Open in Multiple Squib Circuits
Discussion in '1st Gen. Tacomas (1995-2004)' started by mrduran, Jun 15, 2023.
  1. Jun 15, 2023 at 3:42 PM
    mrduran
    mrduran [OP] Member
    1999 Pre Runner, RWD Standard Cab, 2.7L 3RZ-FE, A/T
    Full street header, add-a-leaf spring (rear)
    I have open driver and passenger side squib circuits including the pretensioners. This wasn't right after an accident.
    -No airbag deployment.
    -SRS light is constant ON.
    -I replaced my left pretensioner around 200K miles, but never changed my right pretensioner. Yet both P/T squibs showed open around the same time.
    -I cleaned the contacts with isopropyl and CRC QD Electronics Cleaner.
    Codes:
    B0101
    B0106
    B0131
    B0136
    Insight appreciated.
    Happy wrenching.
  2. Jun 15, 2023 at 7:29 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you checked the connectors at the SRS module?
    Bivouac likes this.
  3. Jun 15, 2023 at 7:56 PM
    mrduran
    mrduran [OP] Member
    Yes. And I cleaned all the contacts as well.
  4. Jun 15, 2023 at 8:53 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    SRS circuits are kinda tricky to test, typically the easiest test is to put a resistor of the correct value in place of the component that is generating the code and seeing if the code clears.
    mrduran[OP] and Bivouac like this.
  5. Jun 9, 2024 at 9:14 PM
    mrduran
    mrduran [OP] Member
    Weekend warriors, we gather once again.
    In preparing to sell the truck, here are some things I found...
