Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Apr 17, 2019 at 11:50 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Didn't realize bad alignment can cause droop to one side. I also lost about an inch in lift swapping my billies to ome. I figured I could remove my 1/2" spacers once I got the 886 in but apperantly not. I'll be replacing one of the 1/2" spacers with a 1/4" on the drivers side. Hoping it'll help.
  2. Apr 17, 2019 at 1:03 PM
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    I might have a spare 1/4" top plate spacer for you.
    but I'm pretty sure the ome have a driver side lean sleeve the sits on the perch because of the gas tank on that side. Maybe your missing that
    Thyces[QUOTED] likes this.
  3. Apr 17, 2019 at 1:09 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thanks bud. I have a 1/4 inch spacer already. I did not know about the ome lean spacer. Any pics or a link to the lean sleeve?
    This one?
  4. Apr 17, 2019 at 1:21 PM
    sorgon82
    Ont. Canada
    Ya i think thats it. Without it i dont see why you cant just use the 1/4" top spacer.
    My lca was still pretty snug even when it was disconnected and bolts loosened off. If that helps
  5. Apr 17, 2019 at 1:30 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I'll check my bushings. Thanks. I'll be using the 1/2" for the drivers side and the 1/4 for the passenger.
  6. Apr 17, 2019 at 1:52 PM
    sorgon82
    Ont. Canada
    Thats what I did also but with 887
    My cv angles are borderline
  7. Apr 17, 2019 at 2:15 PM
    Atlas86
    Atlas86 Well-Known Member
    Ontario
    2012 Tacoma TRD Sport DCLB
    On Sunday I picked up a friend from the airport, visiting from BC. On our way to her parents house, she mentioned gas was cheap here. Said it's around $1.50 in BC and they're expecting $2 in the summer.
    Tridet167 likes this.
  8. Apr 17, 2019 at 2:29 PM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    Ahh it rides so much better on 886’s :drool:
    And my steering wheel is straight again:yes:
  9. Apr 17, 2019 at 2:32 PM
    weight
    weight Well-Known Member
    Kevin
    Ontario, Canada
    2018 Manual Double Cab Short Box
    I saw a picture from BC a few days ago with gas at $1.689.
  10. Apr 17, 2019 at 2:40 PM
    Atlas86
    Ontario
    I guess it varies from place to place like here, but that's terrible
  11. Apr 17, 2019 at 3:11 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    I just passed petro canada and it is 1.51....
    Few hours away from @bdbrown neck of woods (he is on the TW banner) lol
  12. Apr 17, 2019 at 3:26 PM
    weight
    Kevin
    Ontario, Canada
    Yeah, with gas prices like that I agree a trip to the LCBO is in order. Just save what you get until you’re done driving for the day.
    Therby, Atlas86 and Norilsk[QUOTED] like this.
  13. Apr 17, 2019 at 3:32 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    I told ya to take the US route via Makinac bridge route.
    Respond to your linked in
    over60 and Norilsk[QUOTED] like this.
  14. Apr 17, 2019 at 3:40 PM
    Norilsk
    Eugene
    I know, will do on the way back some day.
    On a positive side there is absolutely no traffic for miles, easy drive.
    3JOH22A, weight, pete37 and 2 others like this.
  15. Apr 17, 2019 at 3:43 PM
    TeecoTaco
    SW Ontario
    Kinda makes that TSS cruise control a waste eh?
    Tell ya what, every 3 mins or so, slam on your brakes hard. It will suppress your homesickness of driving in peel region
  16. Apr 17, 2019 at 4:44 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Old vs. new. Added a ¼" spacer to get rid of the lean as well, been dying to do that. I ended up about ¾" higher than the back. I'm hoping it settles to even everything out.
  17. Apr 17, 2019 at 4:50 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Keep yer eyes peeled for Moose.... Especially at dusk....thru the nite… and dawn. Have a safe ride ..:thumbsup:
    bdbrown, Atlas86, weight and 3 others like this.
  18. Apr 17, 2019 at 5:08 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You must be the only one with CV shafts inclined the other way lol, because of the drop-bracket lift.
  19. Apr 17, 2019 at 5:20 PM
    Tridet167
    Tony
    Toronto, Canada
    They been perfectly horizontal for a while when I added the weight with the bumper/skids/winch and now tilt down a bit with the new shocks.
  20. Apr 17, 2019 at 5:52 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    @TRDCal welcome to the ontario group :taco:
    Shveet, tgelata and Atlas86 like this.
