Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Feb 14, 2019 at 2:04 PM
    Taco-Bell
    Taco-Bell Forestry Student, Tree Hugger, Naturalist
    Ethan
    Thunder Bay, Ontario
    03 F250 6.0
    An unreliable engine
    Yeah, gonna try to use quite a few layers of bedliner. Gonna prep with the metal etching solution too
    Manfred[QUOTED] likes this.
  2. Feb 14, 2019 at 2:36 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    My dude! If you need an extra set of hands let us know
  3. Feb 14, 2019 at 2:38 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Thanks man appreciate it! I’m gonna try to bang it out quick tomorrow after school. Still not 100% if I want it black or just clear coat the raw... I think black will look better in the long run.
    llamasmurf and Manfred[QUOTED] like this.
  4. Feb 14, 2019 at 2:57 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    If your going to use the bumper and it get scratched, por15 is good and is pretty easy to touch up, but spray paint works really good as well. The metal etch is worth it but use the marine clean to clean everything. Makes the paint process super easy.
    I use to just use the marine clean, metal prep, and spray paint
  5. Feb 14, 2019 at 2:58 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Give me a sec and I’ll check it out.
    Zulupapa[QUOTED] likes this.
  6. Feb 14, 2019 at 3:11 PM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    thanks ! Ill let ya know
  7. Feb 14, 2019 at 3:14 PM
    tgelata
    Probably at work.
    Welp, the bruce got hammered with snow again apparently so im headed there instead of huntsville :bananadance:
  8. Feb 14, 2019 at 3:26 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Always wanted to know how those fit in, now may be looking into buying one :anonymous:
    tacoma16[OP] likes this.
  9. Feb 14, 2019 at 3:39 PM
    tgelata
    Probably at work.
    Heres a better way of doing it.
    I didnt feel like digging it out for a 1 way trip
  10. Feb 14, 2019 at 3:45 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Yeah I think I’m gonna do the por15 and then to keep it UV protected use the bedliner in a few layers. Can you just pick up the marine cleaner from CT?
    tacoma16[QUOTED][OP] likes this.
  11. Feb 14, 2019 at 3:46 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
  12. Feb 14, 2019 at 3:47 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I went to a speciality shop. Could grab it on Amazon most likely. Any degreaser cleaner like the wd40 degreaser should work
  13. Feb 14, 2019 at 3:57 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Ah okay I have the POR15 brand degreaser so that should be strong enough! I was gonna wash it down with that anyway, it’s got machine oil on it so it didn’t rust shipping.
  14. Feb 14, 2019 at 3:58 PM
    Canadian Joe
    Canadian Joe Well-Known Member
    Joe
    Ontario
    2016 Tacoma trd off-road ,access cab,MT
    SCS rims 285's OME lift
    I normally use acetone ,,,
  15. Feb 14, 2019 at 3:59 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Depends on the size of the sled. Some from skis are wider than our wheel wells
    Norilsk[QUOTED] likes this.
  16. Feb 14, 2019 at 4:45 PM
    tgelata
    Probably at work.
    Mines wider, i currently have the sides of the skis on the wheel wells
    The real trick is keeping the weight off the tailgate
  17. Feb 14, 2019 at 5:05 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Just do this
    Norilsk[QUOTED], Bocsy44 and tgelata like this.
  18. Feb 14, 2019 at 5:05 PM
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    Take the time to do it lol. I also have a needle scaler to take off rust and paint layers. Helped when I applied it to my frame many moons ago
  19. Feb 14, 2019 at 5:17 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Should be fine cause it’s already raw. I’m gonna take the time to do the prep
  20. Feb 14, 2019 at 5:30 PM
    weight
    weight Well-Known Member
    Kevin
    Ontario, Canada
    2018 Manual Double Cab Short Box
    I bought marine clean, metal prep and Por15 from Canadian Tire.
