Opinion on this lift set-up
Discussion in 'Suspension' started by 2006TRDSPORT, May 15, 2011.
  1. May 15, 2011 at 12:46 AM
    2006TRDSPORT
    2006TRDSPORT [OP] 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    I have been racking my brain trying to decide which lift set-up I want to go with, as I don't want to go cheap and regret it later but at the same time don't want to get to crazy either so I want the most for my money. I think I want to go with the Bilstein 5100's up front set to 2.5" with Light Racing UCA's for alignment purposes. In the back, because I have the stock 3 leaf set-up that sux (when towing a Uhaul earlier this year it caused quite a bit of sag) I'm thinking of getting the new OME Dakar 2.75" lift Leaf Springs & a possible DL carrier bearing drop (not sure about this part yet or if I really need it) to prevent vibrations. Please give me your opinion and whether or not this combination of items would be worth my $1100 or so. THANKS!! Jason
  2. May 16, 2011 at 7:30 PM
    2006TRDSPORT
    Felton, Delaware
    ANY OPINIONS???
  3. May 16, 2011 at 7:40 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    This has been covered 1,000,000 times man! That's a pretty decent set up but will want to look at Eibach or OME coil springs instead of pre loading the crap out of the stock springs. In the rear, thats a good pack for hauling weight.
  4. May 16, 2011 at 7:42 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    looks great. Do it!
  5. May 16, 2011 at 7:42 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    If you don't wheel that much just do the billies at 2.5" and get an AAL.
  6. May 16, 2011 at 7:46 PM
    especk
    Erik
    Redding, CA
    ya the dakars may be a little overkill but i like mine and im sittin at about 2.5" in the front to give u an idea look at my build page. A 2" add a leaf may suit ur needs just fine
  7. May 16, 2011 at 8:00 PM
    2006TRDSPORT
    Felton, Delaware
    Awesome, thnx for your input guys! I do not do much "wheelin" and mostly want the look and capability when I do take it off pavement. I have read numerous posts about ppl adding the AAL, and after a year or two being back to where they started because of old factory leafs and I don't want that, thus the reason for considering the OME leaf pack which should keep me in good shape for years to come. I am also keeping my stock sports wheels but upgrading to either General Grabber AT2's or Nitto Terra Grapplers at 265/70/17 to help prevent the TINY factory wheels with 3" lift problem, and wanting the more aggressive tire as well.
