Opinion please!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tjs, Oct 16, 2016.
  1. Oct 16, 2016 at 7:29 AM
    Tjs
    Tjs [OP] Active Member
    2005 TRD Offroad
    Hey guys. I'm planning on getting new shocks for my tacoma. I do major offroading and it also carries alot of weight. More than recommended. Which should i lean to? Old man, Rancho or the advanced bilsteins?? I am stuck on deciding and need some help. Once again major offroading and at times with alot of weight. Kindly weigh in guys.
  2. Oct 16, 2016 at 8:10 PM
    Pigpen
    Dan
    Northwest Montana
    I run my truck heavy and enjoy using it as a truck. I have 5100s up front with 885 coils. In back I have Dakars with the AAL, Ride Rite air bags with cradles and Billsein 110 shocks. It rides great. Running load E 33s too.
    Tjs[OP] likes this.
  3. Oct 16, 2016 at 8:40 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Kings or Icons, expedition rear leafs.
    What's your budget?
  4. Oct 17, 2016 at 4:49 PM
    Tjs
    2005 TRD Offroad
    I'm not looking to spend too much. Anywhere around 1k. I live in south america. The terrain over here offrad is crazy. Kings are a bit pricey and there cylinders are exposed. Not a good thing for where i am. Lol.
  5. Oct 17, 2016 at 4:53 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Jezus, dakars and bags! that must be STIFF
  6. Oct 17, 2016 at 4:57 PM
    10trdtaco
    10trdtaco American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    Not rancho. Budget = bilstien 5100... great shocks!
    Tjs[OP] likes this.
  7. Oct 17, 2016 at 4:59 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Shocks won't help with carrying extra weight. Sounds like you need new leafs (assuming extra weight is in the bed) for that and shocks for the off-roading.
    10trdtaco likes this.
  8. Oct 17, 2016 at 5:09 PM
    Tjs
    2005 TRD Offroad
    Yea. I have the leafs in. Also the ride rite air bags. Its just the shocks im looking for thats capable and provides a softer ride.
  9. Oct 17, 2016 at 5:10 PM
    10trdtaco
    Shayne
    Lynchburg, VA
    Get some 886 coils, 5100s, some Dakar leaf packs, and maybe an aal ??? Decent setup aquirable around $1k
    Sig45 likes this.
  10. Oct 17, 2016 at 5:17 PM
    Sig45
    Mark
    Maine
    This - 5100's on all 4 corners with the 886 coils on front. Without the leafs since you already have that & bags covered.
    10trdtaco[QUOTED] likes this.
  11. Oct 17, 2016 at 5:23 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Welcome to TW. If you get a chance, Id like to see some pictures of the roads you deal with.
    I like seeing toyotas outside of north america doing what they were designed to do. :thumbsup:
    Tjs[OP] and 10trdtaco like this.
  12. Oct 17, 2016 at 9:00 PM
    Pigpen
    Dan
    Northwest Montana
    With load E tires... You'd be surprised how nice the ride is. High speed potholes and washboard - no problem. I do feel the low speed small bumps more than a stock rig, but that's not what I built this for!
    Tjs[OP] likes this.
  13. Oct 22, 2016 at 4:17 PM
    Derrick1030
    Derrick1030 Well-Known Member
    Derrick
    TRD PreRunner Off-road SR5 Acc cab
    All stock accept for fabric on door panel was swapped out
    Kings!!!!!!
