Opinions on a car from Tacoma owners
Discussion in 'General Automotive' started by JasonJump, Aug 16, 2010.
  1. Aug 16, 2010 at 9:27 AM
    JasonJump
    JasonJump [OP] Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    .....mazdas... like mazda 6 mazda 3??
  2. Aug 16, 2010 at 9:33 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    V6 is that year is around 23-26 MPG depending how well was kept. My friend just sold his outback due to load of problems.
    Do you need AWD (do you get snow?) ?
    Also I am going to suggest again that you consider minivan for your wife. Even old Honda Odyssey will be a good deal. They are not abused (driven by soccer moms, maintained by service) and it will be easy on your wifes back. Believe its well worth it.:cool:
  3. Aug 16, 2010 at 9:35 AM
    DoctorSolo
    DoctorSolo New Member
    Colorado Springs
    09 SR5 Sport
    Noticed the OP is in Utah, so AWD is a good thing there. Subie's are very tough and very safe. You will not break the trans unless you are drag racing a lot, just FYI. I trust Honda, Subaru, and Toyota...in that order...
    My .02
  4. Aug 16, 2010 at 9:42 AM
    BlueT
    NorthEast
    IMHO
    To OP, and other first time fathers :D no offense but you can not approach that with Man ideology.
    Simply 4 door sedan is bad choice, imagine your self handling 25 lb trying to squeeze on the back of sedan. You need to lean, crouch, once that is done you need to put baby carriage to the trunk (20lb again) while leaning again. After a month, your wife back is going to hurt like crazy. Your car needs to be off the ground so Minivan, Honda Crv, Toyota Rav 4 should be your choices unless you can afford something bigger.
    :D
  5. Aug 16, 2010 at 9:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    which motor does it have, the boxer or the v6? If they replaced the transmission, there should be some documentation and maybe even a warranty for a certain number of miles. You have to beware anytime you're buying a high mileage vehicle, even if it was properly maintained. Unfortunately, luck plays into it and sometimes things just stop working or break. The outback is a great car though, good space, handles great in the snow and is very safe. Not a bad price on the wagon if everything seems in order with the car mechanically, might be able to negotiate it down a little unless he's getting other offers.
  6. Aug 16, 2010 at 9:44 AM
    JasonJump
    Yukon Oklahoma
    We are back in Oklahoma now, so AWD isn't a must anymore. I like the sounds of the corolla
  7. Aug 16, 2010 at 10:00 AM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    Certain Subaru engines from 1998-2004 had head gasket issues. It's actually not a big deal, since the coolant leaks were external and could often be solved with "Genuine Subaru Coolant Conditioner." Maybe the car with the new radiator had a head gasket-related system failure?
    The main killer of Subies is rust. Just find a clean car and you'll be fine. Oh, and between '98 and '04, use that coolant conditioner.
  8. Aug 16, 2010 at 10:05 AM
    JasonJump
    Yukon Oklahoma
    Its in Oklahoma, so hopefully rust wouldn't be an issue, I think I need to ask him about documents on the tranny and Radiator... see what the warranties are?
    On a side note, I think this Subaru sits about as high as a minivan and has about as much room..... ? maybe not
  9. Aug 16, 2010 at 10:08 AM
    VTDave
    Vermont, USA
    My wife's '00 Outback (160k miles) has a higher ground clearance than a Toyota Sienna minivan. That much I can tell you.
    There's an interesting story behind that involving a winter camping trip and an unplowed road...
  10. Aug 16, 2010 at 10:17 AM
    VTDave
    Vermont, USA
    Also, if you decide on a Camry...my dad has had four of them since the mid 80s. He thinks the 1995-2001 model years were the golden age of bulletproof reliability.
    Just an example: the original front end suspension components on his '95 Camry are still tight. The 4cyl motor doesn't consume a drop of oil at ~270k. The AC hasn't needed recharging. It is one well-built car, and I remember it as a peppy and exciting car to drive back when I was 16. I am now 31. Not bad for what amounts to one step above "econo box" status.
    PS - Camry, Accord, Corolla, etc., all suck in snow. Outback kicks a$$ for that purpose. Very different cars.
  11. Aug 16, 2010 at 10:37 AM
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    Honda if you want a smaller car.
  12. Aug 16, 2010 at 10:42 AM
    JasonJump
    Yukon Oklahoma
    Interesting, Thanks They don't look half bad either, I might check some out
  13. Aug 16, 2010 at 10:59 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    All good cars - especially the Toyota and Honda. Longer lives then the Nissan generally speaking... according to my mechanic anyway (in his experience)....
  14. Aug 16, 2010 at 12:30 PM
    JasonJump
    Yukon Oklahoma
    Thats what I've heard too, I had an '02 altima that had a rod or wrist pin knock at 70k... needed a new engine haha
  15. Aug 16, 2010 at 12:36 PM
    #35
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    I see that Toyota and Honda have been brought up here alot. Another vehicle to possible look at that has some room is a Scion xB. I bought my second Scion xB last year and it has been a great vehicle. Defintely roomy for bigger folks.
  16. Aug 16, 2010 at 12:45 PM
    #36
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Subaru
    have a 06 impreza. it came down to that or a corolla.
    but went with the subaru because of the all wheel drive
    have been very impressed so far, great in the snow, no problems yet - nothing
  17. Aug 16, 2010 at 2:08 PM
    #37
    BlueT
    NorthEast
    Again thinking with the dipstick :D are we ?
    Ground clearance is a man thing, but does the second row seat is at the same height? I am pretty sure its not. Hence to put the kid into the car seat in minivan you don't have to squat or lean. Not to mention you are not worried about hitting his head.
    Dont forget about sliding doors ;)
  18. Aug 16, 2010 at 2:12 PM
    #38
    JasonJump
    Yukon Oklahoma
    All valid points, ha I am new to this parenting thing. Going to be a learning experience
  19. Aug 16, 2010 at 2:18 PM
    #39
    myname150
    myname150 Well-Known Member
    Honestly i'd go for a prius, only the Gen III, NOT Gen II.
    Being a computer geek i love all the technology the prius has and this new generation is alot more faster than the other one, and most drivers get 50+ MPG!!! :eek:
    But if you dont want the prius....my dad has the camry and i hattteee driving it, it feels so underpowered, he has the I4 so my guess is the V6 would feel and drive alot better.
    Based on styling though, id give props to the Honda Accord, i like the looks of that over all the others, i dont know how the new ones drive, but we had one back in 93 and it was a great car never had any major problems and we sold it in 2000 (i think) to get a RX300.
  20. Aug 16, 2010 at 2:19 PM
    #40
    BlueT
    NorthEast
    Been there done that, now I am just waiting when all of my kids get out of the house to college and stop spending my money :D
    maybe I will be able to park car in second garage. :rolleyes:
    But seriously, you can buy whatever you want but she is probably going to want minivan anyway. Buy Her now and be done with it. ;)
    Otherwise one day you may discover that your truck missing (I see you have double cab) and there note on the 4 door sedan saying
    "Back hurts, took your truck to doctor, drive sedan its more fuel efficient, Love you and truck." ;)
