Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Feb 11, 2019 at 7:06 AM
    Taco-Bell
    Taco-Bell Forestry Student, Tree Hugger, Naturalist
    Ethan
    Thunder Bay, Ontario
    03 F250 6.0
    An unreliable engine
    Ah okay so it’s the bolts then. He was making it seem like I would need to get a whole new LCA for each side if it was ceased. I’d be fine with just buying cam bolts and bushings for the ones that are ceased then?
    Hopefully they can get it close enough to spec that I won’t have to do it straight away...
  2. Feb 11, 2019 at 7:32 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    without having pulled it apart, my understanding is the bolts seize to the bushing sleeve since Toyota didn't grease them on assembly. the guys who have had them apart can advise you better on that.
    sounds like most shops will say you need new LCAs cause the bushings are a pain to replace. i am gonna do it myself.
    Taco-Bell likes this.
  3. Feb 11, 2019 at 7:46 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    Thanks for the reply, extremely helpful! I’ve seen the stock Toyota jack used to push out bushings from the LCA. Not sure how they’d be pressed in though, maybe a makeshift press using the jack and the frame of the truck maybe.
    I’ve just gotta look up part numbers now just in case, always a hassle haha.
  4. Feb 11, 2019 at 8:28 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Fuck.... I think I just bought an aluminum Pelfreybilt front bumper.
    llamasmurf, Bocsy44, Norilsk and 4 others like this.
  5. Feb 11, 2019 at 8:30 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I worked out to be cheaper to buy new control arms for me. 124 a pop from rockauto. The amount of labor required for a bushing swap is retarded.
    Norilsk, tacoma16[OP] and Taco-Bell like this.
  6. Feb 11, 2019 at 9:04 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    Wow, that's cheap. Were they dorman?
  7. Feb 11, 2019 at 9:05 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    If they are seized, you'll want to buy cam bolts and a replacement LCA(s). Cam bolts are effectively OEM-only items (Moog/SPC cam bolts are poorly designed and round off easily). You might end up spending more on cam bolts than on the LCA.
    Usually people try to press out the bushings with a vise and sockets. Usually that doesn't work and they end up torching the rubber, cutting the leftover sleeve with a dremel, etc. too much work. And you'd still be spending 50%+ of the money on cam bolts...
    Taco-Bell[QUOTED] likes this.
  8. Feb 11, 2019 at 9:06 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
  9. Feb 11, 2019 at 9:08 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    I read a few sources saying that the cam bolts can be cleaned up and re used if you are able to press them out of the bushing... probably easier to just buy new...
  10. Feb 11, 2019 at 9:09 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    OEM cam bolts are $950.....As mentioned aftermarket sources aren't the greatest, but a whole new arm is better as it comes with everything.
    I went the OEM cam bolt method thinking the "expensive bolts" were maybe $200 a side. I was wrong....Anyways just saying $950 for OEM bolts.
    Joe23 likes this.
  11. Feb 11, 2019 at 9:10 AM
    Jake4848
    Jake4848 Well-Known Member
    Jake
    Petawawa, ON
    2017 Quicksand DCSB TRD Offroad
    6112/5160's,SPC UCA's,3 Leaf AAL, ECGS bushing, Extang Trifecta, 35% Tint, Rear diff breather mod, 285/75r16 K02, Clazzio's, RCI Sliders.
    Can't wait to get out on the new toy. 51604562_2323609664357140_5400771527606009856_n.jpg
  12. Feb 11, 2019 at 9:10 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    :bananadead:
    tacoma16[QUOTED][OP] likes this.
  13. Feb 11, 2019 at 9:10 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    The issue is the bolts become so seized that you won't get them out. At least in our neck of the woods. So when I had my cam tabs reinforced I needed new cams....My truck is a 2010 which is sprayed every year and still it was needed to get new ones.
  14. Feb 11, 2019 at 9:10 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    yup......It was a lovely surprise...
  15. Feb 11, 2019 at 9:11 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    That is absolutely fucked
  16. Feb 11, 2019 at 9:16 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    They're pricey as fuck
    @tacoma16 had to replace his cam bolts . Think they were around $1000.
    I'm really hoping I won't need new ones when my lca are changed
  17. Feb 11, 2019 at 9:17 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Yeah the rabbit hole gets kinda crazy...
    @Joe23 tad late bud....haha
    check out a whole arm replacement if needed. For a 1st gen, just make sure your lower ball joint is good. Failure of those can have a domino affect on other parts. As long as you're getting good alignment numbers and your cam tabs aren't messed.
  18. Feb 11, 2019 at 9:18 AM
    Joe23
    Ya ya. Just saw it now.
    I'm hoping that mine being newer won't be seized yet
  19. Feb 11, 2019 at 9:18 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    My butthole was already lubed but I'm pretty pleased with this assfucking
    Joe23[QUOTED] likes this.
  20. Feb 11, 2019 at 9:19 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Thats not bad at all. I had a sore throat after I bent over......
