Opinions on budget setup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Flannel_Lover, Dec 22, 2015.
  1. Feb 22, 2016 at 8:02 AM
    Pigpen
    Dan
    Northwest Montana
    FWIW, I'm running 255/85/16 Toyo M55 tires with my 5100s @ 1.75 (stock UCAs and wheels) with great results - and minimal rubbing. The skinny tire reduces the wonky road manners and also the rubbing issues, plus, it's a true 33.
  2. Feb 22, 2016 at 8:43 AM
    Flannel_Lover
    Flannel_Lover [OP] Your resident questionable advice giver
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    Alpine component speakers Rockford Fosgate 10" sub Pioneer DEH-X6800BT Kicker CX 300W amp Extang Trifecta Big Country Brush Guard
    FWIW?
    I would go with a 255/85r16. But personally I don't like the look of skinny tires. I'd rather have a wider tire and sacrifice some height.
  3. Feb 22, 2016 at 11:29 PM
    Pigpen
    Dan
    Northwest Montana
    For What It's Worth...
    I hear you on having an opinion about skinny tires. I like it, but that's me.
