Operating in 4 Lo Non A-trac Auto Trans.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dbarn, Apr 11, 2010.
  1. Apr 11, 2010 at 9:07 AM
    dbarn
    dbarn [OP] Well-Known Member
    Texas
    Tacoma 4X4 V6
    Ok, I made the yellow wire mod today. Two questions please. When operating in 4 Lo in muddy areas with an automatic trans. do most of you leave it in regular drive or do you shift down to lower gears and leave it there for slow traveling on diverse terrain? Not trying to gain speed, but want to have the right combination of speed and torque if needed. Second question. When pulling some one out that is stuck, after putting in 4 Lo would you put it in first and leave it there until they are free or have it in second gear? Now that the yellow wire mod has been made and traction control is working in 4 Lo, wanted to see if it makes a difference as to what gear when pulling some one out using auto trans. Thanks for your help
  2. Apr 11, 2010 at 9:18 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    The gearing is unchanged with TRAC ON, you just have ALSD (Auto Limited Slip, non-regulated engine output) traction in L4 now instead of Open Differentials.
    I would use momentum to keep moving through mud, but if really wet, you want to avoid getting too much water thrown up in the engine compartment! Try it in Drive before down shifting, because in Low Range, you overall gearing is much lower anyway. See what others say, as I have not pulled anyone out of mud...
  3. Apr 11, 2010 at 11:56 AM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Higher (wheel) rpm will create a stronger limited slip effect. As well, the algorithms for TRAC use a progressive application of the brakes, (ALSD effect) based on the wheel rpm, and difference of wheel rpm. I found that 1st gear did not turn the wheels fast enough, unless it was revved to the 4000 rpm range, which is unnecessary. Second gear was a good combination of torque and wheel rpm. Basically, you will find it most effective is 2nd, or 3rd. Most of my testing of the TRAC mod, was 2 wheels in the air, fully crossed up, going uphill on sand or mud, at very slow speed. So I was testing the extreme end of what TRAC is capable of. In the mud, wheelspin is as important as anything, so 3rd or 4th might be best. In addition to that, due to the limited pressures generated by the pump on the non-hydraulically assisted models, higher wheel rpm generates more brake pad friction, which transfers a greater amount of torque. Remember, this is a brake based system, and wet pads are not as effective.
    Previously I thought rpm affected the TRAC system, but I now believe only wheel rpm does, not engine rpm.
  4. Apr 11, 2010 at 12:03 PM
    dbarn
    Texas
    Tacoma 4X4 V6
    Thanks guys that is exactly what I need to know. And while I'm at it, on behalf of us non TRD O/R guys, thank you for the yellow wire mod. :cheers:
  5. Apr 11, 2010 at 3:01 PM
    David K
    A lesson for any serious off roader... GET THE OFF ROAD TRD 4WD TACOMA!!! The hydraulic brake booster/ Active Traction Control is dynomite.
  6. Apr 12, 2010 at 4:28 AM
    dbarn
    Texas
    Tacoma 4X4 V6
    Basically I went bare bones with my 4X4 AC cab and do not regret it. I previously had a 08 Pre-Runner until some one rear ended it. I like the 09/10 upgrades and with the lower monthly payment and yellow wire mod, she has and will do everything I need. This one will be a keeper for a while. Thanks again for the info!
  7. Apr 12, 2010 at 8:54 AM
    David K
    Have fun with it, dbarn!
