Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Mar 14, 2019 at 8:11 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I extended mine up into the driver side bed box, with my ARB fitting for compressor action.
    Mine looks rusty, but it is not a Toyota part. I installed a larger breather from a piece of drilling equipment. It just has a bit of surface rust I will be cleaning up in a few weeks.
    Lots of guys relocated them up behind the rear tail light. I had to be able to look at mine, just my crazyness. :cookiemonster:
    Tridet167, Atlas86, Zulupapa and 2 others like this.
  2. Mar 14, 2019 at 8:39 AM
    Taco-Bell
    Taco-Bell Forestry Student, Tree Hugger, Naturalist
    Ethan
    Thunder Bay, Ontario
    03 F250 6.0
    An unreliable engine
    Yes I just ordered 2 fittings from toyotapartsdirect.ca and am going to run it up to the gas cap housing with 5/16” fuel line with an in-line fuel system style filter to make certain no gunk gets in there. Just worried about the stupid seals. It’s always something with this truck haha
    llamasmurf likes this.
  3. Mar 14, 2019 at 8:42 AM
    llamasmurf
    Wes
    Northern Ontario
    I was advised against the gas cap placement, as you can hit each time you gas up and break the little stock breather easily.
  4. Mar 14, 2019 at 8:44 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    Huh, didn’t know that. There’s quite a bit of room in there so I can see if there’s space to put it out of the way. If not I’ll try not to be reckless with the nozzle. I don’t know where else I could put it because I don’t want it in the bed and don’t want to route it up into the engine bay. Worst comes to worst it’s. $6 fitting and if I break it I just replace it.
  5. Mar 14, 2019 at 8:47 AM
    llamasmurf
    Wes
    Northern Ontario
    I am not sure on 1st gen's how your rear tail light is mounted. If you remove it there should be holes already for the wires, can run the breather line in the same holes. That is another common spot on 2nd gens.
    *Edit*
    You wont know the breather is broken, until you blow your seals again. :notsure:
    Taco-Bell[QUOTED] likes this.
  6. Mar 14, 2019 at 8:49 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    Where would you run it from there though? Just behind the tail light?
    llamasmurf[QUOTED] likes this.
  7. Mar 14, 2019 at 8:49 AM
    llamasmurf
    Wes
    Northern Ontario
  8. Mar 14, 2019 at 8:52 AM
    Zulupapa
    Zulupapa Bah-Weep-Gragnah Weep Ni Ni Bong
    Waterloo Region Canada
    2017 Tacoma TRD Sport Inferno
    So getting the Midland MXT series running at 15W would be bad... damnit.
    Guess it's the handhelds still for me..
  9. Mar 14, 2019 at 8:57 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    Atlas86 and llamasmurf[QUOTED] like this.
  10. Mar 14, 2019 at 9:00 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    What are the odds that it stops leaking after I swap the breather? :rolleyes:
    Really don’t want to pull the axle...
  11. Mar 14, 2019 at 9:23 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    lol, 0, your seals are done. It's easier to do the 1st gen than 2nd, 3rd gen if I remember correctly.
    Joe23 and llamasmurf like this.
  12. Mar 14, 2019 at 9:25 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    Fuck this sucks lol
    Manfred likes this.
  13. Mar 14, 2019 at 9:33 AM
    Norilsk
    Eugene
    The most annoying part is to re-assemble drum brakes, everything else is straightforward. Get slide hammer for less struggle when pulling shaft.
  14. Mar 14, 2019 at 9:59 AM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    Sloweburn, Joe23, tgelata and 3 others like this.
  15. Mar 14, 2019 at 12:56 PM
    Taco-Bell
    Ethan
    03 F250 6.0
    Lubrico is coming in clutch. I can take my truck in for a diagnosis on the axle seals to my mechanic and they can check it out and any costs after will be billed against my warranty. Only gonna do that if I need to do the bearings too though. I can do the seals myself.
    Manfred and llamasmurf like this.
  16. Mar 14, 2019 at 2:02 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Taco-Bell likes this.
  17. Mar 14, 2019 at 2:04 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Tridet167, Joe23, llamasmurf and 2 others like this.
  18. Mar 14, 2019 at 2:08 PM
    Norilsk
    Eugene
    :facepalm:
    What makes anyone to stop to make another account?
    llamasmurf and Therby like this.
  19. Mar 14, 2019 at 2:08 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Alight boys, so I’m doing an oil change and I got the wrench you need amd I’m reefing on this thing and it won’t budge at all. Any suggestions?
    TeecoTaco likes this.
  20. Mar 14, 2019 at 2:08 PM
    TeecoTaco
    SW Ontario
    Ip address ... would need VPN
