Operation Crash Bandicoot 4x4 Swapped 05' Tacoma
Discussion in '2nd Gen. Builds (2005-2015)' started by ChamYota, Jul 7, 2011.
  1. Jun 14, 2014 at 10:23 PM
    #1221
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    damn cam, glad I'm not responsible for the lugs on that side. XD
  2. Jun 15, 2014 at 2:38 AM
    #1222
    ChamYota
    ChamYota [OP] Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Haha thanks!
    We be a rare breed on the forum :cool:
    haha.
    Bad news fellas. The lugs sheared off again.. :(
    I had to get it towed to my house. Again. :(
    I honestly dont know why the fuck it happened this time.
  3. Jun 15, 2014 at 3:27 AM
    #1223
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Sounds like something is seizing that axle. :notsure:
    Wheel bearings seizing when they heat up?
    Very entertaining Build thread though, I like your attitude. :thumbsup: Sub'd
    Hope you get it figured out. :popcorn:
  4. Jun 15, 2014 at 6:56 AM
    #1224
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Those dick cepek wheels are lug centric, maybe a cause if you don't have hub centering rings? Maybe brake dragging, or wheel bearing bad? Just some suggestions!
    Also sense the lugs have already sheared check the diameter of the lug holes on the wheels, could have been affected
  5. Jun 15, 2014 at 7:10 AM
    #1225
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    :eek: Again Cam? Jeez
  6. Jun 15, 2014 at 7:14 AM
    #1226
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    To much weight lol. Sry bud
  7. Jun 15, 2014 at 7:22 AM
    #1227
    TheGoat
    Justin
    Greenville, SC
    I think these together might be your problem cam. Remember when I said alloy wheels shouldn't be lug centric. I would get some of that hording treasure out of your truck bed if its still the way I remember it. lol
    Also, did you make sure you fully seated those studs? Shit is crazy man, Hope you get this sorted out with out another tow bill.
  8. Jun 15, 2014 at 7:25 AM
    #1228
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
  9. Jun 15, 2014 at 9:13 AM
    #1229
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I have had lug centric wheels for over 30k miles with no problems, regularly towing 6k lbs. I think the issue is over-torqued lugs, and the wheel being damaged as a result of the lugs sheering. It will cause them to shear over and over unless replaced.
    A dragging brake is a good possibility. Extreme heat build up will cause the studs to fail.
  10. Jun 15, 2014 at 9:13 AM
    #1230
    ChamYota
    Cam
    No idea.. I know that we seated the studs pretty well and they didn't look crooked or anything, but it def sheared off again last night, luckily all of them didn't so i could roll(slowly on/off the tow truck).
    :turtleride: i take it to a shop tomorrow after i replace the wheel studs.. AGAIN :going crazy:
    .-. i just dont get why its only happening to just that one hub, i feel like the rest should be failing as well or maybe its just a matter of time.
    The '82 is just chillin at my folks house as i pay it off and build my credit, not really trying to build it at this moment in life.
    I may switch wheels.
    the hoarding treasure has been long organized lol. They were fully seated, my dad helped me seat them.
    :p
  11. Jun 15, 2014 at 9:15 AM
    #1231
    ChamYota
    Cam
    hmm... I guess i'll have to get those two potential issues looked at, how do i know the brake is dragging?
  12. Jun 15, 2014 at 9:40 AM
    #1232
    TheGoat
    Justin
    Greenville, SC
    my stock steels are lug centric too, cams are aluminum alloy though. The aluminum is very prone to wollaring, I would say the driver side rear that we took off was wollard out too. I just didn't like how they mounted up on the truck, they were very thick and didn't leave as much room for the lug threads to bite. With those wheels I would just rather see a hub-centric mount like the stock alloys.
  13. Jun 15, 2014 at 9:48 AM
    #1233
    ajohnson
    Andy
    Charlotte, NC
    My wheels are alloy as well, I have had 2 different sets. They don't fall off.
    Ever hear of ET (extended thread) lugnuts? You might want some. Be sure to properly torque them.
  14. Jun 15, 2014 at 9:52 AM
    #1234
    ChamYota
    Cam
    I couldn't have over torqued them this time because i did it by hand using a ratchet with a socket.
    The studs when they sheared off last night were extremely hot to the touch. Whatever thats happening is generating a large amount of heat which could point at why they sheared off.
  15. Jun 15, 2014 at 9:57 AM
    #1235
    TheGoat
    Justin
    Greenville, SC
    the heat is either from the brakes or the lugs wallowing around because your wheel is damaged. if its the brakes the whole drum would be pretty hot. they get hot enough to burn you without being messed up,
    torque wrench is $20 at harbor freight. only way to know its right.
  16. Jun 15, 2014 at 10:03 AM
    #1236
    ChamYota
    Cam
    If my wheel is damaged.. :/ damn it.
  17. Jun 15, 2014 at 10:04 AM
    #1237
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Holy shit!
  18. Jun 15, 2014 at 10:04 AM
    #1238
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Makes sense to me.
    I'm no expert, but that kind of heat in that area is usually bearing related IIRC. You might contact Bill (BamaToy1997) and ask his advice? :notsure:
  19. Jun 15, 2014 at 10:10 AM
    #1239
    ChamYota
    Cam
    Im shooting a pm now.
  20. Jun 15, 2014 at 10:11 AM
    #1240
    TheGoat
    Justin
    Greenville, SC
    bearings would make sense too. i would think you would notice some bad noise maybe even vibration if that were the case.
