.
    I thought we were going to get into more trouble.
    Thyces[QUOTED] likes this.
  8. Oct 21, 2018 at 2:53 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Our tanks hold how much?
    Tridet167, Therby and TeecoTaco like this.
  9. Oct 21, 2018 at 3:11 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    80L...that's pricey, I paid 99.9 on Friday
    Manfred likes this.
  10. Oct 21, 2018 at 3:14 PM
    Therby
    Kitchener
    Jeep JL
    Old man overland. Got a few extra overland points this weekend adding this and a rigid light. Still unsure about this as its so much weight but damn its useful
    sorgon82, Joe23, llamasmurf and 4 others like this.
  11. Oct 21, 2018 at 3:18 PM
    TeecoTaco
    SW Ontario
    I didn't think led lights were so heavy *shrugs*. I'm sure it'll pull its own weight tho! Have confidence in cheby!
    Tridet167 likes this.
  12. Oct 21, 2018 at 3:30 PM
    Therby
    Kitchener
    Jeep JL
    Honestly the rigid light is surprisingly heavy compared to cheap Amazon lights i have. Not the point but ya.
    Oh i love the cheby over my previous tacoma. More power and 8 speed, much more enjoyable to drive everyday
  13. Oct 21, 2018 at 4:31 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    :puke:
    Joe23 and Therby[QUOTED] like this.
  14. Oct 21, 2018 at 5:39 PM
    Tridet167
    Tony
    Toronto, Canada
    Did you get the slide as well? Don't remember you having one.
  15. Oct 21, 2018 at 6:38 PM
    Therby
    Kitchener
    Jeep JL
    Yup bought the whole kit, bedslide and ARE DCU cap
    Anyone interested in the bedslide for a shortbed? 55”Lx39”W
  16. Oct 21, 2018 at 8:58 PM
    Norilsk
    Eugene
    Maybe @Joe23 needs it to complete his overland build? :spy:
    Looking at all possible setups and ideas from the web I am set on purchasing a slide in camper, after I upgrade my suspension next summer to BP-51s, cause FOXesssss wearing out quickly from all the abuse I do to them... :annoyed:
  17. Oct 22, 2018 at 1:40 AM
    Therby
    Kitchener
    Jeep JL
    If i had a six foot bed (i did once but im stupid) id use a cap or something like that. Have everything inside and a sleeping set up, super easy and ready to go. Only way i keep this cap is if i cam figure out a decent way to sleep in it. But 5ft bed and 6ft me doesn’t really work
    Norilsk[QUOTED] and llamasmurf like this.
  18. Oct 22, 2018 at 3:38 AM
    Tridet167
    Tony
    Toronto, Canada
    Looks like everyone is becoming an overlander:rofl:
    Norilsk and Therby like this.
  19. Oct 22, 2018 at 7:20 AM
    Norilsk
    Eugene
    They sell campers for 5 ft beds as well, you are sleeping at the top ( above the cab), so it doesn't really matter what bed length you have.
    swift_model_silver_spur_taacoma_4x4_popup_truck_camper_low_profile_lightweight.-1.jpg
    I was overlanding before it was gay:anonymous:
    But this is my dream setup and goal, overland + crawler
  20. Oct 22, 2018 at 7:25 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    lolololol
    Everyone else is doing EXACTLY what I did, so now its no good.
    lolololololol
    :rofl:
    :stirthepot:
    Driving on dirt roads for more than 1 hour in North America is considered overlanding. :rimshot:
    I harvested more wood from the queen's forest this weekend. I now have way to much split and stacked oak. I have an addiction to splitting wood that must stop.
