Ooops....Left in 4 wheel drive.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Harley2, Mar 23, 2015.
Thread Status:
Not open for further replies.
  1. Mar 23, 2015 at 6:07 AM
    Harley2
    Harley2 [OP] Well-Known Member
    Rick
    Vermont
    15 Super White Double Cab 4x4
    So have I done any damage? I accidentally left my truck in 4 wheel drive on hard pavement driving to work at speed averaging 60MPH. I have a nasty 2nd class road I live on and have to put it in 4 wheel to get up the icy snow covered road. I forgot to take it out coming to work this morning when I hit the pavement for the 48 mile trip in.
  2. Mar 23, 2015 at 6:10 AM
    Murica
    Murica F' YEAH!
    Jon
    NH
    '14 DCSB TRD OFFROAD 4x4
    Plasti Derp
    you're all good!
  3. Mar 23, 2015 at 6:17 AM
    UssMoGn
    UssMoGn That Vegas dude
    James
    Las Vegas NV
    05&04 Tacoma SR5
    Home Built Front Bumper HID Headlights LED Cab lights 2013 Radio swap MOLLE DC Insert Traffic Cam F&R 6'' Procomp lift Custom Grillie
    Should not be a issue, I take it there was no turns on 48 mile trip? Chirping tires usually get my attention.
  4. Mar 23, 2015 at 6:19 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Even slight turns are OK...you will notice it binding up on a 3 point or a U-turn lol
  5. Mar 23, 2015 at 7:06 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    all you did was maybe double the wear on the tire tread for the given distance
  6. Mar 23, 2015 at 7:16 AM
    Harley2
    Rick
    Vermont
    Thanks Guys. That makes me feel better!
  7. Mar 23, 2015 at 7:31 AM
    Oldmedic
    Oldmedic Member
    Grayson Co, KY
    2015 Tacoma
    Better tires
    I'm a new member and have a quick question about tire sizes. Just ordered a new 4WDTacoma Access Cab w/SR5 package w/ TRD alloy wheels. Dealer not sure what size tires this option combination will come with. Any of you have any ideas, 245/65R 16, 265/70R 16, or 265/75R 16?
  8. Mar 23, 2015 at 7:48 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to the forums! Don't hijack threads!
    virvak2 likes this.
  9. Mar 23, 2015 at 7:56 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Wtf is this shit.
  10. Mar 23, 2015 at 8:19 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You'll get a lot more love if you do the following:
    #1 - Use the search function to answer your question, before asking it
    .....if you can't find your answer....
    #2 - Start a new thread to ask your question, and help will be provided.
  11. Mar 23, 2015 at 8:25 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Actually neither, tires on the trucks on dealer parking lot are for display only. When you come to pick up truck you need to bring your own rims and tires...
    :D
  12. Mar 23, 2015 at 8:37 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    OP, if you aren't hearing any strange noises from your driveline your truck is fine. You put a little extra stress on the U-joints, U-joint bearings, CV's, axles, and tires but the odds are you probably just took 0.00001% off of their lifespans. The fact that you traveled in a straight line helps more than anything with minimizing any damage you could of caused.
    It happens to everyone. There have been a few times I hit pavement, notice the tires binding, and flip the 4WD off :p.
    If you do hear strange noises odds are you just messed up a U-joint bearing. My mom did that once by driving her GMC Yukon around for a day in town (lots of turning) while the truck was in 4 Hi. Even then it wasn't a terribly expensive repair, only a couple of hundred bucks if I remember correctly.
    WOW. Start a new thread pls. There should be a multiple choice test on thread rules when new members join.
    :threadjacked:
  13. Mar 23, 2015 at 3:12 PM
    Harley2
    Rick
    Vermont
    Thanks I appreciate it!
  14. Mar 23, 2015 at 3:45 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Sound like you got lucky this time. Sharp turns are the main problem... if you didn't experience any binding, wheel hop, or loud noises up front your probably fine. Don't feel bad... we've all done it. Here's a link that explains it more... http://4x4abc.com/4WD101/def_turnpart.html
  15. Mar 23, 2015 at 4:50 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you have such a low esteem of how well you truck is made maybe you should not have bought it. The drive line is far tougher than the tires. If you don't wish to damage your drive line don't take it off road and climb over rocks in low range that's far harder on the CV's and Ujoints. Toyota recommends using 4WD at least 10 miles once a month there is nothing in the manual about never on dry roads. Please feel free to ignore this but don't whine when your ADD doesn't work or axle support bearings fail.
  16. Mar 23, 2015 at 5:08 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    :rolleyes:
    Self esteem is a view of ones self, not ones truck...
    Climbing over rocks allows the drive line to slip which gets rid of binding, unlike pavement...
    Ask any dealer, 4WD is not for use on dry pavement...
    You've trolled enough for one day I think.
  17. Mar 24, 2015 at 5:14 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes your tires do slip but what makes you go forward is when they grab under a lot of torque it does not matter if you are making a hard turn in 4WD the stress is there when you regain traction, you really want to stress your drive line light your tires up on the pavement. No troll dude just 50+ year of dealing with transfer cases and drive lines.
  18. Mar 24, 2015 at 5:23 AM
    taco 2011
    taco 2011 Well-Known Member
    Alabama
    2011 Toyota Tacoma TRD SR5
    Westin Bull guard,predator nerf bars, Window Tint Legal limit, Weather tech Floor mats, Weather tech smoke visors, Wet Okole seat covers, OEM Roof Racks, Reverse Camera, Pace Edwards Full Metal Jack Rabbit Cover,Dyno power locking tailgate Trd alloy wheels, Dunlop at tires JL Stealthbox, JL custom fit molding kit, Directed Audio 500 watt amp, LCI adaptor. More mods to come.
    :stayontopic:
  19. Mar 24, 2015 at 7:37 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Sure. What I heard, and so did OP, was a bunch of insults at him owning a truck and a few half facts from you. Yes, the damage is done in 4WD when the tires bind (aka have traction) and force is exerted back into the driveline components because everything is locked up. Turning creates a speed/rotational differential between the front and rear wheels. If the differential force is stored by the system rather than released by the tires slipping you could cause damage to the driveline. You don't need to be an expert to know that :rolleyes:. OP has already heard that several times. There was no need to hurl it in his face as rudely as possible.
  20. Mar 24, 2015 at 7:45 AM
    Harley2
    Rick
    Vermont
    This OP has broad shoulders. I'm 55, I've been hurled on by better in my life! Lol Thanks!
Thread Status:
