Operation Moab Trail Listing
Discussion in 'Moab' started by NYCO, Mar 31, 2012.
What trails do you want to/plan on running?
Poll closed Apr 30, 2012.
  1. Kane Creek
    48.1%
  2. Poison Spider
    37.0%
  3. Golden Spike
    33.3%
  4. Cliff Hanger
    33.3%
  5. Hells Revenge
    33.3%
  6. Fins & Things
    37.0%
  7. Behind the Rocks
    33.3%
  8. Elephant Hill
    48.1%
  9. Sevenmile Rim
    33.3%
  10. Top of the World
    37.0%
  11. White Rim
    29.6%
  12. Bull Canyon and/or Gemini Bridges
    11.1%
  13. Secret Spire
    18.5%
  14. Onion Creek
    25.9%
  15. Other...
    37.0%
  1. Apr 6, 2012 at 9:55 AM
    #101
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    I think my biggest fear on that entire route is my rear bumper, but I guess it just gives me the excuse to buy/build a new one!
  2. Apr 6, 2012 at 9:55 AM
    #102
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I may go with on trifecta and I'm rolling open diffs. Adam promised I could test his winch lol. Either that or hells...both of which are above my level, but that's what learning is for
  3. Apr 6, 2012 at 10:02 AM
    #103
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    There will be a few places that you will probably need a strap if you don't have a locker. The Golden Crack is probably the biggest one. Should be no biggie. You WILL drag the passenger side corner of your rear bumper on the golden crack. Just be prepared.
  4. Apr 6, 2012 at 10:05 AM
    #104
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    How bad lol
    Alsowhat trail would be easier? Hells or the trifecta
  5. Apr 6, 2012 at 10:05 AM
    #105
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm running Golden spike with O/O diffs should make for a good experience
    I'm hoping that my short wheelbase will help avoid too much dragging but if it happens that's fine
  6. Apr 6, 2012 at 10:09 AM
    #106
    rockgecko03
    Ben
    Rockwall, TX
    I will be prepared to put one of those round moab stickers over the spot. :D
  7. Apr 6, 2012 at 10:11 AM
    #107
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i'd say hells because it has more bypasses
  8. Apr 6, 2012 at 10:24 AM
    #108
    Box Rocket
    Adam
    Syracuse, Utah
    Take a look at this video. Sorry its mostly jeeps, but there is a Tacoma starting at about the 3:25 mark. The Tacoma could have taken a slightly better line but what happens with his truck is pretty typical for a Tacoma. You'll lift a rear tire going in and coming out you'll probably drag your bumper, although this Tacoma comes through pretty lucky without hitting his bumper. If you watch the Jeep Comanche at the end, you'll see how he hit his rear bumper. That's more common for truck like ours.
    http://www.youtube.com/watch?v=nxNBPf4eUlQ?version=3
  9. Apr 6, 2012 at 10:27 AM
    #109
    Box Rocket
    Adam
    Syracuse, Utah
    Hells is easier overall for sure especially if you don't do the hard obstacles.
  10. Apr 6, 2012 at 10:46 AM
    #110
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Which ones would be a good idea to avoid? The fun ones haha?
  11. Apr 6, 2012 at 10:56 AM
    #111
    Box Rocket
    Adam
    Syracuse, Utah
    Only things I would maybe avoid on Hells are the Escalator (although it looks worse than it really is unless you pick the wrong line, then it gets ugly). Tip Over Challenge is dumb IMO. It's not necessarily a difficult obstacle but the risk vs reward is way out of balance. That obstacle is polished really smooth and it's easy to get your front end sliding off line causing a rollover. I've done that obstacle before and have never felt a need to do it again. The Bath Tub is gnarly. You'll know it when you see it. It is a very steep climb to get out of and usually requires a TON of skinny pedal to launch the truck out of the bottom. Hell's Gate is another obstacle that isn't that bad if you're on the correct line but the risk if you screw up is really high. Personally I wouldn't do Hells gate with open diffs.
    But like has been said there are bypasses to all of those and I'm sure there will be some in your group that want to try them so you can watch and decide for yourself if you want to give it a shot or not.
  12. Apr 6, 2012 at 10:58 AM
    #112
    Box Rocket
    Adam
    Syracuse, Utah
    Oh c'mon, don't let me scare you away from it. It's challenging but if you want to run it we can get you through it just fine.
  13. Apr 6, 2012 at 11:00 AM
    #113
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea ben, lets do it.
  14. Apr 6, 2012 at 11:03 AM
    #114
    Blackdawg
    Monte
    Wyoming/St. Louis
    So do it..dude..a little scrape on your rear bumper is not gonna cause problems with your trip home lol
  15. Apr 6, 2012 at 11:10 AM
    #115
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Hells gate was one thing I wanged to try. I got a little bit of comfort when someone said that the risk of tipping over was lower with upen difs because you would spin your tired before the locker got you up and over the tipping point
  16. Apr 6, 2012 at 11:35 AM
    #116
    Box Rocket
    Adam
    Syracuse, Utah
    No. The Crack is not difficult at all. It looks cool cuz you lift tires, but with a locker you line yourself up and drive straight across. It's not hard. The "hard" stuff is really just lots of ledges on the trail, and there are a couple optional obstacles.
    If you are worried about your bumper, I have my stock one still sitting in my garage if you need a replacement. Mine is in perfect shape. :)
    Your spotter should stop you before you get to the tipping point. Spinning tires means you typically have to give more throttle to push through the spot where you're spinning. Not always the best recipe. But seriously I someone wants to try an obstacle, they should try it. That's what's cool about Moab. TONS of stuff to have fun on. You can always change your mind after you see it in person. Or just give it a shot. You'll never know your limits if you don't try.
  17. Apr 6, 2012 at 11:48 AM
    #117
    Blackdawg
    Monte
    Wyoming/St. Louis
    I won't be :D my New Elite bumper is made to do that :cool:
    However little miss princess Ben might be interested! :D
    jk Ben..haha
    and lots of ledges you say? Sounds challenging!
  18. Apr 6, 2012 at 11:51 AM
    #118
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha only you would replace both your OEM bumpers within almost a year..haha
  19. Apr 6, 2012 at 11:52 AM
    #119
    Box Rocket
    Adam
    Syracuse, Utah
    Kane Creek is a decent warm up. The final climb you're talking about on Kane is similar except you're climbing them on Kane Creek. GS you're mostly dropping down the ledges. It's always easier to fall off of something than it is to climb it. :)
    Yeah, I was offering my bumper to Mr. Bassman.
  20. Apr 6, 2012 at 11:53 AM
    #120
    Blackdawg
    Monte
    Wyoming/St. Louis
    OH the ledges are mostly down??
    IFS friendly? or like hard drops??
