Ooof.. another LBJ bites the dust
Discussion in '1st Gen. Tacomas (1995-2004)' started by chrispchicken9, Mar 15, 2021.
  1. Mar 15, 2021 at 7:11 PM
    chrispchicken9
    chrispchicken9 [OP] Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    Spotted LBJ failure in Costco parking lot
    Guy said they were recently replaced too:facepalm:
    epa4wd, jammer, frenchee and 2 others like this.
  2. Mar 15, 2021 at 7:59 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    LBJ? I'm guessing it's a ball joint of some sort...? Also, is the dented dually related to this in any way?
  3. Mar 16, 2021 at 7:39 AM
    chrispchicken9
    Lower ball joint yea
    And no the dually parked there after the Tacoma had its issue
  4. Mar 16, 2021 at 7:39 AM
    chrispchicken9
    They were non Toyota oem LBJs
    The Driver likes this.
  5. Mar 16, 2021 at 7:42 AM
    1997tacomav6
    Denver
    Why people don’t use OEM ball joints to save a few dollars I will never understand
    yotadude520, Nessal, slander and 7 others like this.
  6. Mar 16, 2021 at 8:06 AM
    chrispchicken9
    Thing is many people have a mechanic install them and even is you ask for OEM they give you aftermarket OEM and tell you it’s OEM. They’re not true dealer parts tho
  7. Mar 16, 2021 at 8:17 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If they even changed them. Mechanics these days seem to be really hit or miss. Even if they're not dishonest, sometimes they just miscommunicate internally.
    Wulf likes this.
  8. Mar 16, 2021 at 8:18 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Lyndon Baines Johnson *
    yotadude520, Clucky, Anton338 and 8 others like this.
  9. Mar 16, 2021 at 9:00 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    "Recently" replaced meaning 80k miles ago.
  10. Mar 16, 2021 at 9:17 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Even if true, it’s horrifying that catastrophic failure of suspension components could happen in 80k, regardless of maintenance. Aftermarket LBJs are really scary
    frenchee likes this.
  11. Mar 16, 2021 at 9:22 AM
    jbrandt
    Justin
    ugh, not really. The scariest part is the design, which is Toyota's fault.
    Another scary part is the people who put even OEM ball joints on and figure they can ignore them for 80k miles.
    I'll bet you this guy was rolling around with torn boots and no grease for 10k miles.
    He was in a parking lot. Even cheap Amazon shit doesn't spontaneously explode like that for no reason.
  12. Mar 16, 2021 at 11:36 AM
    Indyteecee
    Indyteecee bad at building Toyotas, good at breaking stuff
    Wyatt
    Utah
    04 Tacoma Double Cab TRD
    this ^ They’re 17-26 year old trucks with not a great ball joint design to begin with. Mine lasted 15k before they started throwing grease. They should be checked regularly. Especially if lifted.
    Abeyancer likes this.
  13. Mar 16, 2021 at 12:18 PM
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    When I replaced mine I went to the dealer and got OEM parts then had them installed at my shop. Best way to know that it's getting done right. Tons of people with these trucks have no clue about replacing these ball joints either. Why would they? If there just an average joe.
    Currygoat likes this.
  14. Mar 16, 2021 at 12:42 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I never buy any vehicle without knowing it's reliability issues. LBJ's came up in my search prior to buying and it was the first thing that I replaced. It's a fairly easy DIY and even easier to check on them.
  15. Mar 16, 2021 at 12:43 PM
    rtwbound
    rtwbound Well-Known Member
    In all fairness, I've had the Toyota Dealership install non-OEM parts on my Tacoma, and when confronted, they said it was because "they were trying to save me money," which is BS because my bill was already fat.
  16. Mar 16, 2021 at 12:55 PM
    jbrandt
    Justin
    They were trying to save THEM money... Bet you they still charged you over $100 each for the LBJs...
  17. Mar 16, 2021 at 7:42 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Shoot. I'm one year in on these $25 advance auto LBJs I got when I needed a quick and cheap replacement for the moment
    1997tacomav6[QUOTED] likes this.
  18. Mar 16, 2021 at 9:52 PM
    1997tacomav6
    Denver
    Well if you don’t go OEM you have a greater chance of spending 1000.00 or more for repairs or totaling
    your truck or 4 runner to save a few dollars
  19. Mar 17, 2021 at 6:50 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    OEM will do this also if you don't actually check on them and just ignore them for 100k+ miles.
  20. Mar 17, 2021 at 7:05 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Just check it regularly, easy enough to do when your already crawling under the truck during an oil change.
    I'm on my second set of Chinese ball joints, I currently don't wheel my truck at all while I'm attempting to restore it but still use it as a DD. No catastrophic failure but only because I check every 3k miles and swap em when required.
