Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Mar 14, 2019 at 2:42 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Doing diffs and tcase and tranny shortly, but oil pan I have the crush washer replaced...its cheap part
    Taco-Bell and Joe23[QUOTED] like this.
  2. Mar 14, 2019 at 2:43 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    get a strap wrench on it and get a new filter.
    do you still have the plastic one?
  3. Mar 14, 2019 at 2:43 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    tacoma16[OP] and Joe23[QUOTED] like this.
  4. Mar 14, 2019 at 2:44 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Guilty! :anonymous: But that is part of "We fucked up when released TuRD gen, let us fix this crap a bit"
    I replaced all mine, they are all together less than $10
    RIP
  5. Mar 14, 2019 at 2:44 PM
    Joe23
    ya figure the same.
    may as well just replace the crush washers. cheaper than dealing with a leak
  6. Mar 14, 2019 at 2:45 PM
    Joe23
    got part # for them?
    need to get them
  7. Mar 14, 2019 at 2:47 PM
    Norilsk
    Eugene
    Torque specs:
    Rear diff drain plug - 36 lb-ft (24mm or 15/16")
    Rear diff fill plug - 36 lb-ft (24mm or 15/16")
    Gaskets:
    Rear drain plug gasket - Toyota part # 12157-10010
    Rear fill plug gasket - Toyota part # 12157-10010
    Rear Diff Oil - 4.0 qts (3.8L) of LT 75W-85 GL-5, Toyota part #08885-02506
    12157-10010 -1 gasket for front diff
    90430-24003 - 1 gasket for front diff
    08885-02506 - 2 liters in total of LT 75W-85 GL-5
    90430-A0003 - 2 gaskets for t-case
    08885-81080 or 08885-81081 1 liter of 75W LF
  8. Mar 14, 2019 at 2:48 PM
    TeecoTaco
    SW Ontario
    Complete this with the MT parts and specs pls...dankje
    Canadian Joe likes this.
  9. Mar 14, 2019 at 2:50 PM
    Norilsk
    Eugene
    add 2.5 liters of Redline MT-90 75W90 GL4 and the list is complete lol
  10. Mar 14, 2019 at 2:52 PM
    Norilsk
    Eugene
  11. Mar 14, 2019 at 3:01 PM
    TeecoTaco
    SW Ontario
    Norilsk[QUOTED] likes this.
  12. Mar 14, 2019 at 3:04 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Worst case I’ll come with a welder, and a old socket. That bastard will come off!
    Make sure you are going the right way. If your wrench has a left and right on it, use that to make sure.....
  13. Mar 14, 2019 at 3:08 PM
    Norilsk
    Eugene
    Or I can come with a hammer and eveything will come off.
  14. Mar 14, 2019 at 3:09 PM
    TeecoTaco
    SW Ontario
    Soak it in vodka, and your clothes will come off
  15. Mar 14, 2019 at 3:10 PM
    Joe23
    Oil ones as well? The drain gasket
  16. Mar 14, 2019 at 3:12 PM
    Norilsk
    Eugene
    There are 6 gaskets,
    2 for front, 2 for rear and 2 for t-case. Each drain and fill has gasket. They all looked new when I replaced them. But what’s another $10 when you just spent over $120 in gear oil lol
  17. Mar 14, 2019 at 3:13 PM
    Joe23
    I mean the engine oil drain gasket you thick cunt
    Tacotj, Bocsy44 and TeecoTaco like this.
  18. Mar 14, 2019 at 3:18 PM
    Norilsk
    Eugene
    CUNT you are sir!
    That gasket comes with your oil filter when you buy it, cunt.
    Tacotj and TeecoTaco like this.
  19. Mar 14, 2019 at 3:19 PM
    Joe23
    That's for the filter one. I mean the crush washer on the drain plug
  20. Mar 14, 2019 at 3:21 PM
    Taco-Bell
    Taco-Bell Forestry Student, Tree Hugger, Naturalist
    Ethan
    Thunder Bay, Ontario
    03 F250 6.0
    An unreliable engine
    I ordered all new for mine. Cheap insurance against leaks.
    llamasmurf and Joe23[QUOTED] like this.
