Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Nov 28, 2018 at 9:17 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    I went to the entrance of the Hell's Gate and looked at it, at first I was like - "I've seen how to do it many times, I will be fine!", but then after walking and taking a closer look I was like "I have not seen any people in the past 5 hours, and I have no spotter, maybe next time?".
    Also there is a bit of a mix when it comes to those trails, there are two climbs on the Hells Revenge trail, the one that KIA, Tundra etc did for commercials is called "Escalator" and then there is Hell's Gate which is similar, but to access it you have to go thru some steep downhill and bash sliders very hard, picture below of the road that leads to start
    Hell's Gate Trail below
    I did the "Tip Over Challenge" where I almost flipped my truck and got steering locked - I couldn't steer in other direction as you can see on the picture, lot's of sweating:help:
  2. Nov 28, 2018 at 9:23 PM
    Norilsk
    Eugene
    Oh yes! Truck is only 10 months old and already has 40,000 kilometres, been on many "iconic" trails and more to come! Let's see how long this drivetrain will last with all the abuse I give it.
  3. Nov 29, 2018 at 5:25 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Great video! Thanks for sharing it :hattip:
    Some of those climbs look :headbang:
    You airing down for any of this amazingness? Having different tires would make that fun :anonymous:
  4. Nov 29, 2018 at 7:29 AM
    Norilsk
    Eugene
    Thanks! I was at 20psi all day. What I found interesting is that having soft tire compound (aka P rated) is beneficial on those kind of rocks so they can actually grip vs slip like Ko2s, Coopers Maxx or any tire that has hard rubber compound. Same thing was happening with me, while 3 Nokians were always in control the E rated Kelly tire (same tire profile, but way harder tire compound) tended to slip more often, but thanks to ATRAC that tire had breaks applied to decrease slippage. The more you know! :gossip:
    TeecoTaco and llamasmurf[QUOTED] like this.
  5. Nov 29, 2018 at 9:23 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Duratrac is a pretty soft compound too
  6. Nov 30, 2018 at 4:08 PM
    Norilsk
    Eugene
    After sandblasting my frame in Mojave desert it is time to cover it in a salt and let the rust process begin :annoyed:
  7. Nov 30, 2018 at 4:12 PM
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    Thats really cool shot
    Norilsk likes this.
  8. Dec 1, 2018 at 4:35 AM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    That is amazing!
  9. Dec 1, 2018 at 7:42 AM
    Atlas86
    Atlas86 Well-Known Member
    Ontario
    2012 Tacoma TRD Sport DCLB
    That looks amazing
    llamasmurf likes this.
  10. Dec 1, 2018 at 1:07 PM
    llamasmurf
    Wes
    Northern Ontario
    :cookiemonster:
    Well its the weekend so of course I cant help myself.
    :bananadance:
    So pretty :eek: The snow is so heavy right now, it is weighing down the small tree's. We had to turn around on 1 trail because it was as far down as you could see with folded over tree's all the way across the trail
    These Nokian Hakkapeliittas R2's become unbelievable when you drop to 15 psi:mudding:
    We saw 1 OPP truck on the unmaintained fire road we access trails off of today, he was writing some snow machines tickets it appeared as we passed. :devil:
    Manfred, Sloweburn, Tridet167 and 3 others like this.
  11. Dec 1, 2018 at 4:49 PM
    Atlas86
    Ontario
    Wow, you guys have a lot of snow up there.
    Therby and llamasmurf[QUOTED] like this.
  12. Dec 2, 2018 at 7:14 AM
    Tridet167
    Tony
    Toronto, Canada
    Out of curiosity, what is everyone's setup when it comes to front suspension downtravel limit? Any bumpstops or straps?
    I have a bumpstop that was added as part of my lift kit. It worked with the stock UCA but since I have upgraded to TC, noticed the other day, it now sits too low and needs to be modified. What's happening is that it droops all the way down and hits the coil. I also removed the sway bar which I think was the limiting factor for down travel? Thoughts?
  13. Dec 2, 2018 at 7:16 AM
    Joe23
    Sway bar will limit travel
    You shouldn't need limit straps with stock LCA it's only once you switch you need them
    Tridet167[QUOTED] likes this.
  14. Dec 2, 2018 at 7:39 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Just make a spacer for the bump. I may have some spacers for you.
    I have upgraded bumps right now. Limits my uptravel to help with clearancing. I kept the sway bar because it also helps with clearance.
  15. Dec 2, 2018 at 8:13 AM
    Joe23
    And driving with no sway bar with your weight would get sketchy .
    I'm thinking of doing no sway bar on trail and keeping it otherwise. It's really not much to remove
  16. Dec 2, 2018 at 8:50 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Think the weight of my coils would be fine since my weight is mainly down low now. With the rtt it may change. At the end of the day I am cheating using the sway bar to help with the tire clearance.
    Joe23[QUOTED] likes this.
  17. Dec 2, 2018 at 9:05 AM
    Sloweburn
    Sloweburn Well-Known Member
    Woodstock, ON
    19 Tacoma TRD Sport Premium
    3" lift. $10K in TRD options. Richie's semi-hidden bumper, and soon his Elka suspension
    A little earlier warning than usual! We're going to have a BS session at Mister Steaks Sunday, December 9th at 7:30pm.
    Drumbo cutoff @ 401, exit 250.
    TeecoTaco likes this.
  18. Dec 2, 2018 at 9:08 AM
    Sloweburn
    Woodstock, ON
    I have a Navi unit for sale if anyone is interested.
    Comes with GPS antenna, radio antenna adapter (if you have an older Taco, like mine), and reverse camera bypass for display instead of on mirror.
    https://www.kijiji.ca/v-view-details.html?adId=1401356561
    edit: Also have the garnish that fits 2005 - 2014.
    tacoma16[OP] likes this.
  19. Dec 2, 2018 at 9:37 AM
    Tridet167
    Tony
    Toronto, Canada
    That's what I was thinking.
    tacoma16[QUOTED][OP] likes this.
  20. Dec 2, 2018 at 9:40 AM
    Tridet167
    Tony
    Toronto, Canada
    It's not that bad as people think. There is a bit more lean when turning but you get used to it. I don't drive the truck like a sports car so not worried.
