Opinion on Lift for 11' Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rreisetter, Oct 5, 2011.
  1. Oct 5, 2011 at 9:27 PM
    rreisetter
    rreisetter [OP] Member
    Raquel
    Arizona
    '11 2WD
    TRD Exhaust, In-Dash, Smoked Headlights and Taillights
    So I have a 2011, 2WD, Pre runner, crew cab, V6 Tacoma. I'm looking to get it done and I don't know what to do. I know I for sure want new wheels and tires, a lift, and exhaust then maybe changing my headlights. I'm debating right now on a 3 inch lift with 33s, or a 6 inch lift with 35s. I want to see a difference with a lift and I want to be high up but I don't want a 6 to be too much for me. Yes I am a girl, but I don't see why that would be a factor. Any suggestions? or does anyone have any pictures of these lifts with the tires that I can see? Some people say that a 6 would be too much for me and some say other wise.
    Thanks
  2. Oct 5, 2011 at 9:32 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    +1.
    6 inches on these trucks looks really tool-ish if you ask me. 3 inch is PERFECT! It's clearly beefier without looking like you're trying to over compensate for something.
  3. Oct 5, 2011 at 9:35 PM
    rreisetter
    Raquel
    Arizona
    '11 2WD
    Will I even see a difference with a 3 inch though? that's the only thing I am worried about because i want to be higher up and I've seen trucks that don't look like they even had a lift at all.
  4. Oct 5, 2011 at 9:38 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    My friends truck has a 6" lift. it looks badass, it all depends on your taste tho.
  5. Oct 5, 2011 at 9:42 PM
    rreisetter
    Raquel
    Arizona
    '11 2WD
    the black tacoma in your pictures has a 3 inch lift right?
  6. Oct 5, 2011 at 9:46 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    You have a prerunner yes?
    Look into spindles.
    IIRC you can get 4 inches of lift outta them.
  7. Oct 5, 2011 at 10:04 PM
    rreisetter
    Raquel
    Arizona
    '11 2WD
    Uh what's spindles? ha
  8. Oct 5, 2011 at 10:05 PM
    Blacktacoma23
    2011 Mall Crawler
    So true.
    Yep.
  9. Oct 5, 2011 at 10:40 PM
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    Well I was all set on the OME lift from ARB. Now I'm thinking I want to equal the Baja '12 edition. Get the TSB 4 leaf pack with the same bilstein shocks as the baja edition Tacoma. Probably cheaper than the OME suspension.:cool:
  10. Oct 6, 2011 at 4:32 AM
    2011TACOMAWHR
    2011TACOMAWHR TACOMA 2011
    aaron
    lancaster SC
    2011 OR dbcb shortie
    big tires and tiny rims
    You can always be in the middle and go with rcd 4.5 inch lift
  11. Oct 6, 2011 at 5:21 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Spindles lower where the front hub attaches. Basically, all the suspension components and controls arms are the same but the attachment point for the front hub is lower, thus giving you lift. If I were you, I'd go for the 3" suspension lift first and go the spindles route if you decide you still want more. You don't have to worry about CV angles since you're a prerunner but you might end up needing new upper control arms if you push a full 3" of lift to get your alignment back within spec. The suspension lift will make the truck ride and handle a lot better, spindles won't.
    As far as what you will see, you will notice a 3" lift. Tire selection makes a big difference also. You can do a 3" suspension lift and run tires that are taller and gain a little more height.
