Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jan 6, 2019 at 8:10 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Lol, soft shackles have a lifespan vs bow shackles that can last forever if you don't overload them.
    Light snow, they slip and projectile in a very deep snow. Ask me how I know.
    Sand they do fine, but you need to try REALLY hard to get stuck in the sand if you have ATRAC or Mall Control systems.
  2. Jan 6, 2019 at 8:16 PM
    Norilsk
    Eugene
    Just use your floor mats, they work great in any terrain.
    Atlas86, Tridet167 and Bocsy44 like this.
  3. Jan 6, 2019 at 8:16 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I again think you are using them wrong.
    Did you have a shovel and properly position the boards under the wheels?
    This winter I have purposely got myself stuck in 2 different situations that the boards just popped me right out.
    1.) I ran directly into a snow bank and high centered on it, trying to access a trail. My front wheels where over the far side of the bank, my rear wheels on the road almost still. Totally frame high centered. Few minutes with the shovel and boards properly positioned. Right out.
    2.) I drove into 3 feet of deep snow and pushed the skinny peddle until I saw sand. Then got the boards and shovel and again, with in a few minutes popped right out.
    Marc70 and Norilsk[QUOTED] like this.
  4. Jan 6, 2019 at 8:19 PM
    Taco-Bell
    Taco-Bell Forestry Student, Tree Hugger, Naturalist
    Ethan
    Thunder Bay, Ontario
    03 F250 6.0
    An unreliable engine
    I’m an animal, I don’t have floor mats atm :eek:
    Norilsk[QUOTED] likes this.
  5. Jan 6, 2019 at 8:19 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    Currently running smitty x20 with 10k lbs capacity and synthetic line. I like it a lot and has yet to fail on me. Plus if it snaps is much safer than SWR
  6. Jan 6, 2019 at 8:29 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Thoughts about a front hitch for a recovery point/lift point?
    Tridet167 and llamasmurf like this.
  7. Jan 6, 2019 at 8:37 PM
    Norilsk
    Eugene
    Yes, I know what you are talking, done it plenty of times, but the snow you are showing is nowhere deep compare to the image below lol.:deadhorse:
    Anyways, if it works for you - good to know:thumbsup:.
    You can bolt and then weld around like this, quick and easy solution.
  8. Jan 6, 2019 at 8:43 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    I’d do that but I don’t trust my welds at all lol. Trying to find a reasonably priced recovery point for a first gen and can’t.
  9. Jan 6, 2019 at 8:47 PM
    Norilsk
    Eugene
    The welds are there just to lessen the stress on bolts. I think 1st gens have same location that you can bolt on hook to?
    http://sosoffroadconcepts.com/factory-recovery-replacement/
    You can also just install front hitch, but you will loose ground clearance and I don't know if anyone makes high clearance hitch for 1st gens. @llamasmurf has mine and it has 2 tow points and a hitch.
    llamasmurf likes this.
  10. Jan 6, 2019 at 8:51 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Thought you meant I fab something like that up myself. Not sure if the bolts on 1st gen line up with 2nd or 3rd Gen. I’ve got the stock one bec I have an Off Road, just don’t know how much I trust that either.
  11. Jan 6, 2019 at 8:56 PM
    Norilsk
    Eugene
    You can make one too, 3/8 piece, 90 degree bend and cut out hole for a bow shackle. :welder:
    If it's an actual hook (not a transportation point) it will do you fine, we will rip your frame off before that hook comes off :devil:
    Taco-Bell[QUOTED] likes this.
  12. Jan 7, 2019 at 3:15 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    They worked great in the snow run st Peter's uncles
  13. Jan 7, 2019 at 4:13 AM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Bocsy44 likes this.
  14. Jan 7, 2019 at 5:26 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
  15. Jan 7, 2019 at 5:39 AM
    llamasmurf
    Wes
    Northern Ontario
    Here are some pics from my install, you can see what it bolts to in them.
    You remove the 2 aluminum blocks with studs on them, and replace with a few bolts.
    Marc70 and Taco-Bell[QUOTED] like this.
  16. Jan 7, 2019 at 5:40 AM
    pete37
    pete37 Well-Known Member
    peter
    Toronto Canada
    2008 trd offroad aclb 2016 trd sport stolen 2019 TRDORSB
  17. Jan 7, 2019 at 6:04 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    Dang thats beefy. Maybe I'll get one of my welder buddies to fab something up like that for me. I don't have the skills required but I'd prefer that over rather that than just a hook.
    Manfred and llamasmurf[QUOTED] like this.
  18. Jan 7, 2019 at 6:15 AM
    Joe23
    Nice part of that is if you get a hitch winch cradle you can put winch on and switch from front to back
  19. Jan 7, 2019 at 6:16 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    That’s actually a great idea, idk why I didn’t think about that
    Joe23[QUOTED], Manfred and llamasmurf like this.
  20. Jan 7, 2019 at 6:20 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    Well since my diff lock actuator took a poo I was gonna go to a parts yard in Belleville but I called and they said the part was the front actuator for 4x4, despite what the website said...:mad: Couldn’t find another one close.
    Swallowed my pride and bought a new AISIN OEM spec SAT-008 one off eBay :( cost me 500 bones and I have to go over the border to get it from my P.O.
    Hopefully no import charges ;) and hopefully my fluid doesn’t leak out of the shaft hole that the shaft is still rust welded into for the next week.
    Manfred likes this.
