Open Differential 4x4 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BanjoScott, Jun 2, 2015.
  1. Jun 8, 2015 at 4:36 AM
    Airmain
    Airmain Well-Known Member
    Jes
    Middle of Georgia
    06 TRD Off road
    I will say $200.00
  2. Jun 8, 2015 at 4:47 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I'm sure it would be. But everyone has Blazers and Broncos. Scouts are less common and that's why I like them
    And, apart from the sheetmetal that tends to rust easily, they are arguably much better built than a Blazer or Bronco. The engines are truly truck engines and make ridiculous amounts of torque at low revs.
    I want to find one in running/driving condition that I can work with (meaning limited rust) and slowly restore it over the years. I should have bought the one I saw last summer. Haven't found anything close for the price. Lots of them have GM 350s swapped into them. I get the reasoning (they're a dime a dozen and weigh a fraction of what the IH motor does), but it just makes me cringe. I want it to be original.
  3. Jun 8, 2015 at 5:40 AM
    Pigpen
    Dan
    Northwest Montana
    No need for a bumper for a winch. I have the CBI Offroad Fab hidden front hitch and Warn Quick connect front and rear kits. My winch is on a removable carrier and can be used on the front or rear of the truck. An added bonus is that I don't have to drive around with my winch on the truck when I'm not going to be needing it.
    SACTOWN likes this.
  4. Jun 8, 2015 at 1:34 PM
    BanjoScott
    BanjoScott [OP] Member
    I haven't driven them before... Everyday get better at it. Really that was the only 4x4 Tacoma available. I had just sold my 4runner and needed something ASAP to get to work.
  5. Jun 8, 2015 at 1:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    again, for those that dont have an elocker and subsequent atrac in 4 lo, check out the Yellow wire mod.... this will give you some simulated LSD action on both axles in 4lo which does help out!
