Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Mar 16, 2019 at 5:17 AM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I feel the same way and that's why it makes things confusing reading all those pages. So far it looks like everyone has different outcomes from the same setting. That makes it hard to come to a decision where to put the notch.
    Right now it's notch 4 or 5 and then make an adjustment if needed. I still have to add sliders into the mix.
    They definitely will give a better ride over stock, just a matter of getting the correct setting for your truck.
  2. Mar 16, 2019 at 5:19 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I think those are the ones I've heard seize up as well . Like you can't get them apart later without damaging the clip
  3. Mar 16, 2019 at 5:21 AM
    Joe23
    Mine have been adjusted no problem .
    But I drench my coilover with fluid film . And the shock body is mostly all aluminum
    Bocsy44[QUOTED] and Tridet167 like this.
  4. Mar 16, 2019 at 5:36 AM
    Tridet167
    Tony
    Toronto, Canada
    Gotta keep everything greased or apply a clear coat coating on the thing.
    Bocsy44, Joe23[QUOTED] and llamasmurf like this.
  5. Mar 16, 2019 at 7:09 AM
    Atlas86
    Atlas86 Well-Known Member
    Ontario
    2012 Tacoma TRD Sport DCLB
    I wonder if I should forget about the 5100s and go straight to 6112s.
    pete37, Bocsy44 and llamasmurf like this.
  6. Mar 16, 2019 at 7:13 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I have the 5100's currently. I am looking down the road for when I want to upgrade again.
    My truck rides great with 5100's and OME 885's. I am pushing the front end weight a bit on the 885's with the 2" receiver up front., but its ok for now. If I add anymore weight to the front I will have to upgrade springs. Like 2nd battery setup :drool:
    Atlas86[QUOTED] and Tridet167 like this.
  7. Mar 16, 2019 at 7:28 AM
    Joe23
    Go for broke and just get Fox or bp51
  8. Mar 16, 2019 at 7:30 AM
    llamasmurf
    Wes
    Northern Ontario
    Yea I am looking at all the options as well for next time, the bp51's are sexy!
    One more year and the truck is paid for, then things can really start o_O
    Bocsy44, Tridet167 and Joe23[QUOTED] like this.
  9. Mar 16, 2019 at 7:34 AM
    Joe23
    I'm still trying to understand how you guys aren't all sagging being on 600lbs springs or less.
    I'm on 600s and sag with all the armor and batteries
    llamasmurf[QUOTED] likes this.
  10. Mar 16, 2019 at 7:37 AM
    llamasmurf
    Wes
    Northern Ontario
    That battery is heavy up front. My front end is not exactly as high as it was before the install of the receiver from @Norilsk. I wouldnt call it sagging though. Sagging was how my truck looked before I upgraded the suspension. Low Rider.
    Hmmm weather network is saying spring is in the air, so tempted to go up to the shop after I finish work today and change to the Coopers :cookiemonster:
    Tridet167 likes this.
  11. Mar 16, 2019 at 8:04 AM
    Tridet167
    Tony
    Toronto, Canada
    Wait until you add the bumper and watch that front end go all the way down.
  12. Mar 16, 2019 at 8:08 AM
    Tridet167
    Tony
    Toronto, Canada
    Would a 650 spring on a lower setting be similar to a 600 spring on a higher setting? Thinking that a 650 spring is stiffer so wouldn't it act similar to a compressed 600 spring? A 600 spring being softer might actually accommdate the compression better for a better ride. Might be the reason people on notch 5 say ride isn't bad.
    Just thinking out loud here.
    Bocsy44 and tacoma16[OP] like this.
  13. Mar 16, 2019 at 8:23 AM
    Joe23
    I'll be on 700s at that point though
    Tridet167[QUOTED] likes this.
  14. Mar 16, 2019 at 8:29 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    When you compress the spring I becomes stiffer as you are also loosing travel. So with your heavier 650 spring you shouldn’t have to crank it up thus being a softer ride. In theory.
    Joe23 and Tridet167[QUOTED] like this.
  15. Mar 16, 2019 at 8:33 AM
    Tridet167
    Tony
    Toronto, Canada
    Do we know the spring rate of a spring say at every inch of travel? Like how much force needed to push it down.
    tacoma16[QUOTED][OP] likes this.
  16. Mar 16, 2019 at 8:35 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’m not to sure. I don’t believe the rate changes but the down travel or something to that extent is limited...so instead of the spring sagging it allows it to be leveled out. I may be wrong as I haven’t looked at this for a while.
    I just remember that cranking or adjusting the coilover will limit travel. Just don’t remember up or down.
  17. Mar 16, 2019 at 8:51 AM
    Tridet167
    Tony
    Toronto, Canada
    From what I'm reading I guess the actual spring weight is the the force needed to push it down 1 inch. So 650 will require 650lbs to push it down 1 inch. That sound correct?
    I'm being a bit scientific here, trying to get a grasp and understanding of all this spring shit.
  18. Mar 16, 2019 at 8:54 AM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    I just find it hard to believe that there aren't any sacrifices being made on the 4th or 5th notch and a 610 spring hahaha either in ride quality or travel for that matter.
  19. Mar 16, 2019 at 9:12 AM
    Tridet167
    Tony
    Toronto, Canada
    You're right. That's why I started thinking that maybe because 610 springs end up requiring less force to compress than a 650, that perhaps the higher notch isn't that harsh. From #3 to #5 is approx. 1 inch difference. and that doesn't seem like a lot for a spring that size.
    Bocsy44[QUOTED] likes this.
  20. Mar 16, 2019 at 9:13 AM
    Atlas86
    Ontario
    Plus you have the steel skid too right?
    I have 5100s.. Haven't installed them yet, waiting on getting springs . But 6112s come with springs..hmm.
    Problem is I'm already broke haha.
