Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Nov 24, 2018 at 5:11 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    @Tridet167 i think the only legal place to go is Raysplace but I’m thinking it’s a pretty beefy trail, like 35’s and up. Unless we do unmaintained roads and possibly some of the “rally of abandon Ontario” routes for back roads.
    llamasmurf[QUOTED] and Tridet167 like this.
  2. Nov 24, 2018 at 6:06 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I heard Ray's can be challenging. Anything would be good since weekends get boring closed indoors now. There's only so much PS4 I can handle.
    Joe23 and tacoma16[QUOTED][OP] like this.
  3. Nov 24, 2018 at 6:07 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Haha I hear ya. I’ll see what I can plan. Still have to get my truck sprayed though.
  4. Nov 24, 2018 at 6:08 PM
    Atlas86
    Atlas86 Well-Known Member
    Ontario
    2012 Tacoma TRD Sport DCLB
    Getting mine done tomorrow
  5. Nov 24, 2018 at 9:12 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    How did you do it?
    TeecoTaco[QUOTED] likes this.
  6. Nov 25, 2018 at 5:55 AM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    I have a cable and tech stream...and mad puter skills!
  7. Nov 25, 2018 at 7:06 AM
    Canadianguy91
    Sean
    2016 Limited
    i see i see!
    what other updates are there? like for anything else? I did one for the head unit already
  8. Nov 25, 2018 at 8:11 AM
    TeecoTaco
    SW Ontario
    I've done the head unit as well when I flashed another local's buggy. There are some other customizations that can be done, door chime off, how long lights stay on, seat belt chime and such.
  9. Nov 25, 2018 at 9:09 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I still need to get it
  10. Nov 25, 2018 at 9:29 AM
    TeecoTaco
    SW Ontario
    Whatcha need to get...thought you got TSB done at the dealer
  11. Nov 25, 2018 at 9:43 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    After almost two months, this hub/bearing assy I ordered finally arrived. BamaToy sent it late due to hiding from Hurricane Michael, then the shipment got caught up in the Canada Post strike. In hindsight, it was fortunate @NeonHeights sold me his spare so I could replace the visibly bad passenger front bearing. Now I'm replacing the driver side bearing as a preventative measure:
    AFQscrwj7ve3Er-ve9hZzD174mBrQAJvDSorJohA_7d87efd217c6c6edd9136cef5ba738280cd13c51.jpg
  12. Nov 25, 2018 at 9:49 AM
    Tridet167
    Tony
    Toronto, Canada
    I have the passenger side to do, starting to make some noise. It's my third in 2 years. Something isn't right on that side.
  13. Nov 25, 2018 at 9:56 AM
    Joe23
    I mean tech stream
  14. Nov 25, 2018 at 10:09 AM
    TeecoTaco
    SW Ontario
    Ahh, easy enough to get
    Joe23[QUOTED] likes this.
  15. Nov 25, 2018 at 3:38 PM
    KenLyns
    Belly of the Beast
    Maybe too much water is leaking into the spindle cavity. Did the bearing come with a new O-ring on the shoulder? Did you replace the inner CV seal?
    Tridet167[QUOTED] likes this.
  16. Nov 25, 2018 at 4:00 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    What about torqued properly? Over tightening can cause premature wear.
  17. Nov 25, 2018 at 4:23 PM
    KenLyns
    Belly of the Beast
    ^On the axle nut? It's possible (and very tempting to tighten with just a 1/2" impact and giving it a few ugga-duggas).
    Since @Tridet167 is running an aftermarket spindle with his 4" lift, it's also possible the axle seals are more finicky.
    llamasmurf likes this.
  18. Nov 25, 2018 at 4:34 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Very possible. Definitely premature wear considering I am on my second set of wheel bearings in close to 200kms. I don’t wheel a a lot but big tires, weight and what not.
    KenLyns[QUOTED] likes this.
  19. Nov 25, 2018 at 5:05 PM
    Tridet167
    Tony
    Toronto, Canada
    Only replaced the bearings at the mechanics so not sure about the seal but I would assume it comes with one. mechanic would have noticed that.
    Again mechanic so don't know.
    I'm thinking it's the stressses of the lift that's causing it. Unless there's something needing repair.
  20. Nov 25, 2018 at 5:41 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Your cv angles aren’t really crazy and your not running crazy wheel spacers or offsets right? leaves the mounting surface of the wheel bearing on the spindle
