ooooo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zamuhh, Jun 29, 2017.
  1. Jun 30, 2017 at 7:49 AM
    #41
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    OP you have the 2.7L 5-speed correct? How's the truck pull with the extra weight on the wheels?
  2. Jun 30, 2017 at 9:56 AM
    #42
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    OPs truck is a third gen
  3. Jun 30, 2017 at 10:12 AM
    #43
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    so I have an SR5 with mud flaps, probably have to take them off, but I also would like the tires to stick out a little further to fill the wheel wells so I may use some spacers and the OR/Sport I believe has a stock height about 1" higher than the SR/SR5, but this is all good to know, don't do much serious off road just mainly some back roads during winter in pa when up there hunting.
  4. Jun 30, 2017 at 10:20 AM
    #44
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I'm aware of that. Since I'm pretty sure OP and I have the same truck, I wanted to know his opinion of the 4cyl+bigger tires.
  5. Jun 30, 2017 at 10:32 AM
    #45
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Sorry I was confused, is the 4 cylinder a 5 speed? I had wrongly assumed all 3Gs were 6
  6. Jun 30, 2017 at 10:35 AM
    #46
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    The manual 4cyl is 5, auto is 6.
    Jibbs[QUOTED] likes this.
  7. Jun 30, 2017 at 10:54 AM
    #47
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Lol as if this is news. This has been common knowledge since I dunno week 2 after first deliveries back in 2015. I think it was @treehugger who did it first?
    https://www.tacomaworld.com/threads/285-75-r16-results-on-2016-trd-offroad.396218/
    Fact is they will rub in extreme cases even with stock wheels. Put some aftermarket wheels and/or spacers and it's even worse. Is what it is. No one is spreading false information except the OP claiming 285s fit no rub. 285s rub even with a 3" lift if you haven't done a CMC.
    Coot83 likes this.
  8. Jun 30, 2017 at 11:00 AM
    #48
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    FACT. If you don't want to get a CMC, stay with stock tires. Its not the height you are competing with, but the foundation of the frame work that will naturally hit if you cycle your suspension with a bigger tire.
    Doggman[QUOTED] likes this.
  9. Jun 30, 2017 at 11:25 AM
    #49
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I rubbed 285/75/16 tires with TRD offroad wheels against the stock UCA just turning the wheel on perfectly flat ground.
    fast forward to 3" of lift and 1" wheel spacers and i rub on the cab mount occasionally. That's after trimming plastic and removing the mudflaps.
  10. Jun 30, 2017 at 1:21 PM
    #50
    zamuhh
    zamuhh [OP] Member
    Kris
    2017 AC 4x4
    If you know how to find good tire pressure, it's just about the same. Difference is negligible
  11. Jun 30, 2017 at 1:22 PM
    #51
    zamuhh
    zamuhh [OP] Member
    Kris
    2017 AC 4x4
    Lol mine don't rub at all, your truck must be broken. Did you try to turn it off and turn it back on again?. Nice try.
  12. Jun 30, 2017 at 1:24 PM
    #52
    zamuhh
    zamuhh [OP] Member
    Kris
    2017 AC 4x4
    You won't be able to run spacers with these big a tire. I tried. The wheel will rub hard. Without a spacer is perfectly fine.
  13. Jun 30, 2017 at 1:55 PM
    #53
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Thanks, then maybe a size smaller, we will see?
  14. Jun 30, 2017 at 2:02 PM
    #54
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    SR's sit higher and do not have fender flares or mud flaps
  15. Jul 13, 2017 at 3:17 AM
    #55
    KiteGuam
    KiteGuam The favorite!
    Guam
    03 Xtra-Cab 2.7L 4X4
    starting over from scratch
    :rofl::rofl::rofl: y'all are too funny
    Reequinata likes this.
  16. Jul 13, 2017 at 3:45 AM
    #56
    Reequinata
    Reequinata Well-Known Member
    Ree
    All I knows of is chubrubs!
  17. Jul 13, 2017 at 5:08 AM
    #57
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Whew !!! Someone needs a chill pill !
    I would say if anyone just read the opening post and went and grabbed a $1000 plus in tire's based only on that...:) well you get what you deserve !! But honestly maybe some meditation classes ? Yes ? Ommnmmmmm
  18. Jul 13, 2017 at 5:29 AM
    #58
    jLEE028
    jLEE028 Well-Known Member
    MKE
    :worthless:
    2 weeks and still no pics?
  19. Jul 13, 2017 at 5:48 AM
    #59
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Why do I need to take a chill pill bc of my statement... Nothing I said was harsh. All I stated were situations and facts. He made a general statement which isn't true. Sure for his situation it could be possible that absolutely no rubbing occurs but you can't make a claim that 33" tires will fit on stock height bc like you said someone will log on to TW and take his general statement as a true statement and actually go out and buy tire size based on that information. Sure at the end of the day it would be the individual's fault for not doing all his research but just wanted to point out it wasn't a true over all statement that could be claimed.
    I have sliced my tires from bottoming out the suspension and the pinch welds under the wheel well cut through and chewed my tires on my cab mount after its been chopped with new tires and its not a good feeling (3" lift 285/75/16 K02s (32.8"OD) on FN wheels 4.0 Backspacing and 0 offset). Maybe you don't care about this topic enough to make a correct statement but I'm just trying to help the next guy out based on experience.
    BloodyTesla likes this.
  20. Jul 13, 2017 at 7:01 AM
    #60
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    This is funny. "It could be possible that for him, no rubbing occurs, but he can't claim no rubbing occurs because someone might use the real data he's provided regarding a specific tire on a specific wheel to guide a decision, instead of relying on the intangible data provided by other peoples' paragraph long rants about why he's a liar"
    These tire threads all turn into this mess too. "There's no way you are doing what you say youre doing because it causes me cognitive dissonance!" Also, #255s4Lyfe
