opinions on bumpers for 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by Flash2408, Feb 20, 2011.
  1. Feb 20, 2011 at 6:16 PM
    Flash2408
    Flash2408 [OP] Well-Known Member
    Justin
    Chattanooga
    99 reg cab 4x4 green
    rough country lift
    all pro tube style or the steel plate style?
  2. Feb 20, 2011 at 6:20 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    What are you using it for... And rear or front?
    Tube is more for offroad, lighter, better approach angle and easier to access.
    Plate if for style and usage.
  3. Feb 21, 2011 at 12:54 PM
    Flash2408
    Justin
    Chattanooga
    rough country lift
    Im for style and trails with some mudding
  4. Feb 21, 2011 at 12:59 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
  5. Feb 21, 2011 at 1:10 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    How much heavier are the plate bumpers like Elite, etc... compared to the stock?
    And does the increase in weight affect driveability and mpg?
  6. Feb 21, 2011 at 1:34 PM
    Max-4_Yota
    Michael
    South Carolina
    Squattin'
    I believe the Elite plate bumper is about 100lbs. Im sure the stock bumper dosen't weigh much its mostly plastic.
  7. Feb 21, 2011 at 2:49 PM
    dmz1241
    dmz1241 Well-Known Member
    Dan
    SE, Connecticut
    01 Gold DC TRD
    Bilstein 5100's all around, Eibach coils, 2" shackles, Flowmaster 60 Series
    any good suggestions for rear bumpers. tube or plate. I just dont want to pay more than 450 and dont wanna get another stock bumper. the one i have now is completely rusted out.
  8. Feb 21, 2011 at 4:46 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
  9. Feb 21, 2011 at 5:13 PM
    dmz1241
    Dan
    SE, Connecticut
    01 Gold DC TRD
    thanks, i really like that one. thats another thing i was looking for in a bumper, was the wrap around sides. thanks a lot man.
  10. Feb 21, 2011 at 5:15 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    youre welcome
  11. Feb 21, 2011 at 7:05 PM
    Flash2408
    Justin
    Chattanooga
    rough country lift
    Elite makes a NICE looking rear bumper
  12. Feb 21, 2011 at 7:10 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
  13. Feb 21, 2011 at 9:23 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The Elite bumper with winch installed weighed 160 lbs. That is with synthetic cable. The toyota tupperware and cross bracing that gets removed weighed 30 lbs. So a net gain of 130 lbs.
    It did not effect driveability at all but I have the SAWs with 650 lbs coils. If anything, the added weight smoothed it out a wee bit. I am sure on stock coils it would be a different story.
    Not really sure about mpgs. I had already lost some when I did the lift and put on bigger tires. I don't think adding the bumper made it any worse.
  14. Feb 22, 2011 at 3:34 AM
    Nick_Taco
    Nick_Taco Well-Known Member
    Nick
    Maryland
    2014 DCSB OR 4x4 Auto
    i want either elites bumper or an ARB bumper but i just dont have the money right now :/
