Opertion Red and Black.
Discussion in 'Street Trucks' started by F16TACO, Jun 10, 2011.
  1. Manwithoutaplan
    CA
    like the the before
  2. F16TACO
    F16TACO [OP] Well-Known Member
    LUKE
    CO Springs
  3. F16TACO
    LUKE
    CO Springs
    in reference to the tail lights?
  4. F16TACO
    LUKE
    CO Springs
    Since being overseas I have been stockpiling parts. Thus far I have a set of color matched eyelids, OEM fender flares on the way from Black Sheep, and about to order a DJM front control arm setup in the next month or so. Still need to get the scoop insert parts for the hood, toyota center caps for the wheels and a catback system (jerry rigged Flowmaster was good for a bit but I wanna do it right). Then gotta find a paint shop at wherever I get stationed next for me paint job. T-Minus 5 months or so until Mod-apalooza. Stay tuned.
  5. Az lowtacoma
    Az lowtacoma Mini Truckin'
    Seth
    Arizona
    95.5 Lowered Tacoma
    k&n cold air intake 57 series, flowmaster 50 series delta flow, viper alarm, auto door locks, big three upgrade, kinetik hc1400r battery, 1/0 gauge wire, Pioneer 4500, Streetacos 3" tapered blocks, Belltech 3" drop leafs, Qa1 coil overs with 550lbs coils, ball joint flip, rear KYB Monomax shocks, 18x8 +40 Enkei Kojins, 225/40/18 Nittio Motivo tires, LCE drilled and slotted rotors, Hawk HPS brake pads, roll pan, 01+ taillights
    Excellent!
  6. F16TACO
    LUKE
    CO Springs
    Well. Seeing as Portuguese island roads are not friendly to a lowered truck my build has taken a bit of a different direction. Put the stock suspension back on and got some 235/75/R15 Goodyear Wrangler tires on the way. Put the eyelids on and talking to a local paint shop about painting the hood and front bumper. I will get pics up when I get the tires on.
    Anyone know where I can purchase Toyota OEM paint by the gallon or quart via the internet? Or anyone have a paint connection in the states?
  7. Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks Bilstein Shocks/Struts DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    Bummer. Your truck would look really sharp completely color-matched with the X-Runner wheels.
    If you actually want the paint to match, you're much better off having the paint done by a professional... 'specially since your truck is red. Even if you buy paint that is mixed to match the paint code of your truck, that doesn't take into consideration the fact that your paint has probably faded due to the sun and the environment.
    Not only that, your hood and bumper have to deal with road debris thrown at it by the vehicles in front of you (and bugs), which means you don't want some cheap, do-it-yourself paint job that is going to flake off at the first rock that comes it's way. The bumper will have to be prepped and painted differently than the hood because the bumper is plastic. In the end, you'll end-up spending hundreds on supplies only to get a questionably good paint job in the end if you try to do it yourself.
    I hate getting stuff painted because it's so freekin' expensive, but it's better to get it done right the first time.
  8. F16TACO
    LUKE
    CO Springs
    I totally agree with the ridiculous prices for painting things. But seeing as I am on a tiny island in the middle of the Atlantic Ocean and there is only one paint shop here, I dont have many options. Probably just going to leave the bumper bare but I have to get the hood painted because the sea air here is going to rust it in the next few months if I dont get it painted.
  9. F16TACO
    LUKE
    CO Springs
    Back to stock suspension.
    235/75/R15 Goodyear Wrangler Silent Armor tires on stock steelies with sweet ass spray paint job.
    May be doing a 1 inch spacer up front to level it.
  10. F16TACO
    LUKE
    CO Springs
    Just ordered a Fat Bobs lift. Post pics when it's installed.
  11. jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    oh dayum going th other direction!
  12. F16TACO
    LUKE
    CO Springs
    Yeah man. European roads are not friendly on lowered trucks. I am out in the country and these roads see as much tractor and cattle traffic as they do vehicle traffic. It was beating the truck up pretty bad. Figured I'd go the other direction for practical reasons. Not to mention I am 3000 miles from nearest Toyota shop.
  13. jmarquez808
    Jess
    Hawaii
    07 4x2 reg cab
    Lol makes sense. If I had 4x4 I would definitely get a lift. Or long travel using total chaos stuff. The little 5 lug gers they have on there website are so nice!!!
  14. F16TACO
    LUKE
    CO Springs
    Yeah if I had $7k laying around I would do a long travel. But for now I go FatBobs. haha
  15. jmarquez808
    Jess
    Hawaii
    07 4x2 reg cab
    lol true, i dont have that or the 4x4 so its only a dream ha ha.
  16. F16TACO
    LUKE
    CO Springs
    well Fat Bob's sent me the wrong stuff. I received two different types of shocks for the rear, the correct one is the type with the threaded end that mounts in the shock tower with the bushings and has the nut that threads on the top. The incorrect one is the type that has the bushing on the rod end that mounts on to a post. There is also some miscellaneous spare bushings and little 2 inch long rod things which I am guessing are for mounting shocks, that came with the kit.I am pretty pissed off about this. Not to mention 4x4parts is dicking me around about the front struts I ordered and hasnt even shipped them 2 weeks after I ordered them.Anyone had any issues with Fat Bobs sending the wrong stuff?
  17. F16TACO
    LUKE
    CO Springs
    Finally got my other rear shock. And Fat Bob's Garage sent me the wrong shock...AGAIN!! These guys are pissing me off. I am still waiting for backordered Bilstein Struts for the front but it would be nice to have one less thing to worry about. Man Fat Bob's is gonna get a nice email tomorrow.
