[Open] - Noxx Flashlight Group Buy
Discussion in 'Non-automotive Group Buys' started by Scoobarooo, Apr 19, 2018.
  1. Apr 19, 2018 at 7:42 AM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Hey there! So I'm trying something a bit new here! My norm is T-Shirts. However, I've teamed up with a company called Noxx Flashlights - I've been using these lights for 6+ years and decided I like them so much, I want to do a group buy so everyone can get in on these bad to the bone lights. I stock quite a few different lights but this group buy is going to be for 4 different lights. This is going to work as normal - If you're interested in buying one, comment below with the type and quantity of the one you'd like to buy in for - I will add you to the list then. The discount is going to be 20% off MSRP. - If this Buy goes well enough, we will have the chance to become an official vendor on Tacoma World! Which means more discounts for YOU! :thumbsup:
    Don't hesitate to ask questions - I'll gladly answer them without hesitation.
    ADVENTURE II FLASHLIGHT
    Quantity - 6
    MSRP - $49.99
    Functions:
    • High Mode used for long range spotlighting on work where intense illumination is required
    • Low Mode used for normal flashlight tasks and every day work
    • Interchangeable Lenses - clear, red and green glass lenses for low impact illumination
    Features (All Included):
    • Light Source 5 watt high intensity diode light chip
    • Beam Intensity over 12,000 candelas
    • Length 4.75" closed - 5.25" extended
    • Weight 4.4oz
    • Slide Focusing Head patented slide function
    • Maximum Beam Distance 200+ yards
    • Construction high grade aluminum body
    • Power Source three (3) standard high quality "AAA" batteries (recommended for best performance)
    • Wrist Band
    • Belt Mount Carrying Case with pouch for extra lenses
    • Lenses clear, red and green
    • Water Resistant
    • End Cap Switch easy access recessed rear mount power button
    • One Year Manufacturer's Warranty
    ADVENTURE 300 RECHARGEABLE FLASHLIGHT
    Quantity - 4
    MSRP - $99.99
    The NEW Adventure 300 Flashlight has a 45% higher down range capability than our original, popular Adventure II Light, while still remaining very compact, under 6" long!
    Functions:
    • Low Mode used for normal flashlight tasks, going to and from location
    • Light Source high intensity CREE diode light chip
    • Length5.25” closed - 6" extended
    • Weight5.5oz
    • Slide Focusing Head patented sliding function to vary beam from wide to spot easily
    • Maximum Beam Distance 300+ yards
    • Power Source one (1) 18650 2600mah rechargeable battery
    • Spare Battery hunt all night
    • Battery Charger dual capacity with combo USB/car charger adapter
    • Wrist Band
    • Water Resistant
    • Fits most standard universal gun mounts
    XPLORER HEADLAMP
    Quantity - 6
    MSRP - $49.99
    Functions:
    • High Mode used for long range spotlighting or work where intense illumination is required
    • Strobe Modeused for high visibility safety light
    • Head Length 2.25" closed - 2.75" extended
    • Weight 5.6oz
    • Slide Focusing Head (upgraded to aluminum body)
    • Pivoting Lamp new infinite micro adjust-ability (no ratchet mechanism)
    • Power Source three (3) standard high quality "AA" batteries (recommended for best performance)
    • Head Band adjustable for a comfortable fit (wider and longer straps for more comfort)
    • Water Resistant
    • Rear Mount Power Switch (sealed rubber tap switch)
    VIPER X HEADLAMP - GREEN
    Quantity - 6
    MSRP - $59.99
    PLEASE NOTE: This is a dedicated GREEN light, you cannot interchange the green light for a white one - the light source is green.
    Functions:
    • Weight 5.6oz
    • Water Resistant
  2. Apr 19, 2018 at 7:49 AM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Reserved for Tacos
  3. Apr 19, 2018 at 3:00 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Reserved for Tacos :oldglory:
  4. Apr 20, 2018 at 8:06 AM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
  5. Apr 30, 2018 at 5:30 PM
    SeeWhatHadHappenedWas...
    SeeWhatHadHappenedWas... Well-Known Member
    Jeremiah
    Oregon
    2017 OR DCSB MT Quicksand
    I’m interested in the adventure 300 and the xplorer headlamp. Would be nice for work.
  6. Apr 30, 2018 at 7:31 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Group buy fell through, but I did add a discount for TW members to get 15% off through my website. Code is “TW15”, website is > here <
  7. Apr 30, 2018 at 7:49 PM
    Jeremiah
    Oregon
    Thank you. To bad it fell through, 15% is still pretty good though.
  8. Apr 30, 2018 at 8:12 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Sure is, the justification for buying one is really the big thing. My whole reasoning to behind why I have so many is because I love lights :rofl:. Seriously though, absolutely sick lights. Used em for years. My suggestion would be to buy the headlamp and go from there.
  9. Apr 30, 2018 at 8:22 PM
    Jeremiah
    Oregon
    They look nice, I tried to look up some info online and I couldn’t find to much about them. What I could find said they are fantastic lights for the money.
    Side note, I wanted to get a TN shirt while I was at it. When would you have the military green or cement back in? I really like that green.
  10. Apr 30, 2018 at 9:12 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    I’ve been working on getting a new batch of shirts in - we just moved to Orlando a couple days ago so still getting settled in and everything unpacked. Hoping to order some soon though.
  11. Jun 7, 2018 at 5:38 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
