#operation_sloppytaco
Discussion in 'Northern California' started by Cristiang19, Dec 11, 2019.
  1. Dec 15, 2019 at 6:15 PM
    #621
    Cristiang19
    Cristiang19 [OP] NOT STUCK
    Cristian
    Bay Area
    '97 3.4L, 4x4 5spd "sloppy taco"
    3inch mid travel, All pro Bumper, skid plates and Relentless Sliders
    V6, and a manual
  2. Dec 15, 2019 at 6:17 PM
    #622
    Cristiang19
    Cristian
    Bay Area
    Does any company make aftermarket ones for my truck, I've seen marlin crawler has a reduction box but not a t-case
  3. Dec 15, 2019 at 6:23 PM
    #623
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Excellent work TW! I love these threads because they have a happy ending!
  4. Dec 15, 2019 at 6:39 PM
    #624
    Cristiang19
    Cristian
    Bay Area
    Some more good news, we got the dodge out today.
  5. Dec 15, 2019 at 6:49 PM
    #625
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Nah, time for the big guns and be done with it :)
    tacoWithstickyrice and Hobbs like this.
  6. Dec 15, 2019 at 7:03 PM
    #626
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    excavator? Or did it dry up enough to get him moving?
  7. Dec 15, 2019 at 7:11 PM
    #627
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Advanced Adapters makes the Atlas, which you can get an adapter to fit your tranny. Good luck breaking that shit. All 300M internals
  8. Dec 15, 2019 at 7:19 PM
    #628
    Cristiang19
    Cristian
    Bay Area
    It dried up enough and we stuffed the ground with twigs and some more wood, not to mention a heavy foot
  9. Dec 15, 2019 at 8:27 PM
    #629
    Cristiang19
    Cristian
    Bay Area
    Is it for a manual v6?
  10. Dec 15, 2019 at 8:33 PM
    #630
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Awesome!
  11. Dec 15, 2019 at 9:25 PM
    #631
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    The one I've got, came from a 98 automatic 4 banger.
  12. Dec 15, 2019 at 9:26 PM
    #632
    Cristiang19
    Cristian
    Bay Area
    Damn, oh well
    That won't work with mine, but thanks tho
    easleycrawler[QUOTED] likes this.
  13. Dec 15, 2019 at 9:34 PM
    #633
    easleycrawler
    Travis
    2014 RC Taco 4wd
    No problem. Sounds like you have some local to you. I'd check with Marlin crawler about getting a rebuilt case, or as someone mentioned above, there is always advance adapters and go with a atlas.
  14. Dec 15, 2019 at 9:49 PM
    #634
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Right on!!!
  15. Dec 15, 2019 at 9:59 PM
    #635
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @Cristiang19
    I'd advise heavily against an Atlas. Unless you are going to do a lot more than just replace the T-case with the Atlas.
    Sure, Atlas is bulletproof. But a J-shift t-case is actually not a weak (chain drive) T-case. If you're stsying with an IFS setup the Atlas is a waste of around $2500... the T-case will be WAY stronger than the entire rest of your front drive train.
    Seriously, this is just my 2 cents, but I'd get you another J-shift and spend that coin elsewhere. Only way I'd go Atlas if it were running a SAS'd front end.
  16. Dec 15, 2019 at 10:18 PM
    #636
    Cristiang19
    Cristian
    Bay Area
    Ahh, I plan on long travel in the future so this helps alot in my choice. Thanks I'll look for a j-shift compatible with my truck
  17. Dec 15, 2019 at 10:21 PM
    #637
    tcjacado
    tcjacado Well-Known Member
  18. Dec 15, 2019 at 11:55 PM
    #638
    cbechtold
    Cory
    Pleasanton, CA
    Just getting a stock t-case is honestly a much better route. Cheap and easy fix. The chain drive t-cases are super strong for what they are, but from my experience, and the direction I'm taking my build, I wish I would have just saved a little more money and bought an Atlas 4speed instead of going with dual cases I currently have. Just my 2cents
  19. Dec 16, 2019 at 12:17 AM
    #639
    ericegonz
    ericegonz Well-Known Member
    Eric
    San Diego
    2019 MGM DCSB TRD OR 4x4
    Method 704 265/75/16 DuraTrac
    A little late to the party..... but this story was inspiring :’)
    Cristiang19[OP] likes this.
  20. Dec 16, 2019 at 7:32 AM
    #640
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
