open diffs are bad and I should feel bad. . .
Discussion in 'Tacoma Videos' started by MxRacer190, Apr 5, 2014.
  1. Apr 6, 2014 at 2:32 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    "Standard" differential.
    Closed and open differential refers to the carrier of the pinions. Too many people with bad terminology around here. Toyota trucks have closed differentials.
  2. Apr 6, 2014 at 2:37 PM
    avw4x4
    avw4x4 Well-Known Member
    Andrew
    Rochester, NY
    '93 FZJ80
    OME 2.5" lift, cobra cb radio, smashed rocker panels
    The yellow wire mod gives 2009+ models trac in 4lo. Basically turning each axle into a LSD. It would have made this much easier for the OP...if he had a 2009+ Truck ;)
  3. Apr 6, 2014 at 3:01 PM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    never heard of a "closed diff"
  4. Apr 6, 2014 at 3:07 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    100,000 people on this forum call it OPEN diff.
    1 person calls it closed diff. :facepalm:
    tpotnoc likes this.
  5. Apr 6, 2014 at 3:45 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    From what source do you get these numbers
  6. Apr 6, 2014 at 4:03 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    your mom told me
  7. Apr 6, 2014 at 4:16 PM
    Janster
    Jandy
    Lancaster, PA
    :rofl:
  8. Apr 6, 2014 at 4:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    People have been calling non locked, or LS Diffs "Open" for 438 years. I have never told someone the diff was "Open", to have them give me a confused look and not know what I was talking about. "Closed Differential" is more commonly known in math.
    tpotnoc likes this.
  9. Apr 6, 2014 at 4:26 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Do some research bud :thumbsup:
  10. Apr 6, 2014 at 8:38 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    OP you should try that first one again in 2WD with Auto LSD, I think it may work better.
    tpotnoc likes this.
  11. Apr 6, 2014 at 11:01 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 2 Hella 4000 HID, 1 Cibie Halogen. Bilstein 5100s Ride Rite Air Bags
    His sig says he has a 2006 4WD.
    AUTO LSD & TRAC wasn't standard on all Tacomas until 2009. There were some exceptions back to 2005 I hear.
    With only open differentials (as opposed to limited slip), and no select-able rear locker, and no electronic/ ABS traction controls... then the best advice was given: REDUCE the air pressure in the tires... off road: 20 psi max/ 10 psi min on the standard tires. When you are under 15 psi, you must avoid speed, sharp turns, sudden braking... The beauty of 4WD is to crawl up and through anything with damage to the truck. 2WDs need momentum...
  12. Apr 6, 2014 at 11:09 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    As Chris said.
    A little pressure on the brakes would have switched traction to the other wheel.
  13. Apr 7, 2014 at 3:33 AM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Learn brake throttle modulation and you'll be set. I rarely use my rear locker now.
  14. Apr 7, 2014 at 4:08 AM
    Janster
    Jandy
    Lancaster, PA
    I did....... and everywhere I searched referred to OPEN diffs, LSD, traction information, and all the things this forum already discusses as OPEN differentials.
    :D
  15. Apr 7, 2014 at 6:35 AM
    #35
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    I guess the educated are few.
    Open and closed is the carrier
  16. Apr 7, 2014 at 8:25 PM
    #36
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Deck Plate Mod; Grey Wire Mod; 1.5" AAL; 1.75" Lift Shackles; Bilstein 5100's; Eiback Coils; LR UCA; Front Diff Drop; Tundra Brake Upgrade; Wheels Offroad Brake Lines; Rear Diff Breather Mod
    This. Especially in that situation, use the e-brake.
  17. Apr 7, 2014 at 8:34 PM
    #37
    BeeRadd
    BeeRadd ANTI-DARK Vendor
    Brad
    Fountain Valley, CA
    2008 DCLB 4x4 TRD Sport
    Mag light mod, ABS Kill switch, On board air, tail-gate theft mod, Redline hood struts, Shovel mount, Rubberized undercoated frame, CB radio w/lil wil magnet antenna, LED interior light, Shocker 228 Train horns, black valence, fog lights anytime, black hood scoop, eyelids, anti-seatbelt chime hack, weathertechs,
    TRYING THIS
  18. Apr 7, 2014 at 8:36 PM
    #38
    BeeRadd
    Brad
    Fountain Valley, CA
    OP, i've heard that on the 06 and 07 models that if you "feather" the e-brake whilst stuck on something like the first video, it will trick your diff and have a locker effect.
    Only heard this on trails before, never seen in action. Can anyone verify?
  19. Apr 8, 2014 at 4:38 PM
    #39
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    I've heard this also. I've tried it in the past with no luck. Everyone swears it works though.
  20. Nov 15, 2016 at 9:02 PM
    #40
    tpotnoc
    tpotnoc Well-Known Member
    Bellingham, WA
    15 2.7 DCSB PRERUNNER
    I've been waiting for some runs like this to use my ALSD and air compressor! The ALSD would have worked better than 4WD I think (in the first vid)
