Opinion/will it fit question regarding the V-Tec Raptor Wheel
Discussion in 'Wheels & Tires' started by eckcessive, Jan 18, 2011.
  1. Jan 18, 2011 at 1:00 PM
    eckcessive
    eckcessive [OP] Well-Known Member
    Ken
    Gilbert, AZ
    in between Tacoma's
    I'm looking to change out wheels and tires. I really like the V-Tec Raptor and the price is pretty good at DiscountTire, $120. Is anyone running these? I was inclined to just get the 16" option so I could buy tires first and then later the wheels, but I don't think the specs are ideal. The 17" specs seem to be closer to stock, but I'm currently running 16" stock so would have to do both wheels and tires at the same time.
    I'll prob be getting either 265/75/16 or 265/70/17 tires.
    Full Wheel Specs: http://www.visionwheel.com/pdf/V-Tec 372 RWD Tech2.pdf
    16x8 6-139.7mm BP - 0mm OS - 4.45 BS - 110 Hub Bore
    17x8 6-139.7mm BP - 25mm OS - 5.43 BS - 106.2 HB
    17x9 6-139.7mm BP - 25mm OS - 6 BS - 106.2 HB
  2. Jan 19, 2011 at 6:44 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Option 1 has the best specs. Just makes sure someone else has these and that they don't rub the calipers.
  3. Jan 19, 2011 at 8:25 AM
    eckcessive
    Ken
    Gilbert, AZ
    in between Tacoma's
    That would work better so I can stagger the purchase. I guess I thought the 17" would be better because the 25 offset is closer to the 30 offset on the stock offroad wheels.
    Thanks for the reply.
  4. Jan 19, 2011 at 8:30 AM
    TexasTacoma37
    That only matters if they are the same width. Backspacing is what you should be looking at.
    With the 4.5" backspacing, you can fit your 265s, or you can go up to 33's someday if you get a lift. With the 5.5" backspacing you are limiting your tire options.
  5. Jan 19, 2011 at 2:23 PM
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    I really like these wheels too...can't beat the price. So if I went with the 17x8 with 265/70/17 do you think I will be fine? I don't see me ever going to a bigger tire.
  6. Jan 19, 2011 at 2:28 PM
    TexasTacoma37
    You'll be fine with the 17x8's but not the 17x9's.
  7. Jan 19, 2011 at 2:52 PM
    eckcessive
    Ken
    Gilbert, AZ
    in between Tacoma's
    The 16" versions are even $10 cheaper. :D
    I just haven't heard anyone else running them. I saw them on a Jeep and they looked awesome.
  8. Jan 30, 2011 at 9:34 PM
    Tacodog
    Tacodog Well-Known Member
    Ron
    Renton, Wa.
    ‘19 TRD offroad DCSB Cement
    Icon stage 1, Icon upper control arms, 17” Fuel wheels,Ridge Grapplers, TRD exhaust, leather interior.
    Tried this on. Option 1 specs. Tire 265/75/16 Hankook MT.
