Opinions: bad clutch or seized compressor?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chickenofthesea, Aug 30, 2024.
  1. Aug 30, 2024 at 3:49 PM
    chickenofthesea
    chickenofthesea [OP] New Member
    Philadelphia, PA
    2012 Tacoma Access Cab 4x4 2.7L 5-Speed
    Hi Everyone,
    I'm experiencing the dreaded blinking A/C light + associated problem (see video below, sound on), and am hoping to solicit opinions if this is a bad clutch only, or a seized / seizing compressor. Fingers crossed it's just the clutch, for obvious reasons, but I acknowledge there might not be enough data at this point for an unequivocal diagnosis.
    Important context:
    1. I was driving with the A/C on and working fine, then it gave a brief shriek (similar to the video). Air immediately starting blowing warm, with the A/C button blinking.
    2. Re the video, the shrieking starts immediately upon pressing the A/C button / the clutch engages. It stops immediately when pressing the button again.
    3. Note the dried ribbon of black goo coming out of the clutch.
    4. I've confirmed the clutch relay is functional.
    Thank you!
  2. Aug 31, 2024 at 5:51 AM
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    My truck had the same exact symptoms and made the same exact horrible noise last month. It was my A/C clutch, once I removed it the clutch more or less fell apart. Easy fix, the one c-clip can be a pain in the ass to remove and install without the correct angled c-clip pliers. Hopefully the a/c clutch isn’t on national back order anymore, it was last month. I went OEM Toyota.
  3. Aug 31, 2024 at 7:49 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Welcome to TW forums!
    Nice first post. It's specific, with context, and even audio/video documentation.
  4. Sep 3, 2024 at 1:44 PM
    chickenofthesea
    Philadelphia, PA
    Thank you! I ordered an OEM clutch today (it's no longer on backorder).
    goforbroke123[QUOTED] likes this.
  5. Sep 3, 2024 at 2:59 PM
    TacoTuesday1
    SD CA
    12yo vehicle
    I would be doing a whole compressor not a clutch.
  6. Sep 3, 2024 at 3:11 PM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    Why replace the compressor? Worst case if he leaves it in would be it quits one day.
