Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. May 28, 2019 at 3:45 AM
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    Something like that, the ultimate dana 44 front would probably be good enough for me. But we will see when the time comes. Got a few things to do before then
    I agree and have learned the buy once cry once method though!
    Edit: i like how you know these things about jeeps, join the jeep side!
    Had a few things i wanted for the jeep but now i took some body damage and bashed in the rocker last trip. Need some armour skin to fix that
  2. May 28, 2019 at 5:13 AM
    pete37
    pete37 Well-Known Member
    peter
    Toronto Canada
    2008 trd offroad aclb 2016 trd sport stolen 2019 TRDORSB
    come on guys need some business :rofl:
  3. May 28, 2019 at 6:45 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Add alignment to the list of things not to do at Noyzboyz. :frusty: Apparently having the upper ball joint hit the coil at full droop is acceptable to them. Got an Amazon camber gauge on order. Won't be going back and wasting half a day for them to screw things up further.
    Joe23[QUOTED] and llamasmurf like this.
  4. May 28, 2019 at 6:59 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Day 2 of driving without sway bar seems ok with the 700 lb coils. Tried a double lane-change maneuver (aka moose test) at 40 kph and didn't lift a wheel. Will try incrementally higher speeds up to 70 kph, which is what the European tests are done at.
  5. May 28, 2019 at 7:02 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    :rofl:Yeah, if I was driving auto Turd gen I would try to total it as well for manual...:anonymous:
    Therby likes this.
  6. May 28, 2019 at 8:14 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Got to work and was wondering why my truck felt like I had destroyed the alignment. It was heavily steering to the passenger side.
    Apparently I got something wedged in my rim, might be just dirt. Dont know yet.
    It will sit at 10.5 PSI, anything over it starts hissing and leaking from the bead at 1 spot.
    Switched to my full size spare at work, nice having a shop to pull into to change the tire. Instead of doing it outside in the rain.
    Guess I have to figure out wtf is wrong tonight.
    Sloweburn, tacoma16[OP] and pete37 like this.
  7. May 28, 2019 at 9:59 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Deflate the tore and use a hilift to break the bead on one side so you can clean it out. That is assuming you have done the soap test and have confirmed it is coming from the bead seat on the rim and not a puncture.
    llamasmurf[QUOTED] likes this.
  8. May 28, 2019 at 10:26 AM
    llamasmurf
    Wes
    Northern Ontario
    I am pretty confident a rock is wedged in the bead, I will check it tonight.
    Better inspection after wheeling is needed if I am stepping up the difficulty it seems. :facepalm:
    This is in the rim on my drivers side front, holding air but I need to get that out. :anonymous:
    The one that is leaking looks exactly the same you just cant see the rock it is farther under the bead. Has the scrape exactly like this one.
    Sloweburn, Tridet167, Shveet and 2 others like this.
  9. May 28, 2019 at 10:45 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i didn't even know that was possible...
  10. May 28, 2019 at 10:56 AM
    llamasmurf
    Wes
    Northern Ontario
    You and me both bud.
    When you air down to 15 PSI front 13 PSI rear. You learn things. :bananadead:
    Shveet[QUOTED] likes this.
  11. May 28, 2019 at 10:57 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    have had sticks and stones stuck in mine. No broken bones though....:anonymous:
    Sometimes mud and a bunch of junk can get squeezed into a bead. Its pretty impressive. Never had issues with the tire deflating. Did have a blown bead though...
    Thyces, Sloweburn, Bocsy44 and 2 others like this.
  12. May 28, 2019 at 1:14 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I went from stock 540 lbs to 610 lbs coils and the handling without the swaybar is a huge improvement. It's night and day. With your 700 lbs, it should be fine.
    Thyces and llamasmurf like this.
  13. May 28, 2019 at 4:26 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    I've seen branches/sticks jammed into the bead but never a stone that far in, Lol and you did it twice in one day!
    Quick! buy a lottery ticket and a case of beer.
    llamasmurf[QUOTED] and Norilsk like this.
  14. May 28, 2019 at 5:48 PM
    pete37
    peter
    Toronto Canada
  15. May 28, 2019 at 5:52 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
  16. May 28, 2019 at 5:52 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    Back road map book discount codes
  17. May 28, 2019 at 7:09 PM
    llamasmurf
    Wes
    Northern Ontario
    This is the best use I have come up with so far for the stock jack, perfect reason it stays in the truck.:rolleyes:
    Did this to both the front tires, fixed the one that would not hold air and removed the rock that wanted to deflate my tire.
    Didnt even have to break the bead on either :thumbsup:
  18. May 28, 2019 at 9:23 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Messaged arb asking them for a couple sticker scahse I didn’t get any with my coils, the girl there sent me a bunch. I got some that say arb locker on them if anyone wants one?
    Shveet, llamasmurf and pete37 like this.
  19. May 29, 2019 at 5:54 AM
    llamasmurf
    Wes
    Northern Ontario
    All-Pro did the same for me, when I ordered my brake lines I put in the note 'Hook an All-Pro bro up with some sweet stickers plz'
    I got 2 :cookiemonster:
    Bocsy44 and Shveet like this.
  20. May 29, 2019 at 5:57 AM
    Canadianguy91
    Sean
    2016 Limited
    Haha awesome dude! It’s good the companies will actually do that like hey free advertising
