OoOooo Look what I found =(
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bamahoyt, May 27, 2012.
  1. May 27, 2012 at 3:57 PM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    NorCal
    2001 TRD 4x4 Xtra Cab
    Tires- 31x15x10.5 Cooper Discovery AT3
    Well I have this strange jingle in my front pass. side when I hit bumps so I decided to pull things off and take a look. I have owned the truck about a month now and its been there the whole time. Well I took the tire off and found that my retainer for my brake pads had broken and then upon a deeper inspection I noticed that I CV boot was blown. I then decided to take a look at the other CV boot and it was a mess. Looks like I will be adding CV boots to my "To Do" list for my truck. I saw that there was a CV slide Mod sticky so I will check that out. Are inner boots pretty simple to replace? and also is that retainer thing necessary because I am headed to town tomorrow and get some parts cleaners so I could find one while I am there
  2. May 27, 2012 at 3:59 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Not sure how it is with our trucks (your truck) but when I tore a CV boot on my FWD car, I was told it was cheaper labor wise to just replace the half axle. So that being said, I'm guessing it's a lot of work.
  3. May 27, 2012 at 9:25 PM
    Bamahoyt
    Ted
    NorCal
    Alrighty. Well hopefully someone will chime in on that. Thanks
  4. May 27, 2012 at 9:50 PM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    2011 Dbl Cab TRD Sport
    I can't add much but rock auto has them for about 50 bucks, since they have been like that for a while I would do the replacement. I have had it done on other cars if it was torn for a long time or just change the boot if it was just a small hole. That being said you have to do the same amount of work to change the boot or replace the whole cv might consider that in your equation.
    http://www.rockauto.com/catalog/raf...88&partkey=534650&a=FRc1278929k534650-1830392
    Cypher
  5. May 28, 2012 at 8:12 AM
    Bamahoyt
    Ted
    NorCal
    Great. That might be a fun $100 Half axle's replacement and a weekend project. thanks
  6. May 28, 2012 at 8:34 AM
    aw113sgte
    aw113sgte Well-Known Member
    Aftermarket ones are never as good as OEM. There is a reason they are cheaper. They are not built to the same tolerance, nor is the surface hardening as good.
  7. May 28, 2012 at 8:50 AM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    ive done mine a few times i have a 2004 taco and they are actually pretty easy. like the guy above me said aftermarket ones are never as good but hell toyota will charge you 800 bucks for a set! no thank you! i got the autozone ones for 100 bucks and a life time gaurentee your all set! and yes its easier to change the whole half shaft than just doing a boot
  8. May 28, 2012 at 5:14 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Yea remanned shaft from autozone. is like $50 after a 100 core charge. May as well just change the whole shaft may be worn from lack of lube. Plus is plug and play will take half the time.
  9. May 28, 2012 at 5:17 PM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    If you replace it do a write up. I havent seen one yet and would be interested to see what it takes and what I might need to avoid doing(at your expense. :D )
  10. May 28, 2012 at 5:21 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I'd replace it.
    No telling how long they've been torn, they're dry and dirty. That's a LOT of wear. You can go through all of the work of replacing the boots and in 3 months realize that you're getting a klunk/click/bind when turning.
  11. May 28, 2012 at 6:40 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    i dont know about your truck buy on my 1st gen all you do is take the wheel off (oviously) than take the nut that holds your half shaft to the nuckle, pop the lower control bolt off than take a crow bar and pop the half shaft off! pretty easy nothing too crazy. Grant it thats a super basic explanation its a little more involved than that
  12. May 28, 2012 at 6:47 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Like everyone had said it you should just replace the half shaft. It doesn't take long for some grit to get in there and wear the cv's out.
  13. May 28, 2012 at 10:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  14. May 28, 2012 at 10:46 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    great advice. you can't beat autozone's warranty. i've used their reman. half shafts on cars before and they've always held up fine.
  15. Jun 21, 2012 at 2:54 PM
    Bamahoyt
    Ted
    NorCal
    Just got my axles in from NAPA and they were $60 each but I only got one because they only had one in the houston area but I was told that the passenger side and driver side are the same. Just checking to make sure that it is true becuase the part numbers are the same for both sides also.
  16. Jun 21, 2012 at 6:52 PM
    Newbie123
    Newbie123 Active Member
    Without question replace it. The tolerances are now larger than what they should be and you'll have too much play within the joint therefore tearing another boot and causing more wear than necessary. CV boots should only be replaced when they are caught tearing early enough, before water, dirt, and all the grease evacuates the joint.
  17. Jun 21, 2012 at 9:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, both sides are the same for ADD trucks. It is a different axle if you have manual hubs but even with those, both sides are the same.
  18. Jun 23, 2012 at 3:33 PM
    Bamahoyt
    Ted
    NorCal
    well, its done and it took me about 2.5 hours to do by myself. Easy job and somewhat fun. Cheap at $140 total including taxes and extra gear oil.
  19. Jun 26, 2012 at 5:01 PM
    Bamahoyt
    Ted
    NorCal
    I don't wheel real hard so I think I will keep her posted up where it is but maybe in the future I will take it off.
