opinion on shocks to get w/ 3" lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by jps76, Nov 20, 2008.
  1. Nov 20, 2008 at 9:32 PM
    jps76
    jps76 [OP] Member
    pemberton, bc, canada
    02 trd xtra cab
    3" revtek lift, 33" bfgs, piaa fog lights, more to come...
    hey all, i have a three inch spacer lift with the stock trd bilsteins in the front and ranchos on the back, any suggestions on what to upgrade the shocks to that would work with the lift? my budget is around $700
    cheers
  2. Nov 20, 2008 at 9:36 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you talking about front, rear, or both?
  3. Nov 21, 2008 at 4:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to Tacoma World.
    People have been haveing good results with the Bilstien 5100's. The front can be adjusted, so You can use them without your spacers (though they both preload the spring to achieve lift). Down South Motorsports has the best price for them.
  4. Nov 21, 2008 at 8:32 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Chris, he's already got the 3" spacer up front, I don't think it would be wise to use the 5100 up front with that. I would go with the Bilstein HDs on all corners.
  5. Nov 21, 2008 at 9:55 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    I really like the OME shocks. I have the Firm ride ones on my truck.
  6. Nov 21, 2008 at 4:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Which is why I said they can be used with out the spacers. :) Personally, the 5100's are valved for the compressed rate of the stock springs (5100 set to 2.5" and NO spacer), whereas the HD's are not.
  7. Nov 21, 2008 at 4:58 PM
    jps76
    jps76 [OP] Member
    02 trd xtra cab
    thanks for the speedy replies, yes it's for both front and rear, didn't really want to go with the 5100s since you can't use them w/ a spacer and you only get 2.5" out of them and i don't want to start loosing height. my main concern is to not loosen my truck up too much because i love the way it corners with almost no body roll, but it's stupidly rough on the back roads.
  8. Nov 21, 2008 at 5:00 PM
    jps76
    jps76 [OP] Member
    02 trd xtra cab
    maybe some new springs are in order too?
  9. Nov 21, 2008 at 5:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can use the 5100's with the spacer lift if they are kept at their stock height setting.
  10. Nov 21, 2008 at 5:19 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Yep, forgot about that part... doh!
  11. Nov 21, 2008 at 5:33 PM
    jps76
    jps76 [OP] Member
    02 trd xtra cab
    nevermind the new springs idea, that makes no sense
  12. Nov 21, 2008 at 6:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    New springs would be MUCH better than the spacer lift.
