oopse, what have I done?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hootch, Apr 28, 2024.
  1. Apr 28, 2024 at 6:35 PM
    Hootch
    Hootch [OP] New Member
    99 4x4 extra cab
    While doing the valve cover gaskets on my 99 V6 4x4 Tacoma, I swapped the vacuum and the coolant line on the bottom of the throttle body. When I started it up, heard a liquid running sound that did not sound good. Never heard that one before.... Does anyone have an idea of how to drain the coolant out of the vacuum system, or should I just let it be? Thanks for your replies.
  2. Apr 28, 2024 at 6:42 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    How long did it run? Did you shut it off or did it die on its own?
    "The vacuum system" is the intake manifold, and the next stop is the cylinders.
    It might be fairly inconsequential if it was just a little bit of coolant. Anything more than and you're looking at pulling the manifold to clean it out and /or removing the spark plugs to get it out of the cylinders
  3. Apr 28, 2024 at 6:49 PM
    Hootch
    99 4x4 extra cab
    It idled for a few minutes. I shut it off. It's smoking pretty good. To be sure, the vacuum is the lower port on the throttle body, while the upper is the coolant?
  4. Apr 28, 2024 at 7:14 PM
    Hootch
    99 4x4 extra cab
    I just pulled a plug and the cylinder seems a bit damp, but not enough to hydrolock it. Have I dodged a bullet or am I in for more fun and games? PS, Thank you so much for your reply!
  5. Apr 28, 2024 at 10:50 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Coolant lines for the throttle body are on the bottom.
    I would be as diligent as I could to get any excess coolant out of the cylinders before running the truck any more.
  6. Apr 28, 2024 at 11:14 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    If you pulled the plugs and cranked it to get the coolant out, you’re good.
    457taco and ColoradoTJ like this.
  7. Apr 29, 2024 at 4:19 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Should probably do an oil change now too
