Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Mar 3, 2019 at 12:43 PM
    Taco-Bell
    Taco-Bell Forestry Student, Tree Hugger, Naturalist
    Ethan
    Thunder Bay, Ontario
    03 F250 6.0
    An unreliable engine
    I am skeptical about legitimacy too but don’t wanna chance it since my truck came stock with non synthetic. And I honestly have no clue how long the trans has gone without a change so I don’t know if I want to risk it
    TeecoTaco and Bocsy44[QUOTED] like this.
  2. Mar 3, 2019 at 12:45 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I had read differently on here. Who knows though. If your stuff hasn’t blown up I’m sure it’s fine lol.
    Atlas86 and Bocsy44[QUOTED] like this.
  3. Mar 3, 2019 at 12:45 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Just do a drain and fill. Not a flush.
  4. Mar 3, 2019 at 12:47 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    i have no idea what was in mine before cuz i got it used at 210k. i went with syn engine oil at first oil change, no leaks. went syn in the diffs about a year ago, no leaks. Trans... no idea when mine was done, you can do a full flush without issues if you do it a certain way. my buddy's work uses a bladder system, not a pump, so it just uses operating pressure to push new fluid into the system and it removes the old fluid. which in my opinion is the best way/safest way. i personally think the problems come when someone or a shop uses a pump method that might flow at a higher rate then the factory transmission pump, loosening up debris.
  5. Mar 3, 2019 at 12:47 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    i read the bottle and made sure lol it was their MAX GEAR or some shit like that
    tacoma16[QUOTED][OP] likes this.
  6. Mar 3, 2019 at 12:49 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I was trying to find the thread but I had read a while back that some guy used royal purple during a gear break in on a regear. Blew up two diffs. But who knows what that person did. For me it was cheaper to get the Lucas or amsoil lol.
  7. Mar 3, 2019 at 12:50 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    guy probably did something stupid. also, they recommend Dyno and a thicker oil when doing the break in. ECGS recommends dino in all their diffs and just change more frequently.
    Atlas86 and Taco-Bell like this.
  8. Mar 3, 2019 at 1:00 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Yeah I was going to do the method where you drain the pan, fill the pan exact amount you drained, remove the ATF radiator inlet and start the engine, remove a quart, stop the engine, add a quart, then repeat turning on, drain, turn off, add till you’ve let out about 12 quarts I think it was.
    I’ll just see how my fluid looks and act accordingly to that.
  9. Mar 3, 2019 at 1:01 PM
    Atlas86
    Atlas86 Well-Known Member
    Ontario
    2012 Tacoma TRD Sport DCLB
    Damn... Yesterday was a mess. Lol
    Bocsy44[QUOTED] likes this.
  10. Mar 3, 2019 at 1:02 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    yeah it seems like a pretty full proof method. would be a lot easier with two people, so one person can watch how much fluid is coming out and the other can sit in the truck and shut off the engine in time to make sure you don't dry out the pump
    Taco-Bell[QUOTED] likes this.
  11. Mar 3, 2019 at 1:07 PM
    Atlas86
    Ontario
    You can pay $10 and get the amsoil membership. Pay less for their products, worth it if you order enough
  12. Mar 3, 2019 at 1:09 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Yah I’d probably do it with a buddy to relieve frustration. Wrenching alone blows sometimes.
  13. Mar 3, 2019 at 1:18 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I bought a case of 75-90 a really long time ago. Needless to say I am still trying to get through it.
    I do my oil changes every 5k km so I usually just get what ever synthetic that’s on sale.
    Atlas86[QUOTED] likes this.
  14. Mar 3, 2019 at 1:30 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Dood, the numero uno thing you want to prevent and prescribe for...let me type that in English, with affect because this is that important...The NUMBER ONE thing you want to prevent RIGHT NOW is the strawberry milkshake. I've had one on a 97 t4r, which is essentially the same drivetrain as you. Trust me, it will ruin your day. It will ruin your truck. It will ruin your childhood memories. You made mention earlier (likely inadvertently) about the tranny cooler. Do it now, do it first, borrow the 2 hundy if you have to or do your best meth head impression and blow a guy to get the brownies for the independent tranny cooler funds. Get the two cooling systems independent of each other.
    If you do not, and you get a strawberry milkshake in the future, you will recall this advice...and you will reconcile to yourself..."hmm, I shoulda listened to that old fvck on TW, and blown that transsexual for that 2 hundy"
    It's THAT important
  15. Mar 3, 2019 at 1:34 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Got a rec on which cooler to get?
    TeecoTaco[QUOTED] likes this.
  16. Mar 3, 2019 at 1:37 PM
    TeecoTaco
    SW Ontario
    Yup, any one. It will be a brand name and it will do. It's snowing and I don't feel like going out to look under the hood of my 99 Runner. Just get one. It's the first thing I did to it before even plating it.
  17. Mar 3, 2019 at 1:39 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Read multiple sources already saying that the Tacoma’s don’t get the pink milkshake like the t4rs do. I’ll be adding one but not in a hurry to do it, I’m also going to replace my radiator and doing a coolant flush cause I’m sure there’s some nice gunk in it.
  18. Mar 3, 2019 at 1:44 PM
    TeecoTaco
    SW Ontario
    Hmm, I'm not sure what kind of magikal aura surrounds the 3.4L AT in a Tacoma that utilizes the same cooling strategy (plumbed thru the radiator) than the same 3.4L AT radiator cooled tranny of the 3rd gen T4R lacks...but that is some awesome shit that if you could harness and bottle, you'd make a dollar.
  19. Mar 3, 2019 at 1:44 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    damn, im craving a strawberry milkshake now
  20. Mar 3, 2019 at 1:47 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Not sure, just what I’ve read from a couple of posts here. Will do the upgrades just not in a rush right now
