Oooooo, look what I found.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larzzzz, Aug 29, 2016.
  1. Sep 13, 2016 at 9:06 AM
    Larzzzz
    Larzzzz [OP] Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    No, I want a long block instead of replacing the head gasket. Overheated then the a p0306 code shortly after the water pump and tstat were replaced. New plugs, moved coils, and the same code.
    Silly to do one without doing the other. And now that the top end is all nice and tight, that's gonna put additional stresses on the bottom end. At 240k miles, I don't think the bottom end will last, maybe a year...
  2. Sep 13, 2016 at 9:56 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Seems to me the blown head gasket was the initiating event. Leak path between cyl #6 and water jacket caused coolant to be contaminated and overheated. Leak path also caused the low compression in cyl #6 and the misfire code.
    140-150 psi in the other cylinders look OK. I don't think replacing the head gaskets would put more stress on the bottom end. Not sure if you've had the truck since new. 240k may or may not be a lot for 1GR depending on how it's maintained.
    R0dzilla75 likes this.
  3. Sep 13, 2016 at 10:00 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Out of curiosity did your mechanic give you a shop time of how long this swap would take? and approximate cost excluding engine?
    I only have 130k on mine but love the truck and plan on keeping it for a long time, always wondered what it would cost to have a shop do a swap later on instead of doing it myself.
  4. Sep 13, 2016 at 10:03 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    That has been my experience, rebuild the heads and the bottom end dies soon thereafter. Now I rebuild the whole engine.
    Larzzzz[QUOTED][OP] likes this.
  5. Sep 13, 2016 at 10:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    At 240° you head or heads are warped. No doubt. Going to need to get them machined. Looking at .004" -.006" deflection. Highly highly unlikely that the torque to yield head bolts are still within their stretched tolerance. Check for sure, as it could save you from having to replace all of them. A special socket it needed to remove/install the head bolts.
    I have the Snap-On p/n if you need it? I'll need to upload the picture though.
  6. Sep 13, 2016 at 10:08 AM
    Larzzzz
    Larry
    MA
    Had the truck since new. Mobil 1 with a d3 filter every 3-5k. Been a while, but I have seen motors with fresh top ends crack rings and shit in other cylinders. I only want to do this once..
    he said a couple days and about a grand with labor and fluids.
  7. Sep 13, 2016 at 10:23 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If this is an automatic, think about changing the radiator. Helps with avoiding the dreaded "pink milkshake"
  8. Sep 13, 2016 at 10:52 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    The bigger the glob, the better the job :thumbsup:
    tacoma16 likes this.
  9. Sep 13, 2016 at 11:07 AM
    Larzzzz
    Larry
    MA
    Haha haha, you're funny. Good point though. I will have it flushed at a radiator shop
  10. Sep 13, 2016 at 11:14 AM
    koditten
    Kirk
    Central Michigan
    Not being funny. Look it up.
    Radiators are considered wearable parts and they are cheap. Flushing is really not the best answer.
  11. Sep 13, 2016 at 11:29 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    What year is your truck?
  12. Sep 13, 2016 at 11:58 AM
    Larzzzz
    Larry
    MA
    I'll check out getting a replacement radiator... it's an'06
  13. Sep 13, 2016 at 12:14 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I just went through his with my 06' too, luckily I caught mine early and never saw a temp over 202 on my scan gauge so the heads were still in good shape. I heard air bubbles behind the dash in the mornings then a few months later started having coolant overflow under the hood from the coolant reservoir ...then noticed bubbles in the coolant resi which was the big sign it was a head gasket leak. Never had the sludge on the cap or any bad looking oil. I just had it all fixed last week, when they got into it the water pump had a similiar prob as yours although not as bad and the radiator definitely needed to be replaced too. We went ahead and replaced the idler and tensioner pulleys because they are notorious for failing around 150k too. Heads were sent to the machine shop and barely needed any work at all, valve seats were still great too.
    I had the same thought about the bottom end giving up after tightening up the top end but was told by a few local shops that these new motors are really tight and the bottom ends are generally still in excellent shape and can handle the top end being tightened up.
    My head gasket work was $1550 plus the water pump, radiator and pulleys.
    Larzzzz[OP] likes this.
  14. Sep 13, 2016 at 12:32 PM
    Larzzzz
    Larry
    MA
    What's the temp now?
  15. Sep 13, 2016 at 1:50 PM
    #35
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Operating temp seems to go from 185- 195 ish, I was told that is the normal range.
  16. Sep 13, 2016 at 1:51 PM
    #36
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is. Unless you add in a cooler T-stat, or other related items.
  17. Sep 13, 2016 at 2:06 PM
    #37
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    That's a helluva good price, most shops charge $3-4K, I did mine myself for about $800 without the radiator and pulleys, but machining the heads, all of the gaskets, water pump and head bolts.
  18. Sep 13, 2016 at 2:46 PM
    #38
    Larzzzz
    Larry
    MA
    Saw the motor today. It's an 05 with 78k...grrrr, wtf. Oh well, no matter, it's here and the guy will have the old motor out tonight, new one in tomorrow and hopefully ready on Thursday.
    The motor doesn't look all new England nasty. The dust covering the block has more of a sand/light tan color
    Getting a new radiator under 2 bills. Might as well. Whatever was on the bottom of the radiator cap is in the radiator.
    Anything else I should spend money that I don't have right now on? Lol.
    Nirvana likes this.
  19. Sep 13, 2016 at 2:50 PM
    #39
    Larzzzz
    Larry
    MA
    The water pump and tstat are brand new on the junk motor. He's moving them over. Plugs too and he's keeping a couple extra coils for me.
  20. Sep 13, 2016 at 2:54 PM
    #40
    Larzzzz
    Larry
    MA
    I swear I was rock solid at 180° for the longest time as reported by the scan gauge. Temp started creeping up a while ago... Well over a year ago. It'll be interesting to see what it runs at now.
