Open differential spider gears breaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nschmittsd, May 1, 2018.
  1. May 1, 2018 at 12:44 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    On the street, daily driving/towing/commuting, they'll be fine, unless you're drag racing/drifting/burning rubber/jumping dunes more.
  2. May 1, 2018 at 12:46 PM
    Muddinfun
    Muddinfun Well-Known Member
    So, if I read this right, you blew up the original 130k mile 3.73 ratio open diff rear and now you installed a 4.56 open diff and are wondering how it's going to hold up?
    I'm assuming the open diffs have 2 spiders. Do the limited slips have 4 spiders?
  3. May 1, 2018 at 12:46 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Who knows. Maybe the spider gears were an isolated failure due to abuse. Maybe you bent or screwed up something else (bearings? axle shaft?) that caused premature spider failure. Let us know.
  4. May 1, 2018 at 12:56 PM
    nschmittsd
    nschmittsd [OP] Well-Known Member
    Nick
    Chula Vista
    07 prerunner tacoma double cab
    procomp helldorado rims bilstein 5100 goodyear ats hid/led whole truck
    Exactly. And open diffs have 2 spider gears. Not sure about limited slip.
  5. May 1, 2018 at 1:01 PM
    nschmittsd
    Nick
    Chula Vista
    This is the answer I was looking for. Thank you
