opinion on my interests
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nerby, Nov 14, 2010.
  1. Nov 14, 2010 at 9:06 PM
    nerby
    nerby [OP] Member
    2010 sport
    I drive a grey 2010 tacoma TRD sport and i am wanting to put around $3000 into it but not sure what to get so far this is what i have come up with and i just want some thoughts in what people have to say, if the tires will fit the rims and if not then what size do i need and if the lift i went with is good
    Pro Comp 3 inch Lift Kit with ES9000 Shocks
    LT305/60R18, Pro Comp Xtreme All Terrain Radial
    Xtreme Alloy Series 7031 - Flat Black
    18 x 9, 5 on 5.5Bolt Pattern
  2. Nov 14, 2010 at 9:09 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    I used to run that lift, and I hated it. Rode super super stiff. Felt as if there was no down travel when going over bumps, pot holes, etc..
  3. Nov 14, 2010 at 9:12 PM
    nerby
    nerby [OP] Member
    2010 sport
    so what did u go with now a
  4. Nov 14, 2010 at 9:12 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    Your truck has 6 lugs.. If you are ordering these online, make sure you get the right ones....
  5. Nov 14, 2010 at 9:14 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Pretty sure bolt pattern is 6 on 5.5.
    3000$ is a good chunk of change. You have a bit of options.
    Check out OME lifts, or Bilstein 5100's with eibach
    coils. There's tons of coilover lifts you can do also. A 2 inch add a leaf in the back would do it for most lifts at around 3 inches.
  6. Nov 14, 2010 at 9:15 PM
    nerby
    nerby [OP] Member
    2010 sport
    right you are thanks for catching that
  7. Nov 14, 2010 at 9:16 PM
    jr114
    Jon
    SoCal
    Truck
    icon front and rear
  8. Nov 14, 2010 at 10:39 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    how about save it since you don't seem to know what to get. Just hang back and see what, if anything, grabs you.
