Opinion on trailer?
Discussion in 'Towing' started by Trent, Oct 3, 2011.
  1. Oct 3, 2011 at 3:05 PM
    Trent
    Trent [OP] Well-Known Member
    Houma, LA
    '91 Toyota Pickup 4x4 DLX
    The wife and I are looking at medium sized travel trailers for our family of four's growing camping addiction.
    Found a pretty good deal on a 2011 Tracer Micro 225M camper locally, and I'd like you guys' opinion on it.
    It's a 25' tandem axle (w/ electric brakes) with a dry weight of 3145 lbs. It seems pretty nose heavy though with a tongue weight of 525lbs. :eek:
    That's my biggest concern. I'm getting the dealer to throw in a weight distribution hitch, but I'm not sure if that buys me enough room on the tongue weight.
    My truck does not have the factory tow package, but I do have a Class III aftermarket hitch, a transmission cooler, brake controller, and Firestone Ride-Rite airbags.
    My Class III hitch has a tongue weight limit of 500 lbs, and 550 with a WD hitch.
    Seems like cutting it a bit close maybe?
    Note that we never camp anywhere without hookups, so the tanks will always be empty.
  2. Oct 3, 2011 at 3:16 PM
    cc350
    cc350 Retired Member
    To much tongue weight! They give you a dry weight. By the time you load her up and fill the propane you'll be way over the top limit...
  3. Oct 3, 2011 at 3:16 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i think 525 is too much for out trucks. you say tanks will empty but what if you need them full just once, or you back stuff in the trailer. i think you want to be closer to 400#
  4. Oct 3, 2011 at 3:19 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    x2. I wouldn't, especially without the tow package. You'll be well over your limit for sure.
  5. Oct 3, 2011 at 3:21 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    If it were close the other way (meaning if you were slightly under), but slightly over is a risk, especially like Pudge and cc mentioned, extra gear adds more weight. You may not fill the tanks until you get to the campsite, but what if you don't empty them before leaving.
  6. Oct 3, 2011 at 3:27 PM
    Trent
    Houma, LA
    Would you guys still say this if I were able to source a Class IV OEM hitch?
    Not that I'm discounting what you guys are saying at all. I'm concerned about it too. That's why I'm asking.
    I really can't understand why a trailer that is so light has such a friggin' heavy nose.
  7. Oct 3, 2011 at 3:50 PM
    dave in maine
    dave in maine Member
    dave
    mid coast maine
    if you store stuff in back of the axles won't that lighten the tongue weight?
  8. Oct 3, 2011 at 3:52 PM
    ILLINOISTACOMAGUY
    ILLINOISTACOMAGUY Well-Known Member
    Darryl
    ILLINOIS
    2005 SR5 SPORT
    WeatherTech Digital floor mats front and rear. Ventvisors, Hood protector, Towing package, Bed tiedowns, Wheel to Wheel steps,
    I think they make a weighted bumper for trailers also..that would lighten the weight up front.
  9. Oct 3, 2011 at 8:29 PM
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
  10. Oct 4, 2011 at 6:00 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Weight limits are established for a reason. You might get away with pulling that much weight for a while but it is too much for the Tacoma when loaded. There will come a time you regret your choice.
    One of the things you are overlooking is that the trailer towing capacity is reduced by passengers and other gear that are inside the truck itself. You will very quickly exceed the Gross Vehicle Weight Rating (which is everything combined) with a trailer of that size and potentially endanger your family by operating the vehicle beyond its design limits.
  11. Oct 4, 2011 at 7:26 AM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    As everybody said, this is too much, especially the tongue weight. The real tongue weight after adding batteries and gear in the trailer will be more than 700lbs, believe me.
    My TT says dry tongue weight is 440lbs, and I measured it to be 600lbs WITHOUT ANYTHING loaded in the trailer, as towed off the dealers lot. That's because of the added options (A/C, water heater, etc.) and the dual battery set up.
    The dry weight numbers really don't mean much, you would not be happy towing that trailer with 4 people in the truck.
  12. Oct 4, 2011 at 1:02 PM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Orange, TX
    2017 Tacoma DCSB Off Road
    I put peanut butter on it.
    Agreed, watch the payload. I have a Silverado now and my Tow rating is 9600 lbs, but it doesn't really matter because by the time you add the hitch weight to my payload of the truck, and the people in it, you max out the GVWR way before you max the tow rating.
    Also, weight distribution hitches move weight off of the rear axle using torsion bars, but they do not lighten tongue weight, it is still what it is, it's just changing the axle loading.
  13. Oct 4, 2011 at 1:13 PM
    pudge151
    Sean
    Connecticut
    how much you wanna bet the OP still buys this trailer
  14. Oct 4, 2011 at 1:52 PM
    sechsgang
    That would be like me. And then he's out shopping for a new truck. Just like me, LOL.
    Only difference is in my case people said I'll be ok with the trailer. :) And I thought so, too. :confused: A few trips to the scales taught me otherwise.
  15. Oct 5, 2011 at 6:49 AM
    Trent
    Houma, LA
    Insanity is asking for advice, getting a consensus, and then just doing what you wanted to do anyway.
    No sir, I am not buying this camper. Already informed the dealer.
