Opinions needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DBTaco, Jan 30, 2013.
  1. Jan 30, 2013 at 4:54 AM
    DBTaco
    DBTaco [OP] Well-Known Member
    NC
    '08 4x4 TRD off road
    Ive been reading on this site before i ever bought my truck about aftermarket items. I want a lift that doesnt require new uca's. I started out wanting a spacer lift but i think i have gotten away from that and looking at 5100's. I dont do any hard offroading just going through paths to hunting spots. Mostly for looks for the most part. I do have new 265/70/16 street tires that were on the truck when i bought it last month. I want to get new rims to fit my tires i have now until these wear out then i will step up to 265/75/16. Im thinking 16x8 with backspacing of 4" or 4.5". Been looking at the dick cepek dc-2, konig countersteer, scs f-5, or pro comp 7089. All these have these baxkspacing. I would like yalls opinion of which lift and wheels/backspacing i would need. Also, im concerned about having vibrations from lifting as ive been reading.
  2. Jan 30, 2013 at 6:12 PM
    DBTaco
    NC
  3. Jan 30, 2013 at 6:29 PM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    Im in a very similar situation. What im doing is getting a Rear TSB done at my dealer, if that dosent work out then just get a 1.5" aal. Then putting bilstein 5100's around in all 4 corners. Set the front bilsteins to 1.75". This is a pretty cheap way to get a quality lift that shouldn't require new UCA's.
    For the wheels, all those you have listed are good. I personally went with KMC XD Enduros 16", I can run the stock tires on them perfectly fine and then when they wear out I will put on some 265/75/16 BFG KM2's or MT MTZ's.
    If you have any more questions, ask away, im happy to help.
    Good luck man.
  4. Jan 30, 2013 at 6:44 PM
    DBTaco
    NC
    Thanks for your reply, do you have any pics of your setup?
  5. Feb 2, 2013 at 5:14 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Toytec and OME both offer a few different kits that might fit your needs and budget. Pricing will vary, but I always like to recommend that you make a budget for yourself and go from there. There are a lot of proven setups out there so it would help if we know what kind of budget you're working with.
    As far as wheels are concern, I can tell you that from the ones you listed that only the SCS F-5 are hubcentric. Our wheels will fit snugly and tight on the hub just like the factory wheel which greatly helps reduce and minimize vibration issues.
  6. Feb 2, 2013 at 5:25 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i plan on buying taller coils to achieve lift, as i would also appreciate the stiffer spring rate. 5100's set at zero to dampen the stiffer springs and a 3 leaf aal with 5100's.
    sounds flawless to me but obviously, i havn't driven it yet.
    i would guess 5100s on stock coils or any coil-loading spacer to be fine for street use. i just get tired of riding around on the bumpstops when off-road
