Ontario Etest
Discussion in 'Canada' started by grant99, Jan 1, 2012.
  1. Jan 1, 2012 at 3:44 PM
    grant99
    grant99 [OP] Well-Known Member
    London, ON
    05 4DR TRD Sport 6SPD
    Just curious if anyone from Ontario that has to deal with etests has headers, (long or short) that has changed/deleted any number of cats and if they have had any problems passing an etest?!
    I'm contemplating headers with my exhaust upgrade and looking for info on what's going to cause issues. I'm going to run hi flow cats, but not sure how hard these trucks are pass
  2. Jan 3, 2012 at 5:28 PM
    grant99
    London, ON
    No one in Ontario with a modified exhaust/cats?
  3. Jan 4, 2012 at 6:15 PM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    Grant , if you check the web site of sontt, their are a couple of guys that had changed the exhaust manifolds on 2nd gens. Alex was one and i believe Mike was the other. Mike is on here as Gylar and i am not sure of Alex's user name. You could try them.
    Cheers
  4. Jan 5, 2012 at 6:55 AM
    Gatorstaco
    Gatorstaco Well-Known Member
    ontario
    07 X-Runner
    Cold air with scoop, JBA exhaust, all AMS oil, tonneau cover, hitch, extra LED light(back). Scan gauge II. Sirius radio
    I have the DTLT and reposition the O2 with a JBA exhaust. Not sure if it would pass an Etest( gov robbery). They are newer cars on the road from the production line that won't even pass an etest
  5. Jan 5, 2012 at 4:55 PM
    grant99
    London, ON
    Ya don't get me started on etests, but was just curious.
    Do you have the stk Y pipe? How do the long tubes sound? Some of the clips I've heard on YouTube of long tubes sound way to raspy for me
  6. Jan 5, 2012 at 6:58 PM
    Gatorstaco
    ontario
    07 X-Runner
  7. Jan 5, 2012 at 7:14 PM
    grant99
    London, ON
    ya I understand that they bolt right up, but wasn't sure if you chose a different y pipe, how do they sound with the stk y pipe? thats an option I was thinking of also
  8. Feb 8, 2012 at 8:54 PM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    going for my first (since I bought my truck) e-test gov robbery tomorrow...I have a TRD exhaust...hope I pass!...:D
  9. Feb 9, 2012 at 4:55 AM
    grant99
    London, ON
    correct me if I'm wrong, but isn't the TRD exhaust just a "cat back" if so it should have no affect on emissions, just sound
  10. Feb 9, 2012 at 7:00 AM
    tombiosis
    T
    Ottawa Canada
    That's right...should have no effect except the sound.
  11. Mar 2, 2012 at 5:56 AM
    valleyboy
    valleyboy Hillbilly 2nd class
    Otttawa Valley,Ont
    95 Tacoma Ext Cab V6 4wd on it's 3rd set of springs
    Owned since new,2-6volt golfcart batteries in bed hooked up to alternator for camping, Air springs in rear,4-runner bucket seats with a centre console from a ford ranger,brand new cab floor all welded in. manual rear linelock for the brakes, rear diff vent tube extension, rear view mirror map light mod, ignition switch ring light from an mr2
    I'm interested in modifying my 95 v6 w/a turbocharger in the bed,not commonly done but can't/won't spend the $ for a bolt on supercharger.
    Has anyone in Ontario had trouble with Etesting a tacoma with any kind of
    forced induction?
    Edited to add that this will be a "mild" boost system with 7psi max that should stay within the ability of the stock ecu to handle re: timing & fuel flow etc,so a small turbo that spools up at a relatively low rpm.
