open door chime
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lizard1, Jul 29, 2010.
  1. Jul 29, 2010 at 1:29 PM
    lizard1
    lizard1 [OP] Well-Known Member
    Tucson
    Desert Sand Mica/4x4 off road w/lock rear
    Leer cap, rear TSB, BFG All Terrains 10 ply 265/75/16, mud flap trim, black badges, AFE filter, 3" Toytec lift, 884 OME coils, add - leaf, Bilstein 5100 all around
    I did the odometer reset which solved the seatbelt chime. Is there a method
    to disable the open door chime when the ignition is "on" position...not running?
    Any help/leads appreciated....Thanks! "08 TRD 4x4 auto
  2. Jul 29, 2010 at 3:58 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
  3. Jul 29, 2010 at 4:01 PM
    APTJ
    APTJ Well-Known Member
    Eric
    Texas
    2005 Dcab SR5 4x4
    grill, lights, bull bar, rims, tires,
    dont think I'm going to do it but cool none the less
  4. Jul 29, 2010 at 4:03 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
  5. Jul 29, 2010 at 4:07 PM
    JarJar
    JarJar New Member
    Jarrod
    Missouri
  6. Jul 29, 2010 at 4:35 PM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    08 4cly
    Dule Magnaflow Exhaust dumped behind axle, K&N Air intake, Aftermarket radio with a kicker L5 sub & a shit amp, 18" rims with tires, RHLM, DT header, color matched bumper, oem foglights, 8k hids in headlights and in fogs
    wow i may do this right now haha, i didnt know it was that easy i thought the only way to do it was when you remove the gage cluster to do the led swap.
  7. Jul 29, 2010 at 6:01 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    I found my buzzer and ripped that out.
  8. Jul 29, 2010 at 7:15 PM
    jackwithcorona
    Eastern Mass
    13 DCSB SR5 4x4
    yea really easy and completely reversible too
  9. Jul 29, 2010 at 9:48 PM
    Taco505
    Alex
    New Mexico
    08 4cly
    haha i just did it took like 10 min, cuz im retarded and couldnt get the bottom half of the panel off, if your not like me itll take like 2min if that
  10. Jul 30, 2010 at 3:05 AM
    TopTeke
    TopTeke Active Member
    Ventura, CA
    07 PreRunner 6spd. Access Cab
    You guys have a seatbelt chime?
  11. Jul 30, 2010 at 6:44 AM
    Taco505
    Alex
    New Mexico
    08 4cly
    no i turned mine off as well, by truck no longer bitches at me :D
  12. Jul 30, 2010 at 8:44 AM
    lizard1
    Tucson
    Thanks for the responses,info, and link! Looks pretty straight-forward.....something even i could do! I'll do it this weekend.
  13. Jul 30, 2010 at 8:51 AM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    unplug the pressure switch, that tells the computer the door is open, that what I did no problems for 2 years now.
  14. Jul 30, 2010 at 3:26 PM
    lizard1
    Tucson
    .....unplug pressure switch...huh? No clue what you're referring to. Any chance you could elaborate?:help:
  15. Jul 30, 2010 at 4:30 PM
    Taco505
    Alex
    New Mexico
    08 4cly
    if you open your door there is a little black rubber thing attached to the cab. if you push it down the chime will go off, if you let go of it the chime will sound haha.
    i think there is 2 screws that you can undo then im sure there is something you can unpulg. not sure if thats what he is talkin about but thats what i got from it
  16. Jul 30, 2010 at 7:28 PM
    jpmorrisvb
    Jimmy
    Virginia Beach
    Does this effect the cab lights if unplugged?
  17. Jul 30, 2010 at 7:30 PM
    jrws6
    x2.... thats it.
    and yes it will keep your dome light from coming on when you open your door with a key. just use your clicker and it will come on.
  18. Jul 30, 2010 at 7:34 PM
    jrws6
  19. Jul 30, 2010 at 7:55 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Has anyone done this and had problems with the immobilizer on the v6? That switch that you're unplugging also tells the immobilizer you have a key in the ignition. Does it take longer to start or anything?
