Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jan 27, 2019 at 9:40 PM
    Sloweburn
    Sloweburn Well-Known Member
    Woodstock, ON
    19 Tacoma TRD Sport Premium
    3" lift. $10K in TRD options. Richie's semi-hidden bumper, and soon his Elka suspension
    just whatever snow accumulates in there and use 4WD when needed... oh, and my back bumper is about 200lbs... throw my back out every time I take it off, so I don't do that anymore...
  2. Jan 27, 2019 at 9:43 PM
    Sloweburn
    Woodstock, ON
    Take it back and yell at them - that's bullshit!
  3. Jan 27, 2019 at 10:07 PM
    ToyotaRacingDev
    ToyotaRacingDev 425,000km
    London, Ontario
    2008 Tacoma TRD Sport
    Had it done back in December
  4. Jan 28, 2019 at 2:33 AM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Find another shop.
  5. Jan 28, 2019 at 3:24 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    The alignment shop you're going to is sloppy then.
    But you can adjust. Plenty of links online and videos on how to.
    It's all in the tie rods just need to be careful you don't do too much.
    Basically mark where they are and adjust to each side.
    If you have a total toe of .40 degree say, you still need to maintain that but right now it might be too much to one side.
    When I had a similar issue I went back as it was unacceptable how much the steering was off for me.
    Once I went back and told them I heard them say ' 1/4 turn to the left ' to the tech . Could see their markings after howb they went to adjust it 1/4 turn difference on either side.
    But they didn't think it could be possible and they put it back on the machine and realized in the 24 hours I had it the alignment somehow came out already. So they re did the whole alignment and it was fine
  6. Jan 28, 2019 at 3:51 AM
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    More snow today :bananadance:
    Shveet and Joe23 like this.
  7. Jan 28, 2019 at 5:32 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Tough spot. The shop may refuse to accept fault and blame potholes or off-roading for the "drift", in which case take it to another shop or try to adjust it yourself. Post the shop's name and addres here so we know to avoid it.
    You need decent tools to adjust the tie rod ends yourself, "parrot" jaw vise grips and/or a metric line wrench to avoid rounding off the wrench flats. Like Joe23 said, mark off the starting spot with a paint marker and make adjustments in 1/4-turn increments. Figure out the correct adjustment direction beforehand. :)
  8. Jan 28, 2019 at 5:33 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I put 2 x '60lbs' sand bags, but they are frozen solid now and id say weight much more that the 60lbs of sand I put in originally.
    If I put it in 4hi every time there is slush or snow id never be in 2wd. I find I get the greatest added traction from the 2 bags positioned over the rear axle between the wheel wells.
  9. Jan 28, 2019 at 5:40 AM
    ToyotaRacingDev
    London, Ontario
    It was Kal Tire London on Wharncliffe. They actually fucked up the first time and it was 20 degrees off so I took it back and the second time was still not great. Cost $100 for a problem, it was better before
  10. Jan 28, 2019 at 9:23 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    I took my truck to kal tire in waterloo specifically for my steerig wheel being off, was probably out 20° and now its within 5° but not perfect. Too much of a hassel to get my truck down there during work hours so i just left it
  11. Jan 28, 2019 at 9:37 AM
    tgelata
    Probably at work.
    sorgon82 likes this.
  12. Jan 28, 2019 at 9:44 AM
    Zulupapa
    Zulupapa Bah-Weep-Gragnah Weep Ni Ni Bong
    Waterloo Region Canada
    2017 Tacoma TRD Sport Inferno
    I really need to clean out my garage so next winter I can do the same.
    Bastardos!! I want to play in the snow too! damnit :D
    Did you tell the Kal Tire waterloo guys that it was still off?
  13. Jan 28, 2019 at 9:46 AM
    Zulupapa
  14. Jan 28, 2019 at 9:55 AM
    tgelata
    Probably at work.
    Nah its within 5° and i already knew it was going to need another alignment anyways when i go to 886’s after i put a bumper on
    Zulupapa[QUOTED] likes this.
  15. Jan 28, 2019 at 10:00 AM
    Zulupapa
    Just looking at the backroad map that @tacoma16 posted. This section is literally around the corner from me.
    The Yellow highlight going from Wilmot Line to Josephsburg Doesn't exist unless it is supposed to overlap Berlett's Road that is parallel to that stretch??
    EDIT... So I started wandering around the map and found this near Perth Line...
    you'll note river a couple of crossings on the Ninth (looks like only two properties on the GIS) Imagery is 2016.
    tacoma16[OP] and Taco-Bell like this.
  16. Jan 28, 2019 at 10:47 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Joe23, Tridet167 and Therby like this.
  17. Jan 28, 2019 at 11:18 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    ip66 is water blasted at fire hydrant 100psi from all angles
    ip67 is submerged in 1 metre of water for 1/2 hour under pressure
    ip68 is submerged in greater than 1 metre of water for greater than 1/2 hour as specified by the tester.
    So for water crossings that we do IP66 is plenty. The speed ratio is another thing, but we aren't racing here lol
  18. Jan 28, 2019 at 11:20 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    You guys are definitely a bad influence..
    I want those Lightforce LEDs
    :anonymous:
  19. Jan 28, 2019 at 12:59 PM
    Tacotim0321
    Tacotim0321 Well-Known Member
    Tim
    Southwestern ontario
    Red 06 access cab trd off road
    Roof top tent 33s on American racing wheels 3 inch lift
    Wife and I were in iceland for a couple weeks last Christmas. Seen a few of those trucks there. Mostly in the north where the roads wash away or are completely impassable in winter. Couldn't talk my wife into getting one for a rental. Ended up with a Suzuki sidekick.
    Shveet, Atlas86, tacoma16[OP] and 3 others like this.
  20. Jan 28, 2019 at 3:37 PM
    Taco-Bell
    Taco-Bell Forestry Student, Tree Hugger, Naturalist
    Ethan
    Thunder Bay, Ontario
    03 F250 6.0
    An unreliable engine
    1 am plowing start tonight :( gonna be a long one
    Tridet167, tgelata and Bocsy44 like this.
